Hi all,
SPI has been enabled into /boot/armbianEnv.txt with:
overlays=spi-spidev
param_spidev_spi_bus=0
Nothing works knowing that the wiring between device and BPI has been checked more than 3 time.
How can I check that SPI0 works well? where can I check that dtd file is correctly loaded? What are created files on fs when the spi port is correctly enabled?
==> Armbian 21.05.1 Focal with Linux 5.15.48-sunxi
Many thanks
Hello Bruno,
I don't have any BPI boards, but in addition to Myron's request to understand specifics.
What is the output ?
demsg | grep spi*
armbianEnv selections look correct, but will require more info.
