JMSKK Posted August 2, 2022 Posted August 2, 2022 I have a question or at last 2. 1.Where to connect outside diode to thinkerboard . 2.How to turn off/on it from command line.
JMSKK Posted August 2, 2022 Author Posted August 2, 2022 23 minutes ago, JMSKK said: Question: How to turn off VCC5V pin 4 or 2 with console line?
TonyMac32 Posted August 5, 2022 Posted August 5, 2022 Are you trying to power the board via the GPIO? I don't think there is a GPIO to shut off the 5V pins from within the board itself.
JMSKK Posted August 8, 2022 Author Posted August 8, 2022 Nope i power it by USB type-B but i power the diod frop gpio pin 4 and 6 and i want to turn of power in pin 4 or 6 to turn it off
JMSKK Posted August 8, 2022 Author Posted August 8, 2022 Nope i power it by USB type-B but i power the diod from gpio pin 4 and 6 and i want to turn of power in pin 4 or 6 to turn it off (what i want to do is to power supply diode that i conect to thinkerboard via pin 4 and 6 and i want to make it trun off and on after some time (like for scanner (flashing diode = = scanning etc)) )
