OrangePi Prime: problem with UART
dmitry_z
Hello to everyone ,
I'm trying to read NMEA messages from GPS receiver via UART .
But can't read anything on pins 8,10 & 38,40  ..
What coulb be a reason ? GPS receiver is working fine , I can read it via USB-UART converter on the same board ...
Thanks in advance !
Here's my system (UARTs are enabled via armbian config utility):
root@orangepiprime:/boot# cat armbianEnv.txt
verbosity=1
console=both
overlay_prefix=sun50i-h5
rootdev=UUID=aca8c4ac-41d0-4e0b-ae7e-1d727baa4d43
rootfstype=ext4
overlays=pps-gpio uart1 uart2 uart3
root@orangepiprime:/boot# uname -a
Linux orangepiprime 4.14.70-sunxi64 #274 SMP Wed Sep 19 12:09:30 CEST 2018 aarch64 GNU/Linux
Link to comment
Share on other sites
Pin 8,10 are not UART, although schematic labeled them wrongly.
Pin 38,40 are not UART too, they are PC11/PC12.
UART1 is dedicated on BT, so not breakout on header ...
Did you tried the UART2 on pin 11,13 ?
Did you tried the UART3 on pin 23,24 if you are not using SPI1 ?
Link to comment
Thank you so much, Martin !
UART2 is found on pins 11,13 indeed !
One more question:
is it right to define in armbianEnv.txt
 param_pps_pin=PA7
and connect PPS wire to pin 29 ?
I mean no mismatch here ?
Link to comment
