I’m running nanopi r4s with armbian 22.02.1 bullseye.
After finishing edit /etc/network/interfaces via armbian-config,  there was an error while restarting services.
Fail to stop network-manager.service: Unit network-manager.service not loaded.
However, for bullseye, network-manager.service might be no longer available.
  On 6/8/2022 at 2:08 AM, Namhong Kim said:
Same problem here. I've installed an AC7260 pcie module and can't use it as AP with the same message above after installing hotspot config in armbian-config.
Expand
armbian-config seems to be under major modification currently.
you may have to set up hotspot manually in case that armbian-config doesn't work.
