Does Someone have a dtb file that enabled the ethernet network for mecool the km3 tv box? The meson-g12a-sei510.dtb file does not enable the ethernet network card in my mecool km3 tv box.
The speed of the ethernet network card of my mecool km3 is 100 MB.
The motherboard is km9 X2 LP4 v 2.2
Two year ago i installed armbian in this tv box with network ethernet card running without problem, now i need to install armbian again but i do not remember that dbt file i used...It only i remeber is that i download from this forum and it was shared per someone but now i hasn't  found the dbt file.
The error that is showed in Dmesg files is:
20.765724] systemd-journald[941]: Received client request to flush runtime journal. [ 26.508116] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 0000000,00000000,00006280 and advertisement 0000000,00000000,00006280 failed: -22 [ 26.528442] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1 [ 26.540074] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) [ 26.871298] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 0000000,00000000,00006280 and advertisement 0000000,00000000,00006280 failed: -22 [ 26.884537] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1 [ 26.890484] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) [ 26.971249] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 0000000,00000000,00006280 and advertisement 0000000,00000000,00006280 failed: -22 [ 26.984577] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1 [ 26.990555] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) [ 27.067959] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 0000000,00000000,00006280 and advertisement 0000000,00000000,00006280 failed: -22 [ 27.081513] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1 [ 27.087453] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) [ 27.194560] meson8b-dwmac ff3f0000.ethernet eth0: validation of rmii with support 0000000,00000000,00006280 and advertisement 0000000,00000000,00006280 failed: -22 [ 27.208229] meson8b-dwmac ff3f0000.ethernet eth0: no phy at addr -1 [ 27.214218] meson8b-dwmac ff3f0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
Thanks.
please in this forum have to take part  a user that he is using armbian with mecool km3 or mecool km9 pro tv box.
could he share his dtb file?
Thanks.
