On 5/30/2022 at 9:21 PM, Chris4arm said:
any hope to have a 5.x server image with support for the M1 bluetooth soon ?
Chris
unfortunately it seems till unsupported in last 5.17 official images :(
Perhaps because due to the lack of /dev/ttyS2 used by BT ?
However it appears in dmesg :
[    3.275178] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 20, base_baud = 1500000) is a 16550A
[    3.275619] serial serial0: tty port ttyS2 registered
What is missing ?
Chris
What is missing ?
Chris
A check of Armbian_22.05.0-trunk_Station-m1_sid_edge_5.18.0_xfce_desktop.img.xz shows same thing.
Looking deeper I see a unit related to bluetooth and it's uart which is dead :
root@station-m1:# systemctl status sys-devices-platform-ff130000.serial-serial0-serial0\x2d0-bluetooth-hci0.device
○ sys-devices-platform-ff130000.serial-serial0-serial0x2d0-bluetooth-hci0.device - /sys/devices/platform/ff130000.serial/serial0/serial0x2d0/bluetooth/hci0
     Loaded: loaded
     Active: inactive (dead)
Try to restart it :
root@station-m1:# systemctl start sys-devices-platform-ff130000.serial-serial0-serial0\x2d0-bluetooth-hci0.device
Job for sys-devices-platform-ff130000.serial-serial0-serial0x2d0-bluetooth-hci0.device timed out.
root@station-m1:/boot/dtb/rockchip# systemctl status sys-devices-platform-ff130000.serial-serial0-serial0\x2d0-bluetooth-hci0.device
     Loaded: loaded
Jun 04 13:57:07 station-m1 systemd[1]: sys-devices-platform-ff130000.serial-serial0-serial0x2d0-bluetooth-hci0.device: Job sys-devices-platform-ff130000.serial-serial0-serial0x2d0-bluetooth-hci0.device/start timed out.
Jun 04 13:57:07 station-m1 systemd[1]: Timed out waiting for device /sys/devices/platform/ff130000.serial/serial0/serial0x2d0/bluetooth/hci0.
Jun 04 13:57:07 station-m1 systemd[1]: sys-devices-platform-ff130000.serial-serial0-serial0x2d0-bluetooth-hci0.device: Job sys-devices-platform-ff130000.serial-serial0-serial0x2d0-bluetooth-hci0.device/start failed with result 'timeout'.
So there is something broken around that unit (dtb ?).
An idea ?
Chris
     Loaded: loaded
Maybe another track around the firmware :
dmesg |egrep -i "RTL|hci0"
[   11.207253] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000d lmp_ver=08 lmp_subver=8723
[   11.211722] Bluetooth: hci0: RTL: rom_version status=0 version=2
[   11.211773] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723ds_fw.bin
[   11.226538] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723ds_config.bin
[   11.262916] Bluetooth: hci0: RTL: cfg_sz 47, total sz 30147
[   13.282610] Bluetooth: hci0: command 0xfc20 tx timeout
[   21.478655] Bluetooth: hci0: RTL: download fw command failed (-110)
the files exist
ls -l /lib/firmware/rtl_bt/rtl8723ds*
-rw-rw-r-- 1 root root    47 May 20 12:25 /lib/firmware/rtl_bt/rtl8723ds_config.bin
-rw-rw-r-- 1 root root 48988 May 20 12:25 /lib/firmware/rtl_bt/rtl8723ds_fw.bin
but the loading fails.
Bad firmware ?
Chris
