Odroid-N2 / Armbian 22.05 / nextcloudpi /external Disks
NOBL
Hi
I had to upgrade my Odroid N2 from Armbian Buster to Armbian Bullseye to run newer versions of Nextcloudpi (24.x).
So I did the upgrade by writing the Armbian 22.05 version to the eMMC and started Armbian.
Works fine.
Then I installed a fresh nextcloudpi (23.0.2) which is the same version I used on Armbian Buster.
Works fine. I added the external disks (ncdata und ncbackup). After a restore of my nextcloudpi backup everything was well.
But the next reboot did nothing, i.e. no output on the HDMI Interface, nothing.
So, I did a power-off and looked at the eMMC via a Micro-SD adapter I have.
Of course, no logs, nothing.
Of course, there are no logs in /var/log because of the /dev/zram1 mounted at /var/log.
Mounting /dev/zram1 on /var/log might be good if everything works, but if a reboot fails,
you are host.
I found a work-around: disable apache2 startup by editing the systemd unit file - I couldn't use systemctl
because the system did not boot.
After plugging in the external disks (nc-automount was enabled) and correcting the unit file, I could start
apache2 and nextcloudpi is running well - until the next reboot.
So, how do I disable the mount of /dev/zram1 to /var/log to find the real culprit ?
Is it sufficient to delay the start of apache2 by adding
      ExecStartPre=/bin/sleep 30
Thanks for your advice.
Kind regards
Norbert
Edited by NOBL
several typos
Link to comment
Share on other sites
  • NOBL changed the title to Odroid-N2 / Armbian 22.05 / nextcloudpi /external Disks
It does not just reboot automatically, but it crashes after a few hours of use.
In addition it automaticall shuts down after a while.
I am sick of opening the case, remove the eMMC, put it on the Micro-SD adapter, put it into the Micro-SD slot on my computer, edit the apache2 startup script, put the eMMC back on board
and start the Odroid N2 again and repeat this several times a day.
OK, I'll try to figure out myself how to stop using /dev/zram1 as /var/log.
Link to comment
