Urmas Posted August 14, 2022 Posted August 14, 2022 I'm trying to build Armbian desktop image in 64-bit uBuntu and it does not complete. When I build the server it completed nicely no problems. Displaying message: Adding APT Source deb [signed-by=/usr/share/keyrings/githubcli.gpg] http://cli.github.com/packages stable main Displaying message: Adding GPG Key /home/hydra/armbian/config/desktop/_all_distributions/appgroups/programming/sources/apt/githubcli.gpg Displaying message: Updating package list bullseye info Displaying message: Upgrading base packages Armbian info Displaying message: Installing the main packages for Armbian info Displaying message: Installing the desktop packages for Armbian info Displaying message: ERROR in function create_rootfs_cache main.sh:588 -> main.sh:549 -> debootstrap.sh:58 -> debootstrap.sh:302 -> general.sh:0 err Displaying message: Installation of Armbian desktop packages for current bananapim2zero bullseye browsers desktop_tools internet programming remote_desktop mate no failed err Displaying message: Process terminated info Displaying message: unmount_on_exit() called! main.sh:1 -> image-helpers.sh:0 err Displaying message: Unmounting /home/hydra/armbian/.tmp/rootfs-d884b109-2ff2-40c1-8555-3789db75a095/ info Displaying message: ERROR in function unmount_on_exit main.sh:1 -> image-helpers.sh:94 -> general.sh:0 err Displaying message: debootstrap-ng was interrupted err Displaying message: Process terminated info Could you point out what missing or what I doing wrong.
TRS-80 Posted August 15, 2022 Posted August 15, 2022 I had some problems trying to build today and last night as well, could not retrieve release file(s) from mirrors. Your errors look very similar to mine, not sure if related or not.
Solution Urmas Posted August 17, 2022 Author Solution Posted August 17, 2022 (edited) before doing that you may need to restart your router somehow I couldn't update and make sure your firewall is disabled. I got around of it making uBuntu server and then upgrate, then installing desktop separately. I personally like kde. sudo apt install xserver-xorg sudo apt-get install task-lxde-desktop /** sudo apt install mate-desktop-environment-core ***/ sudo apt install lightdm sudo apt install lightdm-gtk-greeter Edited August 17, 2022 by Urmas
TRS-80 Posted August 18, 2022 Posted August 18, 2022 10 hours ago, Urmas said: I got around of it making uBuntu server and then upgrate, then installing desktop separately. Yeah, this way also occurred to me today. Great minds think alike, I guess. Thanks for hints.
