best practice - adding a kernel driver as user (eg. CAN-A20 from olimex)
I am not very experienced on the Armbian development and want to add a kernel driver to the legacy kernel using the compile.sh development tool, but did not grasp the best practice to add the kernel source reading some forum posts and docs.
As a start lets add the sunxi-can driver for the Olimex CAN-A20  interface  for legacy kernel for Olimex lime2 A20 board like described in the Wiki at Olimex:
 https://www.olimex.com/wiki/A20-CAN
I did:
a)  http://docs.armbian.com/Developer-Guide_Build-Preparationon an virtual box on my machine
and can successfully build kernel packages and apply user-patches
B) enable some patches like the
 copy /patch/kernel/sun7i-default/0015-sunxi-codec_LL.patch.disabled to user-patches/...
and build new kernel packages for my board and tested it.
To add the driver
a)  cloned the driver source:
 git clone https://github.com/btolfa/sunxi-can-driver.git
So the first questions for best practice:
 1) where to place the source so it is not removed on updates ?
 2) How to change
  linux-sunxi/drivers/net/can/Kconfig and linux-sunxi/drivers/net/can/Makefile ?
 3) How to change the linux config without everytime run the menuconfig and being able to
  update new versions of config file if new kernel arrives ?
mfg
 winfried
3/
copy the ".config" file with the pattern in userpatches folder
I am using
userpatches/linux-sunxi-next.config
userpatches/linux-odroidxu4-next.config
2/
unless better piece of advise, create a patch for the 2 files then put them in userpatches/kernel (?)
1/
idea 1: create a patch with all the source (???)
idea 2: use symlinks ???
 2) How to change
This can be done with a single patch that adds new source files and adds new options to Kconfig and Makefile. Or even better - after you test and confirm that this driver works with your board, this driver can be added to default Armbian kernel since I don't see any CAN related options enabled in our sun7i-default config.
  On 9/23/2016 at 7:05 PM, goldfish_paris said:
3/
I am using
2/
1/
I thought so, but then I saw userpatches/overlay...
It is mentioned it is for the image, but I do not really understand how I can use it, is there an example ?
so I cannot put additional driver source in it.
Ok, I will do so and test beginning next week, when I have access to a CAN bus again and post it here  ?
Thanks for the answers.
  On 9/24/2016 at 3:02 PM, zador.blood.stained said:
You can test this precompiled kernel if you want.
Kernel module is called "sun7i_can"
Thanks again.
This brings me to another question before I go testing tomorrow:
- How to name the packages, for example linux-image ?
If having the same name as the distribution on update it will be overwritten easily.
I want to distribute the kernel debian packages to be installed in the nodes and updated if I update them on server.
Since I apply some patches I also would add this info
like
  "linux-image-sun7i-3.4.112-rt-can_5.20_armhf.deb"
or for koco modules.
  "linux-image-sun7i-koco_5.20_armhf.deb"
Where can I change naming and version numbers of generated debian packages  ?
like
These names are based on variables (i.e. $LINUXFAMILY) in build script, it's not easy to change them. Anyway, if this patch or kernel works for you, I'll just add it to default Armbian kernel, so you don't have to worry about updates or kernel package names.
I guess zador.blood.stain hasn't still changed the variable, I am using SUBREVISION="-GRO" it doesn't rename the debian package but still the tags is changed in dpkg/aptitude so Armbian 5.21 is renamed 5.21-GRO
UPDATE -  CAN Bus didnt work:
  It always hung after some seconds of receiving until we found that it was a electrical problem,
  a non isolated CAN-Bus on another voltage ground.
  Unfortunately we could not finish the tests before return of the vehicle, therefore I cannot confirm the working patch until now.
PS: I will do another try on the CAN-Bus of my Zero E-motorcycle in spring and report.
