thelaw Posted October 2, 2016 Posted October 2, 2016 Hello everyone, I am kinda of new to the orange, I think it's fantastic, I worked with rasp for while and I think the orange just slashes it. Pampering the orange aside, I am trying to hook up an old webcam to the Orange pi lite and I running into some issue, my lsusb info is this: Bus 003 Device 002: ID 1e4e:0100 Cubeternet WebCam When I start motion, everything works fine, although when I go on the browser a gray screen comes up saying: unable to open video device I have changed the configuration file of /etc/motion/motion.conf and /etc/default/motion as instructed here: http://www.orangepi.org/Docs/Webcams.html Plus I have changed the with my ip and removed the semicolin netcam_url I changed so I can connect localhost:off I have tried everything on the net to make it work, it just doesn't, I have even changed multiple cameras that I do know for sure work, but nothing, I don't know what I am doing wrong. Update: The webcam seems to run with mplayer Now motion does not even stream anymore, I did not change anything or touched it FIY I think this is obvious I am running armbian Thanks 1
MacBreaker Posted October 2, 2016 Posted October 2, 2016 Hello thelaw, i was playing around with raspberry pi and motion, but i this was not good. I changed to "mjpg_streamer" with much more success. Now i use mjpg_streamer on three H3 oranges. Try this as root: apt-get install subversion-tools libcairo2-dev libjpeg62-turbo-dev libpango1.0-dev libgif-dev build-essential g++ imagemagick v4l-utils svn co https://svn.code.sf.net/p/mjpg-streamer/code/mjpg-streamer mjpg-streamer cd mjpg-streamer make make install Test: sudo mjpg_streamer -i "/usr/local/lib/input_uvc.so -d /dev/video0 -n -y -r 640x480 -f 15" -o "/usr/local/lib/output_http.so -n -w /usr/local/www -p 8080" You can view at: http://yourdevice:8080/?action=stream If you need more information, just ask... Markus
thelaw Posted October 2, 2016 Author Posted October 2, 2016 Hello thelaw, i was playing around with raspberry pi and motion, but i this was not good. I changed to "mjpg_streamer" with much more success. Now i use mjpg_streamer on three H3 oranges. Try this as root: apt-get install subversion-tools libcairo2-dev libjpeg62-turbo-dev libpango1.0-dev libgif-dev build-essential g++ imagemagick v4l-utils svn co https://svn.code.sf.net/p/mjpg-streamer/code/mjpg-streamer mjpg-streamer cd mjpg-streamer make make install Test: sudo mjpg_streamer -i "/usr/local/lib/input_uvc.so -d /dev/video0 -n -y -r 640x480 -f 15" -o "/usr/local/lib/output_http.so -n -w /usr/local/www -p 8080" You can view at: http://yourdevice:8080/?action=stream If you need more information, just ask... Markus OH MAN! Thank you so much, it did it! Thank you thank you! I was struggling with this so much!
thelaw Posted October 2, 2016 Author Posted October 2, 2016 Wait though how do you change the password and username to access it? Sorry for the noob question
MacBreaker Posted October 3, 2016 Posted October 3, 2016 If i understand right, you like to password protect the stream?use this: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/input_uvc.so -d /dev/video0 -n -r 640x480 -f 25" -o "/usr/local/lib/output_http.so -n -w /usr/local/www -p 8080 -c user:pass" user:pass = username and password. I use mjpg_streamer this way:1. install2. move to /opt mv /root/mjpg-streamer /opt/ 3. make start/stop skript sudo nano /etc/init.d/mjpg_streamer #!/bin/sh # /etc/init.d/mjpg_streamer # # Creation: 04.02.2013 # Last Update: 04.02.2013 # # Written by Georg Kainzbauer (http://www.gtkdb.de) # ### BEGIN INIT INFO # Provides: mjpg_streamer # Required-Start: $all # Required-Stop: $all # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: MJPG-Streamer # Description: MJPG-Streamer takes JPGs from Linux-UVC compatible webcams and streams them as M-JPEG via HTTP. ### END INIT INFO start() { echo "Starting mjpg-streamer..." # /usr/local/bin/mjpg_streamer -i "/usr/local/lib/input_uvc.so -d /dev/video0 -n -y -r 640x480 -f 10" -o "/usr/local/lib/output_http.so -n -w /usr/local/www -p 8080" >/dev/null 2>&1 & /usr/local/bin/mjpg_streamer -i "/usr/local/lib/input_uvc.so -d /dev/video0 -n -r 640x480 -f 25" -o "/usr/local/lib/output_http.so -n -w /usr/local/www -p 8080" >/dev/null 2>&1 & } stop() { echo "Stopping mjpg-streamer..." kill -9 $(pidof mjpg_streamer) >/dev/null 2>&1 } case "$1" in start) start ;; stop) stop ;; restart) stop start ;; *) echo "Usage: $0 {start|stop|restart}" ;; esac exit 0 3. make it executable sudo chmod 0755 /etc/init.d/mjpg_streamer 4. add to autostart update-rc.d mjpg_streamer defaults 5. reboot Hint:If your webcam support "MJPG" you can remove the "-y"-Flag, this will save a lot CPU load. (you can check with "htop") With v4l2-ctl --list-formats-ext all formats and sizes of the connected cam will be listed. Hint2:If you use kernel 4.x.x you have to patch mjpg_streamer, because mjpg don`t work. Have fun...Markus
thelaw Posted October 4, 2016 Author Posted October 4, 2016 If i understand right, you like to password protect the stream? use this: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/input_uvc.so -d /dev/video0 -n -r 640x480 -f 25" -o "/usr/local/lib/output_http.so -n -w /usr/local/www -p 8080 -c user:pass" user:pass = username and password. I use mjpg_streamer this way: 1. install 2. move to /opt mv /root/mjpg-streamer /opt/ ...... Have fun... Markus The pass command change does not work, I even tried to modify the file but's it's all encrypted, here is the error message when I put in the command: MJPG Streamer Version: svn rev: 3:172 i: Using V4L2 device.: /dev/video0 i: Desired Resolution: 640 x 480 i: Frames Per Second.: 25 i: Format............: MJPEG Unable to set format: 1196444237 res: 640x480 Init v4L2 failed !! exit fatal i: init_VideoIn failed root@orangepilite:~# mjpg_streamer MJPG Streamer Version: svn rev: 3:172 ERROR: could not find output plugin output_http.so Perhaps you want to adjust the search path with: # export LD_LIBRARY_PATH=/path/to/plugin/folder dlopen: output_http.so: cannot open shared object file: No such file or directory root@orangepilite:~# /usr/local/bin/mjpg_streamer -i "/usr/local/lib/input_uvc.so -d /dev/video0 -n -r 640x480 -f 25" -o "/usr/local/lib/output_http.so -n -w /usr/local/www -p 8080 -c myusr:mypass" MJPG Streamer Version: svn rev: 3:172 i: Using V4L2 device.: /dev/video0 i: Desired Resolution: 640 x 480 i: Frames Per Second.: 25 i: Format............: MJPEG Unable to set format: 1196444237 res: 640x480 Init v4L2 failed !! exit fatal i: init_VideoIn failed I tried to export it by the way, still the same Btw the script does not work
MacBreaker Posted October 4, 2016 Posted October 4, 2016 Hello thelaw,ok, run sudo v4l2-ctl --list-formats-ext and take a look at the output.If theres only written: ioctl: VIDIOC_ENUM_FMT Index : 0 Type : Video Capture Pixel Format: 'YUYV' Name : YUV 4:2:2 (YUYV) the camera only support "YUYV" format. Than you have to run the script with "-f"-flag like this: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/input_uvc.so -d /dev/video0 -n -f -r 640x480 -f 25" -o "/usr/local/lib/output_http.so -n -w /usr/local/www -p 8080" >/dev/null 2>&1 & If you can find: Index : 1 Type : Video Capture Pixel Format: 'MJPG' (compressed) Name : MJPEG everthing is fine without "-f". I read Unable to set format: 1196444237 res: 640x480 Init v4L2 failed !! exit fatal i: init_VideoIn failed this means that someting is wrong with the resolution 640x480 on your cam.You can find the right resolution on the output of "sudo v4l2-ctl --list-formats-ext" Try this: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/input_uvc.so -d /dev/video0 -n -f -r 320x240 -f 25" -o "/usr/local/lib/output_http.so -n -w /usr/local/www -p 8080" >/dev/null 2>&1 & What type of cam do you have? I run a Logitech C170 (cheap cam), Microsoft LifeCam HD-3000 and Microsoft LifeCam Cinema with 'MJPG' without problems. Markus
thelaw Posted October 6, 2016 Author Posted October 6, 2016 Hello thelaw, ok, run sudo v4l2-ctl --list-formats-ext and take a look at the output. If theres only written: ioctl: VIDIOC_ENUM_FMT Index : 0 Type : Video Capture Pixel Format: 'YUYV' Name : YUV 4:2:2 (YUYV) the camera only support "YUYV" format. Than you have to run the script with "-f"-flag like this: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/input_uvc.so -d /dev/video0 -n -f -r 640x480 -f 25" -o "/usr/local/lib/output_http.so -n -w /usr/local/www -p 8080" >/dev/null 2>&1 & If you can find: Index : 1 Type : Video Capture Pixel Format: 'MJPG' (compressed) Name : MJPEG everthing is fine without "-f". I read Unable to set format: 1196444237 res: 640x480 Init v4L2 failed !! exit fatal i: init_VideoIn failed this means that someting is wrong with the resolution 640x480 on your cam. You can find the right resolution on the output of "sudo v4l2-ctl --list-formats-ext" Try this: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/input_uvc.so -d /dev/video0 -n -f -r 320x240 -f 25" -o "/usr/local/lib/output_http.so -n -w /usr/local/www -p 8080" >/dev/null 2>&1 & What type of cam do you have? I run a Logitech C170 (cheap cam), Microsoft LifeCam HD-3000 and Microsoft LifeCam Cinema with 'MJPG' without problems. Markus I run a cheap chinese "no name" camera, it's a 5megapixels although how do I set the pass it do you have a fix for that? I have tried everything in the last 2 days
MacBreaker Posted October 6, 2016 Posted October 6, 2016 Hi,sorry, but this way i cannot help you.Run /usr/local/bin/mjpg_streamer -i "/usr/local/lib/input_uvc.so -d /dev/video0 -n -f -r 320x240 -f 25" -o "/usr/local/lib/output_http.so -n -w /usr/local/www -p 8080" and copy the contents of the terminal.Post it here, also the output of: v4l2-ctl --list-formats-ext
