smiles Posted July 17, 2022 Posted July 17, 2022 I flashed my espressobin v5 with flash-image-DDR4-1g_1cs_5-1000_800.bin Quote TIM-1.0 mv_ddr-devel-g251bc63 DDR4 16b 1GB 1CS TIM-1.0 mv_ddr-devel-g251bc63 DDR4 16b 1GB 1CS NOTICE: Booting Trusted Firmware NOTICE: BL1: v1.3(release):armada-17.06.2:a37c108 NOTICE: BL1: Built : 14:30:53, Jul 5 2 NOTICE: BL2: v1.3(release):armada-17.06.2:a37c108 NOTICE: BL2: Built : 14:30:55, Jul 5 20 NOTICE: BL31: v1.3(release):armada-17.06.2:a37c108 NOTICE: BL31: U-Boot 2017.03-armada-17.06.3-ga33ecb8 (Jul 05 2017 - 14:30:47 +0800) Model: Marvell Armada 3720 Community Board ESPRESSOBin CPU @ 1000 [MHz] L2 @ 800 [MHz] TClock @ 200 [MHz] DDR @ 800 [MHz] DRAM: 1 GiB U-Boot DComphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link down MMC: sdhci@d0000: 0 SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB After the boot it tries to boot from a network source instead of sdcard. printenv Quote baudrate=115200 boot_targets=usb sata mmc1 mmc0 bootargs=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 root=/dev/nfs rw ip=10.10.10.4:10.10.10.4:10.10.10.1:255.255.255.0:marvell:eth0:none nfsroot=10.10.10.4:/srv/nfs/ bootcmd=run get_images; run set_bootargs; booti ${kernel_addr} ${ramfs_addr} ${fdt_addr} bootdelay=2 console=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 ethact=neta@30000 ethprime=eth0 fdt_addr=0x1000000 fdt_high=0xffffffffffffffff fdt_name=fdt.dtb fdtcontroladdr=3fb1a7c8 gatewayip=10.10.10.1 get_images=tftpboot ${kernel_addr} ${image_name}; tftpboot ${fdt_addr} ${fdt_name}; run get_ramfs get_ramfs=if test "${ramfs_name}" != "-"; then setenv ramfs_addr 0x3000000; tftpboot ${ramfs_addr} ${ramfs_name}; else setenv ramfs_addr -;fi hostname=marvell image_name=Image initrd_addr=0xa00000 initrd_size=0x2000000 ipaddr=10.10.10.4 kernel_addr=0x2000000 loadaddr=0x2000000 netdev=eth0 netmask=255.255.255.0 ramfs_addr=- ramfs_name=- root=root=/dev/nfs rw rootpath=/srv/nfs/ serverip=10.10.10.4 set_bootargs=setenv bootargs ${console} ${root} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}:${netdev}:none nfsroot=${serverip}:${rootpath} ${extra_params} stderr=serial@12000 stdin=serial@12000 stdout=serial@12000 I dont know how it got to this point all I want now is to be able to boot from sdcard. Any thoughts or ideas? 0 Quote
Solution smiles Posted July 27, 2022 Author Solution Posted July 27, 2022 I figure it out. env default -a then saveenv got it back to a state I could boot it from sdcard. 0 Quote
ManoftheSea Posted August 5, 2022 Posted August 5, 2022 Glad to hear it. I'm not sure how you had the old environment that only attempted tftpboot; but I'm glad "restore defaults" remains a good fix. 0 Quote
