Hi. I use Armbian 22.05 Jammy Kernel 5.17 on my rock 3a. The blinking blue is very annoying. How can i stop this LED?
Edited by hyma
path to trigger file for leds is different across board families so I don't know exactly about that board. Try something like this:
root@pihole:~# find /sys -type f|grep led|grep trigger
/sys/devices/platform/leds/leds/orangepi:red:status/trigger
/sys/devices/platform/leds/leds/orangepi:green:pwr/trigger
In this case these are the led trigger files from an Orange Pi One. Use cat on the trigger file to know which values are allowed, then echo one into the file like
echo heartbeat > trigger
thx for the quick response. i not see in this list any devices by color
find /sys -type f|grep led|grep trigger |grep devices
/sys/devices/platform/leds/leds/wifi-led/trigger
/sys/devices/platform/leds/leds/user-led/trigger
/sys/devices/platform/fe310000.mmc/leds/mmc1::/trigger
cat /sys/devices/platform/leds/leds/user-led/trigger
none usb-gadget usb-host kbd-scrolllock kbd-numlock kbd-capslock kbd-kanalock kbd-shiftlock kbd-altgrlock kbd-ctrllock kbd-altlock kbd-shiftllock kbd-shiftrlock kbd-ctrlllock kbd-ctrlrlock usbport mmc0 disk-activity disk-read disk-write ide-disk mtd nand-disk [heartbeat] cpu cpu0 cpu1 cpu2 cpu3 activity default-on panic mmc1 rfkill-any rfkill-none stmmac-1:00:link stmmac-1:00:1Gbps stmmac-1:00:100Mbps stmmac-1:00:10Mbps
cat /sys/devices/platform/fe310000.mmc/leds/mmc1::/trigger
none usb-gadget usb-host kbd-scrolllock kbd-numlock kbd-capslock kbd-kanalock kbd-shiftlock kbd-altgrlock kbd-ctrllock kbd-altlock kbd-shiftllock kbd-shiftrlock kbd-ctrlllock kbd-ctrlrlock usbport mmc0 disk-activity disk-read disk-write ide-disk mtd nand-disk heartbeat cpu cpu0 cpu1 cpu2 cpu3 activity default-on panic [mmc1] rfkill-any rfkill-none stmmac-1:00:link stmmac-1:00:1Gbps stmmac-1:00:100Mbps stmmac-1:00:10Mbps
cat /sys/devices/platform/leds/leds/wifi-led/trigger
[none] usb-gadget usb-host kbd-scrolllock kbd-numlock kbd-capslock kbd-kanalock kbd-shiftlock kbd-altgrlock kbd-ctrllock kbd-altlock kbd-shiftllock kbd-shiftrlock kbd-ctrlllock kbd-ctrlrlock usbport mmc0 disk-activity disk-read disk-write ide-disk mtd nand-disk heartbeat cpu cpu0 cpu1 cpu2 cpu3 activity default-on panic mmc1 rfkill-any rfkill-none stmmac-1:00:link stmmac-1:00:1Gbps stmmac-1:00:100Mbps stmmac-1:00:10Mbps
Then yours probably is not named with a color but with purpose. Simply try adjusting all of them and see what happens. You cannot do any harm doing so.
My best guess would be the user-led ...
thx
the user-led is correct path. i used "none" to turn off LED, it's work for me
echo none > /sys/devices/platform/leds/leds/user-led/trigger
