Hello together,
I just can't get VLC to work with 1080p mp4 on Armbian 22.02 Bullseye. The video starts, but it jerks enormously. 720p on the other hand runs perfectly. Does anyone have any ideas?
best regards,
Mike
Please provide diagnostic information using:
armbianmonitor -u
Post the link given. By providing additional diagnostic information you may have a better chance of someone replying with ideas and possibly answers.
Try using mpv instead.
VLC is not accelerated with no images.
And provide the needed info. I know nothing here with this question. What board, what kernel, what video file, ...
Thank you very much for the friendly replies. Sorry for the poor information.
Armbian 22.02.1
Kernel: Linux 4.9.255-sun50iw9
Board: Orange Pi Zero 2 Plus (H616)
I also tested it on Debian with xfce and MPV
Orangepizero2_3.0.0_debian_bullseye_desktop_xfce_linux5.16.17.7z
MPV gave the same result but without sound. My goal is to play the video via cvlc but if it only works with desktop, so it is. Unfortunately it did not work. ffplay did not work at all too.
Thank you very much for your help
Mike
Video Metadata:
  Metadata:
    major_brand     : isom
    minor_version   : 512
    compatible_brands: isomiso2avc1mp41
    encoder         : Lavf58.20.100
  Duration: 00:00:44.77, start: 0.000000, bitrate: 4088 kb/s
    Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuvj420p(pc), 1920x1080, 3949 kb/s, 59.94 fps, 59.94 tbr, 60k tbn, 119.88 tbc (default)
    Metadata:
      handler_name    : VideoHandler
    Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 128 kb/s (default)
    Metadata:
      handler_name    : SoundHandler
armbianmonitor -U (the upload failed with -u.. )
so here the output:
     1
     2	### lsusb:
     3
     4	Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
     5	Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
     6	Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
     7	Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
     8	Bus 004 Device 002: ID 0603:00f2 Novatek Microelectronics Corp. Keyboard (Labtec Ultra Flat Keyboard)
     9	Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    10	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    11
    12	/:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M
    13	/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M
    14	/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M
    15	    |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
    16	    |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
    17	/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M
    18	/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M
    19	/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M
    20
    21	### Userland:
    22
    23	PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    24
    25	### Installed packages:
    26
    27	ii  armbian-bsp-cli-orangepizero2      22.02.1                        arm64        Armbian board support files for orangepizero2
    28	ii  armbian-config                     22.02.2                        all          Armbian configuration utility
    29	ii  armbian-firmware-full              22.02.2                        all          Linux firmware-full
    30	ii  armbian-zsh                        22.05.0-trunk.0039             all          Armbian improved ZShell
    31	ii  hostapd                            3:2.10-6~armbian22.02.3+1      arm64        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
    32	ii  htop                               3.1.0-0~armbian20.08.2+1       arm64        interactive processes viewer
    33	ii  linux-base                         4.6                            all          Linux image base package
    34	ii  linux-dtb-legacy-sun50iw9          22.05.0-trunk.0001             arm64        Linux DTB, version 4.9.255-sun50iw9
    35	ii  linux-image-legacy-sun50iw9        22.05.0-trunk.0001             arm64        Linux kernel, version 4.9.255-sun50iw9
    36	ii  linux-libc-dev:arm64               22.02.1                        arm64        Armbian Linux support headers for userspace development
    37	ii  linux-u-boot-orangepizero2-legacy  22.02.1                        arm64        Uboot loader 2018.05
    38
    39	### Loaded modules:
    40
    41	Module                  Size  Used by
    42	zram                   36864  2
    43	sprdwl_ng             438272  0
    44	sprdbt_tty             40960  2
    45	uwe5622_bsp_sdio      294912  2 sprdbt_tty,sprdwl_ng
    46	fuse                  135168  1
    47
    48	### Current system health:
    49
    50	Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
    51	17:24:27:   ---      1.27   0%   0%   0%   0%   0%   0% 38.0°C  0/5
    52	17:24:27:   ---      1.27   4%   3%   0%   1%   0%   0% 39.8°C  0/5
    53	17:24:28:   ---      1.27   4%   4%   0%   0%   0%   0% 39.8°C  0/5
    54	17:24:28:   ---      1.27   4%   3%   0%   0%   0%   0% 39.8°C  0/5
    55	17:24:28:   ---      1.27   4%   3%   0%   1%   0%   0% 39.6°C  0/5
    56	17:24:31:   ---      1.25   0%   0%   0%   0%   0%   0% 51.0°C  0/5
    57	17:24:32:   ---      1.25  83%   0%  83%   0%   0%   0% 51.3°C  0/5
    58	17:24:32:   ---      1.25   4%   3%   0%   0%   0%   0% 47.0°C  0/5
    59	17:24:33:   ---      1.25   4%   2%   0%   1%   0%   0% 47.0°C  0/5
    60	17:24:33:   ---      1.25   4%   3%   0%   0%   0%   0% 47.0°C  0/5
    61
    62	### resolv.conf
    63
    64	-rw-r--r-- 1 root root 80 May 22 20:39 /etc/resolv.conf
    65	# Generated by NetworkManager
    66	search home
    67	nameserver XXX.XXX.8.8
    68	nameserver XXX.XXX.1.1
    69
    70	### Current sysinfo:
    71
    72	Linux 4.9.255-sun50iw9 (orangepizero2) 	05/23/2022 	_aarch64_	(4 CPU)
    73
    74	avg-cpu:  %user   %nice %system %iowait  %steal   %idle
    75	           0.20    0.00    0.11    0.01    0.00   99.67
    76
    77	Device             tps    kB_read/s    kB_wrtn/s    kB_dscd/s    kB_read    kB_wrtn    kB_dscd
    78	ram0              0.00         0.00         0.00         0.00          0          0          0
    79	ram1              0.00         0.00         0.00         0.00          0          0          0
    80	ram2              0.00         0.00         0.00         0.00          0          0          0
    81	ram3              0.00         0.00         0.00         0.00          0          0          0
    82	ram4              0.00         0.00         0.00         0.00          0          0          0
    83	ram5              0.00         0.00         0.00         0.00          0          0          0
    84	ram6              0.00         0.00         0.00         0.00          0          0          0
    85	ram7              0.00         0.00         0.00         0.00          0          0          0
    86	ram8              0.00         0.00         0.00         0.00          0          0          0
    87	ram9              0.00         0.00         0.00         0.00          0          0          0
    88	ram10             0.00         0.00         0.00         0.00          0          0          0
    89	ram11             0.00         0.00         0.00         0.00          0          0          0
    90	ram12             0.00         0.00         0.00         0.00          0          0          0
    91	ram13             0.00         0.00         0.00         0.00          0          0          0
    92	ram14             0.00         0.00         0.00         0.00          0          0          0
    93	ram15             0.00         0.00         0.00         0.00          0          0          0
    94	mmcblk0           0.20         8.02         1.85         0.00     598969     138500          0
    95	mmcblk0p1         0.20         7.99         1.85         0.00     596865     138500          0
    96	zram0             0.01         0.03         0.00         0.00       2248        128          0
    97	zram1             0.34         0.02         1.34         0.00       1552     100004          0
    98	zram2             0.00         0.00         0.00         0.00          0          0          0
    99
   100	--procs-- -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu--------
   101	   r    b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st
   102	   0    0           44       286612        21616       553836    0    0     2     1   66   94   0   0 100   0   0
   103
   104	               total        used        free      shared  buff/cache   available
   105	Mem:           965Mi       123Mi       280Mi       9.0Mi       561Mi       817Mi
   106	Swap:          482Mi       0.0Ki       482Mi
   107
   108	NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
   109	/dev/zram1 lz4            50M  5.8M 269.2K  716K       4 /var/log
   110	/dev/zram0 lzo         482.6M   48K   2.8K   40K       4 [SWAP]
   111
   112	 17:24:34 up 20:45,  2 users,  load average: 1.23, 1.13, 1.03
   113
   114	[    4.856617] systemd[1]: Listening on initctl Compatibility Named Pipe.
   115	[    4.867022] systemd[1]: Listening on Journal Audit Socket.
   116	[    4.876808] systemd[1]: Listening on Journal Socket (/dev/log).
   117	[    4.886862] systemd[1]: Listening on Journal Socket.
   118	[    4.897062] systemd[1]: Listening on udev Control Socket.
   119	[    4.906722] systemd[1]: Listening on udev Kernel Socket.
   120	[    4.919475] systemd[1]: Mounting Huge Pages File System...
   121	[    4.933119] systemd[1]: Mounting POSIX Message Queue File System...
   122	[    4.945924] systemd[1]: Mounting RPC Pipe File System...
   123	[    4.959837] systemd[1]: Mounting Kernel Debug File System...
   124	[    4.969934] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
   125	[    4.970291] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
   126	[    4.977618] systemd[1]: Starting Restore / save the current clock...
   127	[    4.999016] systemd[1]: Starting Set the console keyboard layout...
   128	[    5.017174] systemd[1]: Starting Create list of static device nodes for the current kernel...
   129	[    5.036676] systemd[1]: Starting Load Kernel Module configfs...
   130	[    5.050067] systemd[1]: Starting Load Kernel Module drm...
   131	[    5.063605] systemd[1]: Starting Load Kernel Module fuse...
   132	[    5.077149] systemd[1]: Started Nameserver information manager.
   133	[    5.090860] systemd[1]: Reached target Network (Pre).
   134	[    5.092961] fuse init (API version 7.26)
   135	[    5.108304] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
   136	[    5.108471] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
   137	[    5.114153] systemd[1]: Starting Load Kernel Modules...
   138	[    5.129970] systemd[1]: Starting Remount Root and Kernel File Systems...
   139	[    5.145557] systemd[1]: Starting Coldplug All udev Devices...
   140	[    5.172584] systemd[1]: Mounted Huge Pages File System.
   141	[    5.180221] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
   142	[    5.182315] WCN: marlin_init entry!
   143	[    5.182990] WCN: wcn config bt wake host
   144	[    5.183639] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
   145	[    5.183764] WCN: wcn config wifi wake host
   146	[    5.183782] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
   147	[    5.187013] sdiohal:sdiohal_init ok
   148	[    5.187508] systemd[1]: Mounted POSIX Message Queue File System.
   149	[    5.187935] WCN: marlin_probe ok!
   150	[    5.200614] systemd[1]: Mounted RPC Pipe File System.
   151	[    5.205017] mtty_probe init device addr: 0xffffffc03b088a00
   152	[    5.205182] -->rfkill_bluetooth_init
   153	[    5.205303] <--rfkill_bluetooth_init
   154	[    5.210478] systemd[1]: Mounted Kernel Debug File System.
   155	[    5.221110] systemd[1]: Finished Restore / save the current clock.
   156	[    5.234468] systemd[1]: Finished Create list of static device nodes for the current kernel.
   157	[    5.254329] WCN: start_marlin [MARLIN_WIFI]
   158	[    5.254342] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
   159	[    5.254346] WCN: the first power on start
   160	[    5.303839] systemd[1]: modprobe@configfs.service: Succeeded.
   161	[    5.304847] systemd[1]: Finished Load Kernel Module configfs.
   162	[    5.318274] systemd[1]: Finished Set the console keyboard layout.
   163	[    5.369360] WCN: marlin chip en pull up
   164	[    5.376936] systemd[1]: modprobe@drm.service: Succeeded.
   165	[    5.377606] systemd[1]: Finished Load Kernel Module drm.
   166	[    5.391050] systemd[1]: modprobe@fuse.service: Succeeded.
   167	[    5.391722] systemd[1]: Finished Load Kernel Module fuse.
   168	[    5.396071] sdiohal:sdiohal_scan_card
   169	[    5.396090] sunxi-wlan soc@03000000:wlan: bus_index: 1
   170	[    5.396212] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
   171	[    5.412683] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   172	[    5.418240] systemd[1]: Finished Remount Root and Kernel File Systems.
   173	[    5.430171] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
   174	[    5.431022] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
   175	[    5.431041] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   176	[    5.433524] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   177	[    5.436560] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   178	[    5.452667] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   179	[    5.463282] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
   180	[    5.464013] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
   181	[    5.464064] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
   182	[    5.464683] mmc1: new ultra high speed SDR104 SDIO card at address 8800
   183	[    5.465101] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
   184	[    5.465178] WCN: marlin_scan_finish!
   185	[    5.465183] sdiohal:probe ok
   186	[    5.465191] sdiohal:scan end!
   187	[    5.465197] WCN: then marlin start to download
   188	[    5.465406] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
   189	[    5.465414] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
   190	[    5.493534] systemd[1]: Mounting FUSE Control File System...
   191	[    5.509832] systemd[1]: Mounting Kernel Configuration File System...
   192	[    5.525623] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
   193	[    5.525981] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
   194	[    5.530375] systemd[1]: Starting Load/Save Random Seed...
   195	[    5.545782] systemd[1]: Starting Create System Users...
   196	[    5.561268] systemd[1]: Mounted FUSE Control File System.
   197	[    5.573956] systemd[1]: Mounted Kernel Configuration File System.
   198	[    5.604219] WCN: combin_img 0 marlin_firmware_write finish and successful
   199	[    5.604544] WCN: marlin_start_run read reset reg val:0x1
   200	[    5.604549] WCN: after do marlin_start_run reset reg val:0x0
   201	[    5.604805] WCN: s_marlin_bootup_time=5604796894
   202	[    5.611486] WCN: clock mode: TSX
   203	[    5.611697] WCN: marlin_write_cali_data sync init_state:0x1a0f50
   204	[    5.612615] systemd[1]: Finished Create System Users.
   205	[    5.627343] systemd[1]: Starting Create Static Device Nodes in /dev...
   206	[    5.636331] WCN: marlin_write_cali_data sync init_state:0x1a0f50
   207	[    5.662939] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
   208	[    5.662949] WCN: sdio_config bt_wake_host trigger:[high]
   209	[    5.662952] WCN: sdio_config irq:[inband]
   210	[    5.662957] WCN: sdio_config wl_wake_host trigger:[high]
   211	[    5.662961] WCN: sdio_config wake_host_level_duration_time:[20ms]
   212	[    5.662964] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
   213	[    5.662968] WCN: marlin_send_sdio_config_to_cp sdio_config:0xb8f01 (enable config)
   214	[    5.663372] WCN: marlin_write_cali_data finish
   215	[    5.663579] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
   216	[    5.686340] systemd[1]: Finished Create Static Device Nodes in /dev.
   217	[    5.689610] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
   218	[    5.697061] systemd[1]: Reached target Local File Systems (Pre).
   219	[    5.716281] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
   220	[    5.733309] systemd[1]: Mounting /tmp...
   221	[    5.742888] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
   222	[    5.749649] systemd[1]: Starting Rule-based Manager for Device Events and Files...
   223	[    5.769647] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
   224	[    5.770873] systemd[1]: Finished Coldplug All udev Devices.
   225	[    5.784044] systemd[1]: Mounted /tmp.
   226	[    5.796279] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
   227	[    5.796289] WCN: marlin_bind_verify confuse data: 0x8badefa1b12bbe26aeffa8d1a5c07
   228	[    5.796305] WCN: marlin_bind_verify verify data: 0xccd7f963c19581907680f88f2044f687
   229	[    5.796862] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
   230	[    5.797757] systemd[1]: Reached target Local File Systems.
   231	[    5.822954] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
   232	[    5.822964] sdiohal:sdiohal_runtime_get entry
   233	[    5.823104] WCN: get_cp2_version entry!
   234	[    5.824768] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
   235	[    5.824888] WCN: switch_cp2_log - close entry!
   236	[    5.826207] WCN: WCND at cmd read:OK
   237	[    5.826270] WCN: then marlin download finished and run ok
   238	[    5.826276] WCN: start_loopcheck
   239	[    5.827116] systemd[1]: Starting Armbian ZRAM config...
   240	[    5.840426] WCN: get_board_ant_num [one_ant]
   241	[    5.840437] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
   242	[    5.840667] systemd[1]: Starting Set console font and keymap...
   243	[    5.859125] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
   244	[    5.873789] systemd[1]: Starting Preprocess NFS configuration...
   245	[    5.907069] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
   246	[    5.908921] systemd[1]: Finished Set console font and keymap.
   247	[    5.921446] systemd[1]: Finished Load Kernel Modules.
   248	[    5.977320] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
   249	[    5.987913] systemd[1]: nfs-config.service: Succeeded.
   250	[    5.988693] systemd[1]: Finished Preprocess NFS configuration.
   251	[    6.000454] systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
   252	[    6.000516] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
   253	[    6.000623] systemd[1]: Reached target NFS client services.
   254	[    6.030730] systemd[1]: Starting Apply Kernel Variables...
   255	[    6.049700] systemd[1]: Started Rule-based Manager for Device Events and Files.
   256	[    6.103096] systemd[1]: Finished Apply Kernel Variables.
   257	[    6.132131] systemd[1]: Starting Raise network interfaces...
   258	[    6.192100] zram: Added device: zram0
   259	[    6.200608] zram: Added device: zram1
   260	[    6.201655] zram: Added device: zram2
   261	[    6.254754] zswap: can't enable, initialization failed
   262	[    6.306875] zram0: detected capacity change from 0 to 506056704
   263	[    6.402817]
   264	               insmod_device_driver
   265
   266	[    6.403106] device_chose finished 124!
   267	[    6.515961] systemd[1]: Reached target Hardware activated USB gadget.
   268	[    6.591407] systemd[1]: Finished Raise network interfaces.
   269	[    6.790414] systemd[1]: Found device /dev/ttyS0.
   270	[    6.931058] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
   271	[    6.947499] systemd[1]: Starting Load/Save RF Kill Switch Status...
   272	[    7.000604] sunxi-bt soc@03000000:bt: set block: 0
   273	[    7.016128] bluetooth_set_power: start_block=0
   274	[    7.016137] WCN: start_marlin [MARLIN_BLUETOOTH]
   275	[    7.016147] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
   276	[    7.016151] WCN: marlin have open, GNSS is closed
   277	[    7.016156] bluetooth_set_power: end_block=0
   278	[    7.150873] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
   279	[    7.151036] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
   280	[    7.151499] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
   281	[    7.152116] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
   282	[    7.152845] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
   283	[    7.153123] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
   284	[    7.261105] systemd[1]: Started Load/Save RF Kill Switch Status.
   285	[    7.346581] Adding 494192k swap on /dev/zram0.  Priority:5 extents:1 across:494192k SSFS
   286	[    7.485186] zram1: detected capacity change from 0 to 52428800
   287	[    7.756135] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
   288	[    7.756235] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
   289	[    7.756622] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
   290	[    7.757018] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
   291	[    7.757321] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
   292	[    7.757455] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
   293	[    9.556794] systemd[1]: Finished Armbian ZRAM config.
   294	[    9.570065] systemd[1]: Starting Armbian memory supported logging...
   295	[    9.641882] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
   296	[   12.268396] systemd[1]: systemd-rfkill.service: Succeeded.
   297	[   15.282963] systemd[1]: Finished Armbian memory supported logging.
   298	[   15.296984] systemd[1]: Starting Journal Service...
   299	[   15.573596] systemd[1]: Started Journal Service.
   300	[   15.619033] systemd-journald[1839]: Received client request to flush runtime journal.
   301	[   15.619755] systemd-journald[1839]: File /var/log/journal/11494a6a697a4f12a9711e32964a6788/system.journal corrupted or uncleanly shut down, renaming and replacing.
   302	[   15.621460] systemd-journald[1839]: Failed to open system journal: No space left on device
   303	[   15.740512] IPVS: Creating netns size=1928 id=1
   304	[   16.464099] nr_pdflush_threads exported in /proc is scheduled for removal
   305	[   16.724723] random: crng init done
   306	[   16.724736] random: 7 urandom warning(s) missed due to ratelimiting
   307	[   29.697950] sunxi-bt soc@03000000:bt: block state already is 0
   308	[   29.697968] bluetooth_set_power: start_block=0
   309	[   29.697973] WCN: start_marlin [MARLIN_BLUETOOTH]
   310	[   29.697982] WCN: marlin power state:5, subsys: [MARLIN_BLUETOOTH] power 1
   311	[   29.697986] WCN: marlin have open, GNSS is closed
   312	[   29.697991] bluetooth_set_power: end_block=0
   313	[   29.761168] IPVS: Creating netns size=1928 id=2
   314	[   29.884477] proc: unrecognized mount option "hidepid=invisible" or missing value
   315	[   29.936605] sunxi->update_param:1
   316	[   29.936683] HDMI Audio Enable Successfully
   317	[   29.996413] mtty_open device success!
   318	[   30.817492] IPVS: Creating netns size=1928 id=3
   319	[   30.984405] proc: unrecognized mount option "hidepid=invisible" or missing value
   320	[   32.270694] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
   321	[   32.271240] yzhang..read phyaddr=0, phyid=001cc916
   322	[   32.281941] yzhang..read phyaddr=1, phyid=001cc916
   323	[   32.295437] libphy: gmac0: probed
   324	[   32.330083] sunxi-gmac gmac0 eth0: eth0: Type(7) PHY ID 001cc916 at 0 IRQ poll (gmac0-0:00)
   325	[   32.341496] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
   326	[   32.408687] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
   327	[   32.792062] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
   328	[   34.683886] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
   329	[   36.150102] raw_flag value is 0
   330	[   36.178343] raw_flag value is 0
   331	[   36.180367] raw_flag value is 0
   332	[   36.182202] raw_flag value is 0
   333	[   36.197017] raw_flag value is 0
   334	[   36.200413] raw_flag value is 0
   335	[   36.201948] raw_flag value is 0
   336	[   36.203373] raw_flag value is 0
   337	[   36.204783] raw_flag value is 0
   338	[   36.206303] raw_flag value is 0
   339	[   36.207939] raw_flag value is 0
   340	[   36.209154] raw_flag value is 0
   341	[   36.210600] raw_flag value is 0
   342	[   36.211938] raw_flag value is 0
   343	[   36.213672] raw_flag value is 0
   344	[   36.214895] raw_flag value is 0
   345	[   36.216306] raw_flag value is 0
   346	[   36.217709] raw_flag value is 0
   347	[   36.234993] raw_flag value is 0
   348	[   36.259542] raw_flag value is 0
   349	[   37.123060] sunxi->update_param:1
   350	[   37.123125] HDMI Audio Enable Successfully
   351	[   38.355236] sunxi->update_param:1
   352	[   38.355304] HDMI Audio Enable Successfully
   353	[   39.578521] sunxi->update_param:1
   354	[   39.578594] HDMI Audio Enable Successfully
   355	[   40.808845] sunxi->update_param:1
   356	[   40.808917] HDMI Audio Enable Successfully
   357	[   57.128009] raw_flag value is 0
   358	[   93.783021] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
   359	[  131.386231] raw_flag value is 0
   360	[  193.872357] raw_flag value is 0
   361	[  237.367284] raw_flag value is 0
   362	[  274.257807] raw_flag value is 0
   363	[16102.393347] IPVS: Creating netns size=1928 id=4
   364
   365
   366
   367	### interrupts:
   368	           CPU0       CPU1       CPU2       CPU3
   369	  3:    2917368    1748198    2473112    1654283  wakeupgen  48 Level     sun4i_timer0
   370	  6:    1267681     292801    1203881     839381     GIC-0  27 Level     arch_timer
   371	  8:          0          0          0          0  wakeupgen  61 Level     30f0000.iommu
   372	151:          0          0          0          0  sunxi_pio_edge 134 Edge      sdc0 cd
   373	193:          0          0          0          0  sunxi_pio_edge 176 Edge      bt_wake_isr
   374	273:        147          0          0          0  wakeupgen  42 Level     3002000.dma-controller
   375	275:          0          0          0          0  wakeupgen 106 Level     RemoteIR_RX
   376	276:          0          0          0          0  wakeupgen 104 Level     rtc
   377	278:          0          0          0          0  wakeupgen  93 Level     cedar_dev
   378	280:        542          0          0          0  wakeupgen   0 Level     uart0
   379	283:          0          0          0          0  wakeupgen   9 Level     twi3
   380	284:      34524          0          0          0  wakeupgen 105 Level     twi5
   381	285:          0          0          0          0  wakeupgen  25 Level     sunxi_usb_udc
   382	288:          2          0          0          0  wakeupgen  28 Level     ehci_hcd:usb1
   383	289:        330          0          0          0  wakeupgen  29 Level     ohci_hcd:usb4
   384	290:          0          0          0          0  wakeupgen  30 Level     ehci_hcd:usb2
   385	291:          0          0          0          0  wakeupgen  31 Level     ohci_hcd:usb5
   386	292:          0          0          0          0  wakeupgen  32 Level     ehci_hcd:usb3
   387	293:          0          0          0          0  wakeupgen  33 Level     ohci_hcd:usb6
   388	294:          0          0          0          0  wakeupgen  12 Level     spi0
   389	295:          0          0          0          0  wakeupgen  13 Level     spi1
   390	298:       2361          0          0      20976  wakeupgen  35 Level     sunxi-mmc0
   391	299:      97901          0          0          0  wakeupgen  36 Level     sunxi-mmc1
   392	300:         37          0          0          0  wakeupgen  88 Level     dispaly
   393	303:    4482846          0          0          0  wakeupgen  66 Level     dispaly
   394	314:          0          0          0          0  wakeupgen  91 Edge      ss
   395	316:          0          0          0          0  wakeupgen  89 Level     1420000.deinterlace
   396	319:          0          0          0          0  wakeupgen  20 Edge      sunxikbd
   397	320:          0          0          0          0  wakeupgen  14 Level     gmac0
   398	IPI0:    191450     179161     416226     263270       Rescheduling interrupts
   399	IPI1:      2823       2876       3836       2938       Function call interrupts
   400	IPI2:         0          0          0          0       CPU stop interrupts
   401	IPI3:    157439     211741     411155     358924       Timer broadcast interrupts
   402	IPI4:    105783      73320     111334      75038       IRQ work interrupts
   403	IPI5:         0          0          0          0       CPU wake-up interrupts
   404	Err:          0
