hiya folks! I have a no-brand (MK - 918?) RK3188  Android TV box that I'm trying to install Armbian, but I can't get it to boot Multiboot nor the Armbian image from the SD card. I have tried different SD cards and USB sticks, I am burning the Multitool image with balenaEtcher, but no luck, it boots straight to Android. I have also tried the solution posted by fabiobassa
but the program gets stuck on "Downloading bootloader...". here's some more info:
➜ lsusb
Bus 001 Device 009: ID 2207:310b Fuzhou Rockchip Electronics Company RK3188 in Mask ROM mode
➜ sudo ./rkdeveloptool ld
DevNo=1    Vid=0x2207,Pid=0x310b,LocationID=102    Loader
➜ sudo ./rkdeveloptool rd 3
Reset Device OK.
DevNo=1    Vid=0x2207,Pid=0x310b,LocationID=102    Maskrom
➜ sudo ./rkdeveloptool db MiniLoaderAll.bin
it gets stuck there no matter how long I wait.
also, I have soldered the UART debug connections and here is the output I get when it boots to its default Android:
DDR Version 1.04 20140217
In
DDR3
300MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=8 Size=2048MB
Memory OK
OUT
BUILD=====2
No.1 FLASH ID:2c 64 44 4b a9 0
OK! 214381
unsigned!
SecureBootEn = 0 0
Boot ver: 2014-03-03#2.13
start_linux=====219791
 729482 Starting kernel...@0x60408000
Uncompressing Linux... done, booting the kernel.
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.0.36+ (wasser19641@gmail.com) (gcc version 4.7 (GCC) ) #306 SMP PREEMPT Sun Oct 12 11:26:31 CEST 2014
[    0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: RK30board
[    0.000000] ddr size = 2048 M, set ion_reserve_size size to 125829120
[    0.000000] memory reserve: Memory(base:0x98800000 size:120M) reserved for <ion>
[    0.000000] memory reserve: Memory(base:0x97000000 size:24M) reserved for <fb0 buf>
[    0.000000] memory reserve: Total reserved 144M
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] bootconsole [earlycon0] enabled
[    0.000000] CPU SRAM: copied sram code from c0f19000 to fef00100 - fef020c0
[    0.000000] CPU SRAM: copied sram data from c0f1afc0 to fef020c0 - fef029e4
[    0.000000] sram_log:   @      0q   @       P    1      /  !    aB@ 2   `" 2q    : 4q
[    0.000000] CLKDATA_MSG: pll_flag = 0x03
[    0.000000] cpll auto set rate error
[    0.000000] L310 cache controller enabled
[    0.000000] l2x0: 16 ways, CACHE_ID 0x4100c0c8, AUX_CTRL 0x76050001, Cache size: 524288 B
[    0.000000] DDR DEBUG: version 1.00 20131106
[    0.000000] DDR DEBUG: DDR3 Device
[    0.000000] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Total Capability=2048MB
[    0.000000] DDR DEBUG: init success!!! freq=300MHz
[    0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=1 extra clock, DGPS=90
[    0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[    0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb
[    0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[    0.000000] PERCPU: Embedded 7 pages/cpu @c315d000 s6976 r8192 d13504 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 483328
[    0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00150000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00006000@0x00004000(
kernel),0x00006000@0x0000a000(boot),0x00010000@0x00010000(recovery),0x00020000@0x00020000(backup),0x00040000@0x00040000(cache),0x00002000@0x00080000(metadata),0x00002000@0x00082000(kpanic),0
x00272000@0x00084000(system),-@0x002F6000(userdata) bootver=2014-03-03#2.13 firmware_ver=4.4.2
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 880MB 1024MB = 1904MB total
[    0.000000] Memory: 1901376k/1901376k available, 195776k reserved, 1449984K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xff600000 - 0xffe00000   (   8 MB)
[    0.000000]     vmalloc : 0xdf000000 - 0xfe800000   ( 504 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xde800000   ( 488 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .init : 0xc0408000 - 0xc062f000   (2204 kB)
[    0.000000]       .text : 0xc062f000 - 0xc0e840a4   (8533 kB)
[    0.000000]       .data : 0xc0e86000 - 0xc0f18b28   ( 587 kB)
[    0.000000]        .bss : 0xc0f1c024 - 0xc194e328   (10441 kB)
[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:352
[    0.000000] rk30_gpio_init: 128 gpio irqs in 4 banks
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] rk_timer: version 1.3
[    0.003739] Calibrating delay loop (skipped) preset value.. 1583.48 BogoMIPS (lpj=7917420)
[    0.012874] pid_max: default: 32768 minimum: 301
[    0.018146] Security Framework initialized
[    0.022778] Mount-cache hash table entries: 512
[    0.028362] Initializing cgroup subsys debug
[    0.033124] Initializing cgroup subsys cpuacct
[    0.038099] Initializing cgroup subsys memory
[    0.042972] Initializing cgroup subsys freezer
[    0.047945] CPU: Testing write buffer coherency: ok
[    0.134208] CPU1: Booted secondary processor
[    0.174205] CPU2: Booted secondary processor
[    0.214201] CPU3: Booted secondary processor
[    0.214239] Brought up 4 CPUs
[    0.231840] SMP: Total of 4 processors activated (6333.93 BogoMIPS).
[    0.239190] devtmpfs: initialized
[    0.249141] NET: Registered protocol family 16
[    0.254488] DVFS MSG:        AVS Value(index=0): 128 128 128 128 128 128 127 127 127 128
[    0.273374] lcdc0 is used as external display device contoller!
[    0.279957] lcdc1 is used as primary display device controller!
[    0.386728] rk29sdk_wifi_bt_gpio_control_init: init finished
<hit enter to activate fiq debugger>
    0.394297] console [ttyFIQ0] enabled, bootconsole disabled
[    0.394297] console [ttyFIQ0] enabled, bootconsole disabled
[    0.403307] Registered FIQ tty driver de0adc00
[    0.403891] Loaded driver for PL330 DMAC-1 rk29-pl330
[    0.403906]  DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    0.404054] Loaded driver for PL330 DMAC-2 rk29-pl330
[    0.404068]  DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14
[    0.435947] bio: create slab <bio-0> at 0
[    0.440353] SCSI subsystem initialized
[    0.440538] usbcore: registered new interface driver usbfs
[    0.440629] usbcore: registered new interface driver hub
[    0.454906] usbcore: registered new device driver usb
[    0.455280] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter
[    0.455500] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
[    0.455666] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
[    0.455769] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter
[    0.455871] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter
[    0.486460] rk30-adc rk30-adc: rk30 adc: driver initialized
[    0.486529] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[    0.486695] rk29-wdt rk29-wdt.0: starting watchdog timer
[    0.486933] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.487339] Bluetooth: Core ver 2.16
[    0.487390] NET: Registered protocol family 31
[    0.487401] Bluetooth: HCI device and connection manager initialized
[    0.487416] Bluetooth: HCI socket layer initialized
[    0.487428] Bluetooth: L2CAP socket layer initialized
[    0.487452] Bluetooth: SCO socket layer initialized
[    0.488489] rk fb probe ok!
[    0.493184] act8846_set_init,line=17
[    0.493196] act8846_set_init:g_pmic_type=3
[    0.494867] act8846_set_init  act_dcdc1 =1200000mV end
[    0.496622] act8846_set_init  vdd_core =1000000mV end
[    0.498373] act8846_set_init  vdd_cpu =1000000mV end
[    0.500123] act8846_set_init  act_dcdc4 =3300000mV end
[    0.501277] act8846_set_init  act_ldo1 =1000000mV end
[    0.502928] act8846_set_init  act_ldo2 =1200000mV end
[    0.504580] act8846_set_init  act_ldo3 =1800000mV end
[    0.506231] act8846_set_init  act_ldo4 =3300000mV end
[    0.507881] act8846_set_init  act_ldo5 =3300000mV end
[    0.509530] act8846_set_init  act_ldo6 =3300000mV end
[    0.510581] act8846_set_init  act_ldo7 =1800000mV end
[    0.512230] act8846_set_init  act_ldo8 =2800000mV end
[    0.512248] act8846_set_init,line=78 END
[    0.512293] i2c-core: driver [act8846] using legacy suspend method
[    0.512305] i2c-core: driver [act8846] using legacy resume method
[    0.512345] rk1000_control_probe
[    0.537236] rk1000_control_probe ok
[    0.537296] Switching to clocksource rk_timer
[    0.543569] Switched to NOHz mode on CPU #0
[    0.544242] Switched to NOHz mode on CPU #3
[    0.544249] Switched to NOHz mode on CPU #1
[    0.544257] Switched to NOHz mode on CPU #2
[    0.544596] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xdf02c000
[    0.544638] fb0:win0
[    0.544641] fb1:win1
[    0.544644] fb2:win2
[    0.544702] rk3188 lcdc1 clk enable...
[    0.569778] rk3188 lcdc1 clk disable...
[    0.628074] fb0:phy:97000000>>vir:e0000000>>len:0x1800000
[    0.628315] rk_fb_register>>>>>fb0
[    0.628609] rk_fb_register>>>>>fb1
[    0.661086] rk3188 lcdc1 probe ok!
[    0.661161] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xdf040000
[    0.661212] fb0:win0
[    0.661215] fb1:win1
[    0.661218] fb2:win2
[    0.661282] rk3188 lcdc0 clk enable...
[    0.686354] rk3188 lcdc0 clk disable...
[    0.686370] fb2:phy:97000000>>vir:e0000000>>len:0x1800000
[    0.686599] rk_fb_register>>>>>fb2
[    0.686890] rk_fb_register>>>>>fb3
[    0.686902] rk3188 lcdc0 probe ok!
[    0.724681] cfg80211: Calling CRDA to update world regulatory domain
[    0.747766] IT66121 probe success.
[    0.751140] NET: Registered protocol family 2
[    0.751258] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.751566] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.752541] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.753961] TCP: Hash tables configured (established 65536 bind 65536)
[    0.753974] TCP reno registered
[    0.753986] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.754011] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.754284] NET: Registered protocol family 1
[    0.802608] RPC: Registered named UNIX socket transport module.
[    0.802625] RPC: Registered udp transport module.
[    0.802634] RPC: Registered tcp transport module.
[    0.802644] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.802808] Unpacking initramfs...
[    0.868861] Freeing initrd memory: 1344K
[    0.868953] PMU: registered new PMU device of type 0
[    0.869065] efuse_version_val: efuse version = 51
[    0.869080] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 17000
[    0.869094]          adjust table freq=1608000 KHz, index=1350000 mV to index=1250000 mV
[    0.869109] efuse_version_val: efuse version = 51
[    0.869120] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 17000
[    0.869942] cpufreq: delete arm freq(1608000)
[    0.913975] rk3188 cpufreq version 2.2, suspend freq 816 MHz
[    0.914192] vpu: power on
[    0.914240] VPU_SERVICE: checking hw id 4831
[    0.926842] vpu: power off...done
[    0.926878] VPU_SERVICE: init success
[    0.927132] audit: initializing netlink socket (disabled)
[    0.927169] type=2000 audit(0.860:1): initialized
[    0.944065] highmem bounce pool size: 64 pages
[    0.944244] ashmem: initialized
[    0.954959] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.955209] NTFS driver 2.1.30 [Flags: R/W].
[    0.955369] fuse init (API version 7.16)
[    0.970386] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.970398] io scheduler noop registered
[    0.970404] io scheduler deadline registered
[    0.970448] io scheduler cfq registered (default)
[    0.990722] rga: Driver loaded succesfully
[    0.990848] rk_serial.c v1.6 2013-12-23
[    0.990907] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0
[    0.990993] rk_serial rk_serial.0: membase 0xdf048000
[    0.991038] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
[    0.991124] rk_serial rk_serial.3: membase 0xdf050000
[    0.991276] Rockchip ion module(version: 1.0) is successfully loaded
[    0.992798] loop: module loaded
[    0.992827] Android kernel panic handler initialized (bind=kpanic)
[    0.993272] PPP generic driver version 2.4.2
[    0.993361] PPP Deflate Compression module registered
[    0.993368] PPP BSD Compression module registered
[    1.053173] PPP MPPE Compression module registered
[    1.053184] NET: Registered protocol family 24
[    1.053193] tun: Universal TUN/TAP device driver, 1.6
[    1.053198] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.053354] usbcore: registered new interface driver sr9700_android
[    1.053372] Rockchip WiFi SYS interface (V1.00) ...
[    1.053403] Initializing USB Mass Storage driver...
[    1.053445] usbcore: registered new interface driver usb-storage
[    1.053452] USB Mass Storage support registered.
[    1.053528] usbcore: registered new interface driver usbserial
[    1.053553] USB Serial support registered for generic
[    1.053581] usbcore: registered new interface driver usbserial_generic
[    1.053588] usbserial: USB Serial Driver core
[    1.053609] USB Serial support registered for GSM modem (1-port)
[    1.053640] usbcore: registered new interface driver option
[    1.053646] option: v0.7.2:USB Driver for GSM modems
[    1.053668] USB Serial support registered for usi-modem
[    1.053701] usbcore: registered new interface driver usi-modem
[    1.275256] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
[    1.275274] usb20_otg usb20_otg: DWC OTG Controller
[    1.275362] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
[    1.275389] usb20_otg usb20_otg: irq 48, io mem 0x00000000
[    1.275418] DWC_OTG: Init: Port Power? op_state=1
[    1.275424] DWC_OTG: Init: Power Port (0)
[    1.275467] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.275476] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.275484] usb usb1: Product: DWC OTG Controller
[    1.275491] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd
[    1.275497] usb usb1: SerialNumber: usb20_otg
[    1.275749] hub 1-0:1.0: USB hub found
[    1.275763] hub 1-0:1.0: 1 port detected
[    1.278310] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xdf100000
[    1.488642] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
[    1.488663] usb20_host usb20_host: DWC OTG Controller
[    1.488690] usb20_host usb20_host: new USB bus registered, assigned bus number 2
[    1.488718] usb20_host usb20_host: irq 49, io mem 0x00000000
[    1.488758] DWC_OTG: Init: Port Power? op_state=1
[    1.488764] DWC_OTG: Init: Power Port (0)
[    1.488797] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.488806] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.488814] usb usb2: Product: DWC OTG Controller
[    1.488820] usb usb2: Manufacturer: Linux 3.0.36+ host20_hcd
[    1.488826] usb usb2: SerialNumber: usb20_host
[    1.489059] hub 2-0:1.0: USB hub found
[    1.489071] hub 2-0:1.0: 1 port detected
[    1.489398] DWC_OTG: Mode Mismatch Interrupt: currently in Host mode
[    1.562864] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    1.562874] android_usb gadget: Number of LUNs=2
[    1.562883]  lun0: LUN: removable file: (no medium)
[    1.562889]  lun1: LUN: removable file: (no medium)
[    1.563082] android_usb gadget: android_usb ready
[    1.563245] input: rk29-keypad as /devices/platform/rk29-keypad/input/input0
[    1.563402] usbcore: registered new interface driver xpad
[    1.563566] remotectl probe j=0x0
[    1.563574] remotectl probe j=0x1
[    1.563579] remotectl probe j=0x2
[    1.563583] remotectl probe j=0x3
[    1.563588] remotectl probe j=0x4
[    1.563592] remotectl probe j=0x5
[    1.563597] remotectl probe j=0x6
[    1.563602] remotectl probe j=0x7
[    1.563691] input: rkxx-remotectl as /devices/platform/rkxx-remotectl/input/input1
[    1.565772] rtc_hym8563 1-0051: clock/calendar information is no longer guaranteed
[    1.568421] using rtc device, rtc_hym8563, for alarms
[    1.568445] rtc_hym8563 1-0051: rtc core: registered rtc_hym8563 as rtc0
[    1.568476] i2c /dev entries driver
[    1.568901] lirc_dev: IR Remote Control driver registered, major 250
[    1.568910] IR NEC protocol handler initialized
[    1.568916] IR RC5(x) protocol handler initialized
[    1.568921] IR RC6 protocol handler initialized
[    1.568926] IR JVC protocol handler initialized
[    1.568932] IR Sony protocol handler initialized
[    1.568937] IR RC5 (streamzap) protocol handler initialized
[    1.568942] IR LIRC bridge handler initialized
[    1.568947] Linux video capture interface: v2.00
[    1.569003] usbcore: registered new interface driver uvcvideo
[    1.569010] USB Video Class driver (v1.1.0)
[    1.569042] def_ref_volt: 1800mV, curr_ref_volt: 1800mV
[    1.569563] device-mapper: uevent: version 1.0.3
[    1.569757] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[    1.569898] Bluetooth: HCI UART driver ver 2.2
[    1.569906] Bluetooth: HCI H4 protocol initialized
[    1.569913] Bluetooth: HCI Realtek H5 protocol initialized
[    1.569920] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    1.569979] cpuidle: using governor ladder
[    1.569985] cpuidle: using governor menu
[    1.615329]
[    1.615331] drivers/mmc/core/core.c...2019..  ===== mmc_rescan Begin....[mmc0]
[    1.620398] rk29_sdmmc_change_clk_div..1684..  newDiv=62, newCLK=299Khz [sd_mmc]
[    1.620433] .Line4018..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20.  [sd_mmc]
[    1.620567] .Line4018..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20.  [sdio]
[    1.621915] usbcore: registered new interface driver usbhid
[    1.621923] usbhid: USB HID core driver
[    1.622178] logger: created 256K log 'log_main'
[    1.622234] logger: created 256K log 'log_events'
[    1.622292] logger: created 256K log 'log_radio'
[    1.622344] logger: created 256K log 'log_system'
[    1.622621] zram: Created 1 device(s) ...
[    1.623026] i2c-core: driver [RK1000_CODEC] using legacy suspend method
[    1.623034] i2c-core: driver [RK1000_CODEC] using legacy resume method
[    1.667150]
[    1.667152] mmc_attach_sd..1230..  ===== Begin to identify card as SD-card. [mmc0]
[    1.778346] rk29_sdmmc_change_clk_div..1684..  newDiv=0, newCLK=37125Khz [sd_mmc]
[    1.778393] mmc0: new high speed SDHC card at address 0001
[    1.778613] mmcblk0: mmc0:0001 SD32G 29.1 GiB
[    1.780023]
[    1.780025] msdos_partition..466... ==== Begin to parse sdcard-partition.  [mmcblk0]
[    1.780036] msdos_partition..535... ==== The sdcard has MBR. [mmcblk0]
[    1.780044] msdos_partition..548... ==== partition-1, size=1981MB.  [mmcblk0]
[    1.780052] msdos_partition..576... ==== main partition-1....[mmcblk0]
[    1.780061] msdos_partition..548... ==== partition-2, size=51MB.  [mmcblk0]
[    1.780069] msdos_partition..576... ==== main partition-2....[mmcblk0]
[    1.780076]  mmcblk0: p1 p2
[    1.780427] sdmmc_rescan_try_freq..1913..  ===== Initialize SD-card successfully. [mmc0]
[    1.780445]
[    1.780446] drivers/mmc/core/core.c...2019..  ===== mmc_rescan Begin....[mmc1]
[    1.781749] register rk1000 codec earlysuspend ok
[    1.781763] RK1000_CODEC 0-0060: Failed to add route Left DAC->Left Mixer
[    1.788208] asoc: rk1000_codec <-> rk29_i2s.1 mapping ok
[    1.788491] ALSA device list:
[    1.788498]   #0: RK29_RK1000
[    1.788593] GACT probability NOT on
[    1.788603] Mirror/redirect action on
[    1.788610] u32 classifier
[    1.788614]     Actions configured
[    1.788620] Netfilter messages via NETLINK v0.30.
[    1.788664] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    1.788925] ctnetlink v0.93: registering with nfnetlink.
[    1.788955] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    1.788962] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    1.789198] xt_time: kernel timezone is -0000
[    1.789318] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.789441] arp_tables: (C) 2002 David S. Miller
[    1.789479] TCP cubic registered
[    1.789485] Initializing XFRM netlink socket
[    1.789837] NET: Registered protocol family 10
[    1.790375] Mobile IPv6
[    1.790400] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.790507] IPv6 over IPv4 tunneling driver
[    1.791071] NET: Registered protocol family 17
[    1.791095] NET: Registered protocol family 15
[    1.791275] Bluetooth: RFCOMM TTY layer initialized
[    1.791290] Bluetooth: RFCOMM socket layer initialized
[    1.791297] Bluetooth: RFCOMM ver 1.11
[    1.791303] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.791311] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.791435] NET: Registered protocol family 35
[    1.791511] [BT_RFKILL]: Enter rfkill_rk_init
[    1.791587] [BT_RFKILL]: Request irq for bt wakeup host
[    1.791607] [BT_RFKILL]: ** disable irq
[    1.791679] [BT_RFKILL]: bt shut off power
[    1.797375] rk29_sdmmc_change_clk_div..1684..  newDiv=42, newCLK=294Khz [sdio]
[    1.820413] [BT_RFKILL]: bt_default device registered.
[    1.820459] Registering the dns_resolver key type
[    1.820490] pmic set pm_suspend_volt:
[    1.820502] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    1.820524] Registering SWP/SWPB emulation handler
[    1.820929] ddrfreq: verion 3.2 20131126
[    1.820937] ddrfreq: fix cpu pause bug
[    1.820944] ddrfreq: normal 456MHz video 0MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 0MHz reboot 300MHz
[    1.821254] rk3188 lcdc0 clk enable...
[    1.821269] lcdc0: dclk:148500000>>fps:60
[    1.821279] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
[    1.821769] ddrfreq: change freq to 445 MHz when normal
[    1.821917] lcdc0: dclk:27000000>>fps:60
[    1.824077] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
[    1.824086] lcdc0 wakeup from standby!
[    1.824092] lcdc0 win0 open,atv layer:1
[    1.824103] lcdc0 win1 closed,atv layer:1
[    1.824110] rk1000_tv ver 2.0 probe ok
[    1.824915] rtc_hym8563 1-0051: setting system clock to 2011-01-01 12:00:00 UTC (1293883200)
[    1.827599] asoc: dit-hifi <-> rk-spdif mapping ok
[    1.828013] usbcore: registered new interface driver snd-usb-audio
[    1.828306] Freeing init memory: 2204K
[    1.877422] usb 2-1: new high speed USB device number 2 using usb20_host
[    2.087923] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101
[    2.087935] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.087943] usb 2-1: Product: USB 2.0 Hub
[    2.088278] hub 2-1:1.0: USB hub found
[    2.088417] hub 2-1:1.0: 4 ports detected
[    2.197836] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[    2.387409] usb 2-1.4: new full speed USB device number 3 using usb20_host
[    2.508029] usb 2-1.4: New USB device found, idVendor=0fe6, idProduct=9700
[    2.508040] usb 2-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    2.508049] usb 2-1.4: Product: USB 2.0 10/100M Ethernet Adaptor
[    2.547625] sr9700_android 2-1.4:1.0: eth0: register 'sr9700_android' at usb-usb20_host-1.4, SR9700_ANDROID USB Ethernet, 00:e0:4c:53:44:58
[    2.662466] init: /dev/hw_random not found
[    2.662539] keychord: using input dev rk29-keypad for fevent
[    2.662549] keychord: using input dev rkxx-remotectl for fevent
[    3.141834] gp_rknand_info = : 0xde248400
[    3.141913] rk30_chip_set:1
[    3.141968] FtlInit!
[    3.141987] No.1 FLASH ID:2c 64 44 4b a9 0
[    3.141997] No.2 FLASH ID:f0 ff ff ff ff ff
[    3.143548] FTL version: 5.0.12 20140214
[    3.264695] gBootMedia = 1 gSdmmcFwPartOffset =0!
[    3.264706] rknand_buffer.c version: 4.40 20130830!
[    3.274330] 10 cmdlinepart partitions found on MTD device rk29xxnand
[    3.274340] Creating 10 MTD partitions on "rk29xxnand":
[    3.274351] 0x000000400000-0x000000800000 : "misc"
[    3.291096] 0x000000800000-0x000001400000 : "kernel"
[    3.296462] 0x000001400000-0x000002000000 : "boot"
[    3.301635] 0x000002000000-0x000004000000 : "recovery"
[    3.307154] 0x000004000000-0x000008000000 : "backup"
[    3.312514] 0x000008000000-0x000010000000 : "cache"
[    3.317789] 0x000010000000-0x000010400000 : "metadata"
[    3.323336] 0x000010400000-0x000010800000 : "kpanic"
[    3.329066] apanic: Bound to mtd partition 'kpanic'
[    3.329076] apanic: No panic data available
[    3.329087] 0x000010800000-0x00005ec00000 : "system"
[    3.343468] 0x00005ec00000-0x0001df400000 : "userdata"
[    3.350774] fs_mgr: parse_link_device : path = NULL
[    3.355514] fs_mgr: parse_link_device : path = NULL
[    3.360411] fs_mgr: parse_link_device : path = NULL
[    3.365303] fs_mgr: parse_link_device : path = NULL
[    3.370195] fs_mgr: parse_link_device : path = NULL
[    3.375087] fs_mgr: parse_link_device : path = NULL
[    3.379983] fs_mgr: parse_link_device : path = NULL
[    3.384875] fs_mgr: parse_link_device : path = NULL
[    3.389785] fs_mgr: ---------------resize_fs blk_dev /dev/block/mtd/by-name/system, type ext4
[    3.398308] fs_mgr: Running /sbin/resize2fs on /dev/block/mtd/by-name/system
[    3.406809] resize2fs: resize2fs 1.41.14 (22-Dec-2010)
[    3.414696] resize2fs: The filesystem is already 320512 blocks long.  Nothing to do!
[    3.414712] resize2fs:
[    3.427850] EXT4-fs (mtdblock8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    3.446810] EXT4-fs (mtdblock5): recovery complete
[    3.446927] EXT4-fs (mtdblock5): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    3.463029] EXT4-fs (mtdblock6): warning: mounting unchecked fs, running e2fsck is recommended
[    3.463187] EXT4-fs (mtdblock6): mounted filesystem without journal. Opts: noauto_da_alloc,discard
[    3.618620] EXT4-fs (mtdblock9): recovery complete
[    3.618734] EXT4-fs (mtdblock9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    3.639752] UMP: Using OS memory backend, allocation limit: 1073741824
[    3.639767] UMP: UMP device driver -0d88e3e loaded
[    3.664424] Mali: Mali400 inside of rk3188!
[    3.664436] Mali: mali freq table num : 6
[    3.664444] Mali: mali freq table :Mali: 132,Mali: 179,Mali: 223,Mali: 297,Mali: 297,Mali: 446,Mali:
[    3.664477] Mali: init mali clock success
[    3.665799] Mali: Mali device driver loaded
[    3.668974] rk30_mirroring: Unknown symbol video_data_to_mirroring (err 0)
[    3.669014] rk30_mirroring: Unknown symbol audio_data_to_mirroring (err 0)
[    3.680458] rk29_ipp: module is from the staging directory, the quality is unknown, you have been warned.
[    3.681315] ipp irq 47
[    3.681612] IPP init, version rk30-ipp 1.003
[    3.754700] init: /dev/hw_random not found
[    3.775184] binder: 97:97 transaction failed 29189, size 0-0
[    3.781220] init: cannot find '/system/vendor/bin/pvrsrvctl', disabling 'pvrsrvctl'
[    3.788235] init: cannot find '/system/bin/rild3', disabling 'ril-daemon3'
[    3.790696] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[    4.000775] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper'
[    4.001668] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[    4.001684] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
[    4.001873] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
[    4.055276] warning: `su' uses 32-bit capabilities (legacy support in use)
[    4.067910] init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
[    4.076129] init: powerctl: cannot expand '${sys.powerctl}'
[    4.081991] init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
[    4.082122] RKNAND_GET_DRM_KEY
[    4.082131] return ret = 0
[    4.098701] init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
[    4.109579] android_usb: already disabled
[    4.113962] mtp_bind_config
[    4.206611] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[    4.301795] fs_mgr: parse_link_device : path = NULL
[    4.306540] fs_mgr: parse_link_device : path = NULL
[    4.311459] fs_mgr: parse_link_device : path = NULL
[    4.316361] fs_mgr: parse_link_device : path = NULL
[    4.318929] fs_mgr: parse_link_device : path = NULL
[    4.318956] fs_mgr: parse_link_device : path = NULL
[    4.318982] fs_mgr: parse_link_device : path = NULL
[    4.319011] fs_mgr: parse_link_device : path = NULL
[    4.319384] .204.. MMC0 receive the message sd-No-Media from VOLD.[sd_mmc]
[    4.319394] .235.. MMC0 receive the message No-Media from VOLD. waitTimes=0 [sd_mmc]
[    4.474879] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[    4.479978] .204.. MMC0 receive the message sd-Pending from VOLD.[sd_mmc]
[    4.480145] .204.. MMC0 receive the message sd-Idle-Unmounted from VOLD.[sd_mmc]
[    4.568852] EXT4-fs (mtdblock8): re-mounted. Opts: (null)
[    4.889076] rk fb use 3 buffers
[    6.181084] init: sys_prop: permission denied uid:1000  name:sys_graphic.cam_hal.ver
there's also a "recovery" button, when I push it while powering it boots to a different recovery image, and gives me a simple sh shell with busybox installed. the setup there looks pretty limited, with no Wi-Fi connectivity etc:
In
DDR3
300MHz
Memory OK
OUT
BUILD=====2
OK! 742309
unsigned!
SecureBootEn = 0 0
RECOVERY key is pressed
UsbBoot 747700
UsbHook ...1401967
powerOn 1401992
 1401990 11402270
 12138882 Starting kernel...@0x60408000
[    0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203)
[    0.000000] PERCPU: Embedded 7 pages/cpu @c343d000 s6976 r8192 d13504 u32768
[    0.000000] Kernel command line: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00430000 mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x0000
2000(misc),0x00006000@0x00004000(kernel),0x00006000@0x0000a000(boot),0x00010000@0x00010000(recovery),0x00020000@0x00020000(backup),0x00040000@0x00040000(cache),0x00002000@0x00080000(metadata
),0x00002000@0x00082000(kpanic),0x00272000@0x00084000(system),-@0x002F6000(userdata) bootver=2014-03-03#2.13 firmware_ver=4.4.2
[    0.000000] Memory: 1898432k/1898432k available, 198720k reserved, 1449984K highmem
[    0.003740] Calibrating delay loop (skipped) preset value.. 1583.48 BogoMIPS (lpj=7917420)
[    0.018136] Security Framework initialized
[    0.022768] Mount-cache hash table entries: 512
[    0.028338] Initializing cgroup subsys debug
[    0.033101] Initializing cgroup subsys cpuacct
[    0.038076] Initializing cgroup subsys memory
[    0.042949] Initializing cgroup subsys freezer
[    0.047922] CPU: Testing write buffer coherency: ok
[    0.134186] CPU1: Booted secondary processor
[    0.174184] CPU2: Booted secondary processor
[    0.214180] CPU3: Booted secondary processor
[    0.214217] Brought up 4 CPUs
[    0.231820] SMP: Total of 4 processors activated (6333.93 BogoMIPS).
[    0.239184] devtmpfs: initialized
[    0.249127] NET: Registered protocol family 16
[    0.254477] DVFS MSG:        AVS Value(index=0): 129 129 128 127 128 128 129 129 129 129
[    0.273372] lcdc0 is used as external display device contoller!
[    0.279956] lcdc1 is used as primary display device controller!
[    0.386731] rk29sdk_wifi_bt_gpio_control_init: init finished
    0.394287] console [ttyFIQ0] enabled, bootconsole disabled
[    0.394287] console [ttyFIQ0] enabled, bootconsole disabled
[    0.403289] Registered FIQ tty driver de0adc00
[    0.403872] Loaded driver for PL330 DMAC-1 rk29-pl330
[    0.403888]  DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    0.404038] Loaded driver for PL330 DMAC-2 rk29-pl330
[    0.404051]  DBUFF-64x8bytes Num_Chans-7 Num_Peri-20 Num_Events-14
[    0.435923] bio: create slab <bio-0> at 0
[    0.440329] SCSI subsystem initialized
[    0.440513] usbcore: registered new interface driver usbfs
[    0.440605] usbcore: registered new interface driver hub
[    0.454879] usbcore: registered new device driver usb
[    0.455258] rk30_i2c rk30_i2c.0: i2c-0: RK30 I2C adapter
[    0.455479] rk30_i2c rk30_i2c.1: i2c-1: RK30 I2C adapter
[    0.455646] rk30_i2c rk30_i2c.2: i2c-2: RK30 I2C adapter
[    0.455750] rk30_i2c rk30_i2c.3: i2c-3: RK30 I2C adapter
[    0.455854] rk30_i2c rk30_i2c.4: i2c-4: RK30 I2C adapter
[    0.486434] rk30-adc rk30-adc: rk30 adc: driver initialized
[    0.486501] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[    0.486677] rk29-wdt rk29-wdt.0: starting watchdog timer
[    0.486913] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.487319] Bluetooth: Core ver 2.16
[    0.487367] NET: Registered protocol family 31
[    0.487379] Bluetooth: HCI device and connection manager initialized
[    0.487393] Bluetooth: HCI socket layer initialized
[    0.487405] Bluetooth: L2CAP socket layer initialized
[    0.487430] Bluetooth: SCO socket layer initialized
[    0.488466] rk fb probe ok!
[    0.493150] act8846_set_init,line=17
[    0.493163] act8846_set_init:g_pmic_type=3
[    0.494836] act8846_set_init  act_dcdc1 =1200000mV end
[    0.496592] act8846_set_init  vdd_core =1000000mV end
[    0.498341] act8846_set_init  vdd_cpu =1000000mV end
[    0.500094] act8846_set_init  act_dcdc4 =3300000mV end
[    0.501248] act8846_set_init  act_ldo1 =1000000mV end
[    0.502898] act8846_set_init  act_ldo2 =1200000mV end
[    0.504558] act8846_set_init  act_ldo3 =1800000mV end
[    0.506210] act8846_set_init  act_ldo4 =3300000mV end
[    0.507859] act8846_set_init  act_ldo5 =3300000mV end
[    0.509508] act8846_set_init  act_ldo6 =3300000mV end
[    0.510559] act8846_set_init  act_ldo7 =1800000mV end
[    0.512207] act8846_set_init  act_ldo8 =2800000mV end
[    0.512225] act8846_set_init,line=78 END
[    0.512269] i2c-core: driver [act8846] using legacy suspend method
[    0.512281] i2c-core: driver [act8846] using legacy resume method
[    0.512322] rk1000_control_probe
[    0.537211] rk1000_control_probe ok
[    0.537273] Switching to clocksource rk_timer
[    0.543547] Switched to NOHz mode on CPU #0
[    0.544222] Switched to NOHz mode on CPU #2
[    0.544230] Switched to NOHz mode on CPU #3
[    0.544239] Switched to NOHz mode on CPU #1
[    0.544574] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xdf02c000
[    0.544618] fb0:win0
[    0.544621] fb1:win1
[    0.544624] fb2:win2
[    0.544682] rk3188 lcdc1 clk enable...
[    0.569762] rk3188 lcdc1 clk disable...
[    0.628030] fb0:phy:97000000>>vir:e0000000>>len:0x1800000
[    0.628272] rk_fb_register>>>>>fb0
[    0.628566] rk_fb_register>>>>>fb1
[    0.661052] rk3188 lcdc1 probe ok!
[    0.661129] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xdf040000
[    0.661181] fb0:win0
[    0.661185] fb1:win1
[    0.661187] fb2:win2
[    0.661251] rk3188 lcdc0 clk enable...
[    0.686323] rk3188 lcdc0 clk disable...
[    0.686340] fb2:phy:97000000>>vir:e0000000>>len:0x1800000
[    0.686568] rk_fb_register>>>>>fb2
[    0.686861] rk_fb_register>>>>>fb3
[    0.686874] rk3188 lcdc0 probe ok!
[    0.724657] cfg80211: Calling CRDA to update world regulatory domain
[    0.747743] IT66121 probe success.
[    0.751118] NET: Registered protocol family 2
[    0.751237] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.751543] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.752516] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.753937] TCP: Hash tables configured (established 65536 bind 65536)
[    0.753949] TCP reno registered
[    0.753961] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.753987] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.754263] NET: Registered protocol family 1
[    0.802587] RPC: Registered named UNIX socket transport module.
[    0.802602] RPC: Registered udp transport module.
[    0.802612] RPC: Registered tcp transport module.
[    0.802622] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.802789] Unpacking initramfs...
[    1.002882] Freeing initrd memory: 4288K
[    1.002976] PMU: registered new PMU device of type 0
[    1.003091] efuse_version_val: efuse version = 51
[    1.003105] DVFS MSG: core: dvfs_adjust_table_lmtvolt get leakage_level = 17000
[    1.003119]          adjust table freq=1608000 KHz, index=1350000 mV to index=1250000 mV
[    1.003134] efuse_version_val: efuse version = 51
[    1.003145] DVFS MSG: aclk_gpu: dvfs_adjust_table_lmtvolt get leakage_level = 17000
[    1.003967] cpufreq: delete arm freq(1608000)
[    1.047994] rk3188 cpufreq version 2.2, suspend freq 816 MHz
[    1.048215] vpu: power on
[    1.048265] VPU_SERVICE: checking hw id 4831
[    1.060860] vpu: power off...done
[    1.060899] VPU_SERVICE: init success
[    1.061152] audit: initializing netlink socket (disabled)
[    1.061190] type=2000 audit(1.000:1): initialized
[    1.078087] highmem bounce pool size: 64 pages
[    1.078262] ashmem: initialized
[    1.089043] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.089291] NTFS driver 2.1.30 [Flags: R/W].
[    1.089450] fuse init (API version 7.16)
[    1.104467] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.104480] io scheduler noop registered
[    1.104486] io scheduler deadline registered
[    1.104526] io scheduler cfq registered (default)
[    1.124809] rga: Driver loaded succesfully
[    1.124938] rk_serial.c v1.6 2013-12-23
[    1.124996] rk_serial.0: ttyS0 at MMIO 0x10124000 (irq = 66) is a rk29_serial.0
[    1.125085] rk_serial rk_serial.0: membase 0xdf048000
[    1.125131] rk_serial.3: ttyS3 at MMIO 0x20068000 (irq = 69) is a rk29_serial.3
[    1.125216] rk_serial rk_serial.3: membase 0xdf050000
[    1.125368] Rockchip ion module(version: 1.0) is successfully loaded
[    1.126888] loop: module loaded
[    1.126918] Android kernel panic handler initialized (bind=kpanic)
[    1.127420] PPP generic driver version 2.4.2
[    1.127517] PPP Deflate Compression module registered
[    1.127525] PPP BSD Compression module registered
[    1.187263] PPP MPPE Compression module registered
[    1.187275] NET: Registered protocol family 24
[    1.187283] tun: Universal TUN/TAP device driver, 1.6
[    1.187290] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.187462] usbcore: registered new interface driver sr9700_android
[    1.187480] Rockchip WiFi SYS interface (V1.00) ...
[    1.187512] Initializing USB Mass Storage driver...
[    1.187555] usbcore: registered new interface driver usb-storage
[    1.187562] USB Mass Storage support registered.
[    1.187637] usbcore: registered new interface driver usbserial
[    1.187663] USB Serial support registered for generic
[    1.187692] usbcore: registered new interface driver usbserial_generic
[    1.187698] usbserial: USB Serial Driver core
[    1.187720] USB Serial support registered for GSM modem (1-port)
[    1.187750] usbcore: registered new interface driver option
[    1.187756] option: v0.7.2:USB Driver for GSM modems
[    1.187778] USB Serial support registered for usi-modem
[    1.187810] usbcore: registered new interface driver usi-modem
[    1.409297] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
[    1.409314] usb20_otg usb20_otg: DWC OTG Controller
[    1.409381] usb20_otg usb20_otg: new USB bus registered, assigned bus number 1
[    1.409407] usb20_otg usb20_otg: irq 48, io mem 0x00000000
[    1.409435] DWC_OTG: Init: Port Power? op_state=1
[    1.409440] DWC_OTG: Init: Power Port (0)
[    1.409481] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.409490] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.409498] usb usb1: Product: DWC OTG Controller
[    1.409504] usb usb1: Manufacturer: Linux 3.0.36+ dwc_otg_hcd
[    1.409510] usb usb1: SerialNumber: usb20_otg
[    1.409768] hub 1-0:1.0: USB hub found
[    1.409783] hub 1-0:1.0: 1 port detected
[    1.412314] DWC_OTG: host20_driver_probe host2.0 reg addr: 0x101c0000 remap:0xdf100000
[    1.622668] DWC_OTG: ^^^^^^^^^^^^^^^^^^Host Mode
[    1.622697] usb20_host usb20_host: DWC OTG Controller
[    1.622724] usb20_host usb20_host: new USB bus registered, assigned bus number 2
[    1.622751] usb20_host usb20_host: irq 49, io mem 0x00000000
[    1.622791] DWC_OTG: Init: Port Power? op_state=1
[    1.622796] DWC_OTG: Init: Power Port (0)
[    1.622828] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.622837] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.622845] usb usb2: Product: DWC OTG Controller
[    1.622851] usb usb2: Manufacturer: Linux 3.0.36+ host20_hcd
[    1.622858] usb usb2: SerialNumber: usb20_host
[    1.623096] hub 2-0:1.0: USB hub found
[    1.623107] hub 2-0:1.0: 1 port detected
[    1.623432] DWC_OTG: Mode Mismatch Interrupt: currently in Host mode
[    1.696903] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    1.696914] android_usb gadget: Number of LUNs=2
[    1.696921]  lun0: LUN: removable file: (no medium)
[    1.696928]  lun1: LUN: removable file: (no medium)
[    1.697112] android_usb gadget: android_usb ready
[    1.697283] input: rk29-keypad as /devices/platform/rk29-keypad/input/input0
[    1.697509] usbcore: registered new interface driver xpad
[    1.697677] remotectl probe j=0x0
[    1.697684] remotectl probe j=0x1
[    1.697689] remotectl probe j=0x2
[    1.697694] remotectl probe j=0x3
[    1.697698] remotectl probe j=0x4
[    1.697703] remotectl probe j=0x5
[    1.697707] remotectl probe j=0x6
[    1.697713] remotectl probe j=0x7
[    1.697829] input: rkxx-remotectl as /devices/platform/rkxx-remotectl/input/input1
[    1.699929] rtc_hym8563 1-0051: clock/calendar information is no longer guaranteed
[    1.702570] using rtc device, rtc_hym8563, for alarms
[    1.702594] rtc_hym8563 1-0051: rtc core: registered rtc_hym8563 as rtc0
[    1.702624] i2c /dev entries driver
[    1.703052] lirc_dev: IR Remote Control driver registered, major 250
[    1.703061] IR NEC protocol handler initialized
[    1.703066] IR RC5(x) protocol handler initialized
[    1.703072] IR RC6 protocol handler initialized
[    1.703077] IR JVC protocol handler initialized
[    1.703082] IR Sony protocol handler initialized
[    1.703087] IR RC5 (streamzap) protocol handler initialized
[    1.703093] IR LIRC bridge handler initialized
[    1.703098] Linux video capture interface: v2.00
[    1.703154] usbcore: registered new interface driver uvcvideo
[    1.703161] USB Video Class driver (v1.1.0)
[    1.703192] def_ref_volt: 1800mV, curr_ref_volt: 1800mV
[    1.703712] device-mapper: uevent: version 1.0.3
[    1.703904] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[    1.704045] Bluetooth: HCI UART driver ver 2.2
[    1.704054] Bluetooth: HCI H4 protocol initialized
[    1.704060] Bluetooth: HCI Realtek H5 protocol initialized
[    1.704066] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    1.704125] cpuidle: using governor ladder
[    1.704130] cpuidle: using governor menu
[    1.749511]
[    1.749514] drivers/mmc/core/core.c...2019..  ===== mmc_rescan Begin....[mmc0]
[    1.754568] rk29_sdmmc_change_clk_div..1684..  newDiv=62, newCLK=299Khz [sd_mmc]
[    1.754594] .Line4018..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20.  [sd_mmc]
[    1.754722] .Line4018..The End of SDMMC-probe Ver.6.07 The last modify date is 2013-12-20.  [sdio]
[    1.756052] usbcore: registered new interface driver usbhid
[    1.756060] usbhid: USB HID core driver
[    1.756312] logger: created 256K log 'log_main'
[    1.756365] logger: created 256K log 'log_events'
[    1.756418] logger: created 256K log 'log_radio'
[    1.756470] logger: created 256K log 'log_system'
[    1.756766] zram: Created 1 device(s) ...
[    1.757156] i2c-core: driver [RK1000_CODEC] using legacy suspend method
[    1.757166] i2c-core: driver [RK1000_CODEC] using legacy resume method
[    1.807097]
[    1.807099] mmc_attach_sd..1230..  ===== Begin to identify card as SD-card. [mmc0]
[    1.914576] register rk1000 codec earlysuspend ok
[    1.914590] RK1000_CODEC 0-0060: Failed to add route Left DAC->Left Mixer
[    1.918332] rk29_sdmmc_change_clk_div..1684..  newDiv=0, newCLK=37125Khz [sd_mmc]
[    1.918383] mmc0: new high speed SDHC card at address 0001
[    1.918578] mmcblk0: mmc0:0001 SD32G 29.1 GiB
[    1.919959]
[    1.919961] msdos_partition..466... ==== Begin to parse sdcard-partition.  [mmcblk0]
[    1.919976] msdos_partition..535... ==== The sdcard has MBR. [mmcblk0]
[    1.919985] msdos_partition..548... ==== partition-1, size=1981MB.  [mmcblk0]
[    1.919993] msdos_partition..576... ==== main partition-1....[mmcblk0]
[    1.920001] msdos_partition..548... ==== partition-2, size=51MB.  [mmcblk0]
[    1.920009] msdos_partition..576... ==== main partition-2....[mmcblk0]
[    1.920016]  mmcblk0: p1 p2
[    1.920379] sdmmc_rescan_try_freq..1913..  ===== Initialize SD-card successfully. [mmc0]
[    1.920396]
[    1.920398] drivers/mmc/core/core.c...2019..  ===== mmc_rescan Begin....[mmc1]
[    1.923888] asoc: rk1000_codec <-> rk29_i2s.1 mapping ok
[    1.924170] ALSA device list:
[    1.924176]   #0: RK29_RK1000
[    1.924273] GACT probability NOT on
[    1.924283] Mirror/redirect action on
[    1.924289] u32 classifier
[    1.924292]     Actions configured
[    1.924299] Netfilter messages via NETLINK v0.30.
[    1.924338] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    1.924601] ctnetlink v0.93: registering with nfnetlink.
[    1.924632] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    1.924639] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    1.924876] xt_time: kernel timezone is -0000
[    1.924994] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.925115] arp_tables: (C) 2002 David S. Miller
[    1.925153] TCP cubic registered
[    1.925159] Initializing XFRM netlink socket
[    1.925509] NET: Registered protocol family 10
[    1.926045] Mobile IPv6
[    1.926071] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.926179] IPv6 over IPv4 tunneling driver
[    1.926741] NET: Registered protocol family 17
[    1.926766] NET: Registered protocol family 15
[    1.926948] Bluetooth: RFCOMM TTY layer initialized
[    1.926964] Bluetooth: RFCOMM socket layer initialized
[    1.926971] Bluetooth: RFCOMM ver 1.11
[    1.926978] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.926986] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.927114] NET: Registered protocol family 35
[    1.927190] [BT_RFKILL]: Enter rfkill_rk_init
[    1.927265] [BT_RFKILL]: Request irq for bt wakeup host
[    1.927285] [BT_RFKILL]: ** disable irq
[    1.927397] [BT_RFKILL]: bt shut off power
[    1.937333] rk29_sdmmc_change_clk_div..1684..  newDiv=42, newCLK=294Khz [sdio]
[    1.960410] [BT_RFKILL]: bt_default device registered.
[    1.960458] Registering the dns_resolver key type
[    1.960481] pmic set pm_suspend_volt:
[    1.960493] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    1.960515] Registering SWP/SWPB emulation handler
[    1.960929] ddrfreq: verion 3.2 20131126
[    1.960936] ddrfreq: fix cpu pause bug
[    1.960943] ddrfreq: normal 456MHz video 0MHz video_low 0MHz dualview 0MHz idle 0MHz suspend 0MHz reboot 300MHz
[    1.961259] rk3188 lcdc0 clk enable...
[    1.961273] lcdc0: dclk:148500000>>fps:60
[    1.961282] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
[    1.961768] ddrfreq: change freq to 445 MHz when normal
[    1.961914] lcdc0: dclk:27000000>>fps:60
[    1.964072] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
[    1.964082] lcdc0 wakeup from standby!
[    1.964087] lcdc0 win0 open,atv layer:1
[    1.964098] lcdc0 win1 closed,atv layer:1
[    1.964106] rk1000_tv ver 2.0 probe ok
[    1.964911] rtc_hym8563 1-0051: setting system clock to 2011-01-01 12:00:00 UTC (1293883200)
[    1.967592] asoc: dit-hifi <-> rk-spdif mapping ok
[    1.967991] usbcore: registered new interface driver snd-usb-audio
[    1.968285] Freeing init memory: 2204K
[    2.007403] usb 2-1: new high speed USB device number 2 using usb20_host
[    2.217975] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101
[    2.217987] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.217996] usb 2-1: Product: USB 2.0 Hub
[    2.218402] hub 2-1:1.0: USB hub found
[    2.218467] hub 2-1:1.0: 4 ports detected
[    2.517464] usb 2-1.4: new full speed USB device number 3 using usb20_host
[    2.638071] usb 2-1.4: New USB device found, idVendor=0fe6, idProduct=9700
[    2.638083] usb 2-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    2.638092] usb 2-1.4: Product: USB 2.0 10/100M Ethernet Adaptor
[    2.678056] sr9700_android 2-1.4:1.0: eth0: register 'sr9700_android' at usb-usb20_host-1.4, SR9700_ANDROID USB Ethernet, 00:e0:4c:53:44:58
[    2.868585] init: /dev/hw_random not found
[    2.868849] android_usb: already disabled
[    2.869005] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[    2.869017] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
[    2.877895] gp_rknand_info = : 0xde248400
[    2.877961] rk30_chip_set:1
[    2.878016] FtlInit!
[    2.878035] No.1 FLASH ID:2c 64 44 4b a9 0
[    2.879596] FTL version: 5.0.12 20140214
[    2.994673] gBootMedia = 1 gSdmmcFwPartOffset =0!
[    2.994683] rknand_buffer.c version: 4.40 20130830!
[    3.004330] 11 cmdlinepart partitions found on MTD device rk29xxnand
[    3.004340] Creating 11 MTD partitions on "rk29xxnand":
[    3.004350] 0x000000000000-0x000000400000 : "parameter"
[    3.021374] 0x000000400000-0x000000800000 : "misc"
[    3.026427] 0x000000800000-0x000001400000 : "kernel"
[    3.031647] 0x000001400000-0x000002000000 : "boot"
[    3.036672] 0x000002000000-0x000004000000 : "recovery"
[    3.042045] 0x000004000000-0x000008000000 : "backup"
[    3.047253] 0x000008000000-0x000010000000 : "cache"
[    3.052376] 0x000010000000-0x000010400000 : "metadata"
[    3.057774] 0x000010400000-0x000010800000 : "kpanic"
[    3.063432] apanic: Bound to mtd partition 'kpanic'
[    3.063441] apanic: No panic data available
[    3.063454] 0x000010800000-0x00005ec00000 : "system"
[    3.077651] 0x00005ec00000-0x0001df400000 : "userdata"
[    3.111943] EXT4-fs (mtdblock6): mounted filesystem with ordered data mode. Opts: discard
rty__irectocyopeana/pdape: yoerrnot find any tzdata when looking for GMT!
__bionic_open_tzdata: couldn't find any tzdata when looking for posixrules!
Starting recovery on Sat Jan  1 12:00:01 2011
bootmode = unknown
recovery filesystem table
  0 /mnt/internal_sd vfat /dev/block/mtd/by-name/user 0
  1 /mnt/external_sd vfat /dev/block/mmcblk0 0
  2 /system ext4 /dev/block/mtd/by-name/system 0
  3 /cache ext4 /dev/block/mtd/by-name/cache 0
  4 /metadata ext4 /dev/block/mtd/by-name/metadata 0
  5 /data ext4 /dev/block/mtd/by-name/userdata 0
  6 /cust ext4 /dev/block/mtd/by-name/cust 0
  7 /custom ext4 /dev/block/mtd/by-name/custom 0
  8 /misc mtd misc 0
  9 /uboot mtd uboot 0
  10 /charge mtd charge 0
  11 /parameter mtd parameter 0
  12 /boot mtd boot 0
  13 /recovery mtd recovery 0
  14 /backup mtd backup 0
  15 /tmp ramdisk ramdisk 0
I:InternalSD_ROOT: /mnt/internal_sd
I:ExternalSD_ROOT: /mnt/external_sd
I:Set boot command "boot-recovery"
locale is [(null)]
stage is []
failed to read font: res=-1
can't open /dev/tty0: No such file or directory
framebuffer: fd 3 (1920 x 1080)
[    3.234131] rk30-lcdc rk30-lcdc.0: blank mode:4
[    3.234143] rk30-lcdc rk30-lcdc.0: blank mode:0
       installing_text:  (1 x 1 @ 1896)
          erasing_text:  (1 x 1 @ 1599)
       no_command_text:  (1 x 1 @ 1599)
            error_text:  (1 x 1 @ 1599)
Recovery system v4.4.0
[    3.354441] EXT4-fs (mtdblock7): warning: mounting unchecked fs, running e2fsck is recommended
[    3.354611] EXT4-fs (mtdblock7): mounted filesystem without journal. Opts:
[    3.355352] FAT-fs (mmcblk0): invalid media value (0x00)
[    3.355361] FAT-fs (mmcblk0): Can't find a valid FAT filesystem
W:trying mount /dev/block/mmcblk0 to ntfs
[    3.468709] NTFS-fs error (device mmcblk0): read_ntfs_boot_sector(): Primary boot sector is invalid.
[    3.468723] NTFS-fs error (device mmcblk0): read_ntfs_boot_sector(): Mount option errors=recover not used. Aborting without trying to recover.
[    3.468734] NTFS-fs error (device mmcblk0): ntfs_fill_super(): Not an NTFS volume.
read cmdline
Not enter sdboot!
auto sdcard update path: /mnt/external_sd/FirmwareUpdate/auto_sd_update.tag
bootmode = unknown
Command: "/sbin/recovery"
ro.rk.cpu=rk3188
ro.rk.soc=rk3188+
ro.rk.wifi_on=false
ro.rk.bt_enable=true
ro.rk.systembar.tabletUI=false
ro.rk.systembar.voiceicon=true
ro.rk.MassStorage=false
ro.rk.changescreen=false
ro.rk.homepage_base=http://pikotv.com
ro.rk.def_brightness=200
ro.rk.screenoff_time=-1
ro.rk.screenshot_enable=true
ro.rk.install_non_market_apps=truerue
ro.sf.hwrotation=0
ro.sf.lcd_density=160
ro.sf.fakerotation=false
ro.sf.lcdc_composer=0
ro.adb.secure=0
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=true
ro.ril.ecclist=112,911
ro.sms.capable=false
ro.boot.console=ttyFIQ0
ro.dlna.devicename=eHomeCenter
ro.wifi.channels=
ro.allow.mock.location=0
ro.audio.monitorOrientation=true
ro.board.platform=rk3188
ro.build.id=KOT49H
ro.build.date=Sun Oct 12 14:41:31 CEST 2014
ro.build.date.utc=1413117691
ro.build.host=pfullingen.str.redhat.com
ro.build.tags=test-keys
ro.build.type=user
ro.build.user=wasser
ro.build.display.id=KOT49H test-keys
ro.build.product=rk3188
ro.build.version.sdk=19
ro.build.version.release=4.4.2
ro.build.version.codename=REL
ro.build.version.incremental=eng.wasser.20141012.143755
ro.build.description=rk3188-user 4.4.2 KOT49H eng.wasser.20141012.143755 test-keys
ro.build.fingerprint=rockchip/rk3188/rk3188:4.4.2/KOT49H/eng.wasser.20141012.143755:user/test-keys
ro.build.characteristics=tablet
ro.rksdk.version=RK30_ANDROID$(PLATFORM_VERSION)-SDK-v1.00.00 \
ro.voice.capable=false
ro.ap_mdm=-1
ro.config.ringtone=Ring_Synth_04.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
ro.config.notification_sound=pixiedust.ogg
ro.kernel.android.checkjni=0
ro.secure=0
ro.tether.denied=false
ro.vendor.sw.version=1.0.5
ro.carrier=unknown
ro.default.size=100
ro.factory.tool=0
ro.factory.hasGPS=false
ro.factory.hasUMS=false
ro.factory.without_battery=true
ro.factory.storage_suppntfs=true
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.name=rk3188
ro.product.board=manta
ro.product.brand=google
ro.product.model=Nexus 10
ro.product.device=manta
ro.product.locale.region=US
ro.product.locale.language=en
ro.product.version=1.0.0
ro.product.usbfactory=rockchip_usb
ro.product.manufacturer=samsung
ro.baseband=unknown
ro.bootmode=unknown
ro.hardware=rk30board
ro.opengles.version=131072
ro.revision=0
ro.bootloader=unknown
ro.debuggable=0
ro.ap_has_alsa=-1
ro.factorytest=0
ro.ap_data_only=-1
ro.ap_has_earphone=-1
sf.power.control=2073600
net.bt.name=Android
net.change=net.bt.name
ril.function.dataonly=1
sys.hwc.compose_policy=6
sys.rkadb.wasser=0
sys.wallpaper.rgb565=0
sys.resolution.changed=false
init.svc.console=running
init.svc.ueventd=running
init.svc.recovery=running
rild.libargs=-d /dev/ttyACM0
rild.libpath=/system/lib/libril-rk29-dataonly.so
rild.libpath1=/system/lib/libreference-ril-mt6229.so
rild.libpath2=/system/lib/libreference-ril-mu509.so
rild.libpath4=/system/lib/libreference-ril-mw100.so
rild.libpath6=/system/lib/libreference-ril-sc6610.so
rild.libpath7=/system/lib/libreference-ril-m51.so
rild.libpath8=/system/lib/libreference-ril-mt6250.so
rild.libpath9=/system/lib/libreference-ril-c66a.so
rild.libpath10=/system/lib/libreference-ril-sew290.so
rild.libpath11=/system/lib/libreference-ril-u5501.so
rild.libpath12=/system/lib/libreference-ril-u7501.so
rild.libpath13=/system/lib/libreference-ril-aw706.so
rild.libpath14=/system/lib/libreference-ril-a85xx.so
rild.libpath15=/system/lib/libreference-ril-e1230s.so
wifi.interface=wlan0
wifi.supplicant_scan_interval=15
debug.nfc.se=false
debug.nfc.fw_download=false
debug.hwui.render_dirty_regions=false
media.rmvb.support=1
rild1.libpath=/system/lib/libreference-ril-sc6610-1.so
rild3.libpath=/system/lib/libril-rk29-dataonly.so
video.use.overlay=0
video.bluray.render=gpu
video.bluray.navigationMenu=hide
dalvik.vm.jniopts=warnonly
dalvik.vm.heapsize=384m
dalvik.vm.heapmaxfree=8m
dalvik.vm.heapminfree=512k
dalvik.vm.dexopt-flags=m=y
dalvik.vm.heapstartsize=8m
dalvik.vm.heapgrowthlimit=64m
dalvik.vm.stack-trace-file=/data/anr/traces.txt
dalvik.vm.heaptargetutilization=0.75
persist.sys.usb.config=mtp,adb
persist.sys.dalvik.vm.lib=libdvm.so
persist.sys.timezone=Europe/Berlin
persist.sys.strictmode.visual=false
persist.audio.currentplayback=9
persist.audio.lastsocplayback=9
persist.tegra.nvmmlite=1
keyguard.no_require_sim=true
ExternalSD_ROOT=/mnt/external_sd
InternalSD_ROOT=/mnt/internal_sd
UserVolumeLabel=RockChips
I:Set boot command ""
heres the busybox output:
# busybox
BusyBox v1.11.1 (2009-03-11 09:17:49 CST) multi-call binary
Copyright (C) 1998-2008 Erik Andersen, Rob Landley, Denys Vlasenko
and others. Licensed under GPLv2.
See source distribution for full notice.
Usage: busybox [function] [arguments]...
   or: function [arguments]...
        BusyBox is a multi-call binary that combines many common Unix
        utilities into a single executable.  Most people will create a
        link to busybox for each function they wish to use and BusyBox
        will act like whatever it was invoked as!
Currently defined functions:
        [, [[, addgroup, adduser, adjtimex, ar, arp, arping, ash,
        awk, basename, brctl, bunzip2, bzcat, bzip2, cal, cat, catv,
        chat, chattr, chgrp, chmod, chown, chpasswd, chpst, chroot,
        chrt, chvt, cksum, clear, cmp, comm, cp, cpio, crond, crontab,
        cryptpw, cttyhack, cut, date, dc, dd, deallocvt, delgroup,
        deluser, depmod, df, dhcprelay, diff, dirname, dmesg, dnsd,
        dos2unix, du, dumpkmap, dumpleases, echo, ed, egrep, eject,
        env, envdir, envuidgid, ether-wake, expand, expr, fakeidentd,
        false, fbset, fbsplash, fdflush, fdformat, fdisk, fetchmail,
        fgrep, find, fold, free, freeramdisk, fsck, fsck.minix,
        ftpget, ftpput, fuser, getopt, getty, grep, gunzip, gzip,
        halt, hdparm, head, hexdump, hostid, hostname, httpd, hush,
        hwclock, id, ifconfig, ifdown, ifenslave, ifup, inetd, init,
        inotifyd, insmod, install, ip, ipaddr, ipcalc, ipcrm, ipcs,
        iplink, iproute, iprule, iptunnel, kbd_mode, kill, killall,
        killall5, klogd, lash, last, length, less, linux32, linux64,
        linuxrc, ln, loadfont, loadkmap, logger, login, logname,
        logread, losetup, lpd, lpq, lpr, ls, lsattr, lsmod, lzmacat,
        makedevs, man, md5sum, mdev, mesg, microcom, mkdir, mkfifo,
        mkfs.minix, mknod, mkswap, mktemp, modprobe, more, mount,
        mountpoint, msh, mt, mv, nameif, nc, netstat, nice, nmeter,
        nohup, nslookup, od, openvt, passwd, patch, pgrep, pidof,
        ping, ping6, pipe_progress, pivot_root, pkill, poweroff,
        printenv, printf, ps, pscan, pwd, raidautorun, rdate, readahead,
        readlink, readprofile, realpath, reboot, renice, reset,
        resize, rm, rmdir, rmmod, route, rpm, rpm2cpio, rtcwake,
        run-parts, runlevel, runsv, runsvdir, rx, script, sed, sendmail,
        seq, setarch, setconsole, setkeycodes, setlogcons, setsid,
        setuidgid, sh, sha1sum, slattach, sleep, softlimit, sort,
        split, start-stop-daemon, stat, strings, stty, su, sulogin,
        sum, sv, svlogd, swapoff, swapon, switch_root, sync, sysctl,
        syslogd, tac, tail, tar, taskset, tcpsvd, tee, telnet, telnetd,
        test, tftp, tftpd, time, top, touch, tr, traceroute, true,
        tty, ttysize, udhcpc, udhcpd, udpsvd, umount, uname, uncompress,
        unexpand, uniq, unix2dos, unlzma, unzip, uptime, usleep,
        uudecode, uuencode, vconfig, vi, vlock, watch, watchdog,
        wc, wget, which, who, whoami, xargs, yes, zcat, zcip
 let me know if there is any more info I can give, or anything else I can try!
