ej0rge Posted April 20, 2022 Posted April 20, 2022 Armbianmonitor: http://ix.io/3VF9 When i first tried out my orange pi prime in october 2020 i thought i recalled that the wifi worked. With a current armbian image, the wifi can't authenticate. I tried several of the available kernel images. I'm sure that the wpa2 password is correct because I control the router and other devices connect all the time. If i plug in an ath9x usb wifi dongle, that is able to connect, so it would appear to be an issue with the onboard rtl8723bs driver. 0 Quote
