Set static IP in jessie server on orange pi one
I want to set static IP in armbian, I edit interfaces in /etc/network as follow
auto lo
iface lo inet loopback
iface eth0 inet static
address 172.19.19.110
netmask 255.255.255.0
gateway 172.19.19.253
but when in terminal get ifconfig , address ,...there isn't exist and ping address is `Destination host unreachable` what am I missing??
edit :   /etc/network/interfaces
# start ###
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
# The primary network interface
# allow-hotplug eth0
# iface eth0 inet dhcp
# Static IP address
auto eth0      # ou auto enp0s7 (see  ifconfig)
        address 192.168.25.3
        gateway 192.168.25.1
# end ###
and change :   /etc/resolv.conf
domain domain.name
search domain.name
nameserver 8.8.8.8
nameserver 8.8.4.4
# for your preference
I am trying to setup my OPI Lite wi-fi connection with no success. (OPI Lite has only WiFi connection)
I downloaded and installed Debian_jessie_default_3.4.113.
I have updated /etc/network/interfaces with next:
### General setup - Local loopback
auto lo
### General setup - WI-FI WAN Network
auto wlan0
iface wlan0 inet static
  address 192.168.100.52
  gateway 192.168.100.1
  dns-nameservers 8.8.8.8 8.8.4.4
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
I have updated /etc/wpa_supplicant/wpa_supplicant.conf with next:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
        ssid="DIGI-B3ED"
        key_mgmt=WPA-PSK
        psk="P9XwDmuF"
Restarted device >>
lo gets:
inet addr: 127.0.0.1
UP LOOPBACK RUNNING
wlan0 states:
UP BRODCAST RUNNING MULTICAST with NO IP address
When I run: sudo ifup wlan0, I get:
wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Failed to bring up wlan0
Code is perfectly running on RaspberyPi2, OPI Zero but, NO OPI Lite !!
Please someone help !
Thank you.
