rvalle Posted September 6, 2024 Posted September 6, 2024 Hi @rpardini I am putthing an M1 in production for a MAAS server, the M.2 and ram make it ideal for LAB deployment. I found a problem Network downstream is very fast, but upstream below 100Kb/s. It should be getting 7.5Mb/s... as a RPI4, or the M1 with an USB ethernet adapter. My M1 is on 6.6.39, did you notice this before? I will try to test with the latest verion.... R. 0 Quote
rvalle Posted September 6, 2024 Posted September 6, 2024 Ok, I tested with armbian 24.8.1/6.6.47 and it seems to be normal now. R. 0 Quote
bunducafe Posted November 26, 2025 Posted November 26, 2025 I used the latest official image for a brand new install and set up OMV afterwards. So far everything works, but I ran into the "sata-reboot" bug. That said: Once I reboot after an update for example the sata drive is not being recognized. M2 nvme does come up as usual but not the sata ssd. Only remedy: Shutdown the M1, unplug, replug power cable and this cold reboot does the trick and the sata drive comes up again properly. It seems to be a kernel bug somehow and via armbian-config I tried several kernels but the bug unfortunately persists. Any ideas? 0 Quote
