Hi!
You can find the armbianmonitor output attached to this thread. The issue is: when I use HDMI audio output with wine applications the entire system freezes very soon, usually after some seconds from the launch of the application. Some fraction of the latest played sound keeps looping very fast and both mouse and keyboard are unresponsive. All I can do is to unplug the power. This happens both on Odroid N2 and Odroid N2+. Everything works fine if I use some bluetooth headphones. And everything works fine if I use HDMI audio output with linux native applications. The problem is in the combination of Wine applications and HDMI audio output.
Armbian Monitor Output.txt
