Armbianmonitor-U
http://ix.io/450c
MPV broken (does not play video anymore)...might or might not be related to the last apt update/upgrade I did ?
Any hints would be much appreciated...thanks
MPV output:
$ mpv
[osc] Lua error: bad light userdata pointer
[ytdl_hook] Lua error: bad light userdata pointer
[ytdl_hook] Could not load lua script @ytdl_hook.lua
[osc] Could not load lua script @osc.lua
[stats] Lua error: bad light userdata pointer
[stats] Could not load lua script @stats.lua
[console] Lua error: bad light userdata pointer
[console] Could not load lua script @console.lua
[auto_profiles] Lua error: bad light userdata pointer
[auto_profiles] Could not load lua script @auto_profiles.lua
mpv 0.34.0-380-gad5a1ac873 Copyright © 2000-2022 mpv/MPlayer/mplayer2 projects
built on Thu Jul 21 15:02:41 NZST 2022
FFmpeg library versions:
  libavutil       57.30.100
  libavcodec      59.39.100
  libavformat     59.29.100
  libswscale      6.8.101
  libavfilter     8.46.100
  libswresample   4.8.100
FFmpeg version: N-107453-g15785e044e
Usage:   mpv [options] [url|path/]filename
Basic options:
--start=<time>    seek to given (percent, seconds, or hh:mm:ss) position
--no-audio        do not play sound
--no-video        do not play video
--fs              fullscreen playback
--sub-file=<file> specify subtitle file to use
--playlist=<file> specify playlist file
--list-options    list all mpv options
--h=<string>      print options which contain the given string in their name
