grecha Posted August 22, 2022 Share Posted August 22, 2022 Hello! I would like to connect orangepi-4-lts to ili9341. I have new blank Armbian. $ uname -a Linux orangepi4-lts 5.15.52-rockchip64 #22.05.4 SMP PREEMPT I did overlay based on allwinner: /dts-v1/; /plugin/; / { compatible = "rockchip,rk3399"; fragment@0 { target = <&gpio1>; __overlay__ { ili9341_pins: ili9341_pins { pins = "PC7", "PD0"; function = "gpio_out", "gpio_out"; }; }; }; fragment@1 { target = <&spi1>; __overlay__ { status = "okay"; cs-gpios = <&gpio1 10 1>; ili9341: ili9341@0 { compatible = "ilitek, ili9341"; reg = <1>; pinctrl-names = "default"; pinctrl-0 = <&ili9341_pins>; spi-max-frequency = <16000000>; rotate = <90>; bgr; fps = <25>; buswidth = <8>; reset-gpios = <&gpio1 23 1>; dc-gpios = <&gpio1 24 0>; debug = <0>; }; }; }; }; Setting /boot/armbianEnv.txt verbosity=1 bootlogo=true extraargs=systemd.unified_cgroup_hierarchy=0 overlay_prefix=rockchip fdtfile=rockchip/rk3399-orangepi-4-lts.dtb rootdev=UUID=ce86a0ca-f0e5-4dba-af37-15cc3fb2f4e0 rootfstype=ext4 param_spidev_spi_bus=1 param_spidev_spi_cs=0 user_overlays=ili9341 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Restart, TFT not turn on. I watch debugiing uart, no errors: ## Executing script at 00500000 Boot script loaded from mmc 1 320 bytes read in 4 ms (78.1 KiB/s) 16356833 bytes read in 696 ms (22.4 MiB/s) 30540288 bytes read in 1295 ms (22.5 MiB/s) 81458 bytes read in 14 ms (5.5 MiB/s) 1233 bytes read in 7 ms (171.9 KiB/s) Applying user provided DT overlay ili9341.dtbo 2698 bytes read in 9 ms (292 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Moving Image from 0x2080000 to 0x2200000, end=3fc0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 16356769 Bytes = 15.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f4f65000, end f5efe5a1 ... OK Loading Device Tree to 00000000f4ee8000, end 00000000f4f64fff ... OK Starting kernel ... Watching system boot log: grecha@orangepi4-lts:~$ sudo dmesg | grep spi [ 2.053302] rockchip-spi ff1d0000.spi: cs1 >= max 1 [ 2.053318] spi_master spi1: spi_device register error /spi@ff1d0000/ili9341@0 [ 2.053345] spi_master spi1: Failed to create SPI device for /spi@ff1d0000/ili9341@0 grecha@orangepi4-lts:~$ sudo dmesg | grep ili9341 [ 2.053318] spi_master spi1: spi_device register error /spi@ff1d0000/ili9341@0 [ 2.053345] spi_master spi1: Failed to create SPI device for /spi@ff1d0000/ili9341@0 Please, help me. Why is this overlay not working? 0 Quote Link to comment Share on other sites More sharing options...
grecha Posted August 23, 2022 Author Share Posted August 23, 2022 If i set overlay, line 23 reg = <0>; then i get [ 2.030154] rockchip-spi ff1d0000.spi: chipselect 0 already in use i understand fdtfile=rockchip/rk3399-orangepi-4-lts.dtb has device spidev reg = <0>; File /boot/dtb/rockchip/overlay/README.rockchip-overlays says "Using chip select 1 requires using "spi-add-cs1" overlay", but i nave not overlay spi-add-cs1. There is an idea to edit rk3399-orangepi-4-lts.dtb - remove device spidev and set reg = <0>; for ili9341, but that is a bad idea, and I'm not sure what will work I would like to make everything just an overlay. 0 Quote Link to comment Share on other sites More sharing options...
grecha Posted August 26, 2022 Author Share Posted August 26, 2022 Hi! I made a new one dtb, it seems to work. I not building new device and used spidev from main dtb. It looking great: grecha@orangepi4-lts:~$ sudo dmesg | grep 9341 [ 6.883847] fb_ili9341: module is from the staging directory, the quality is unknown, you have been warned. [ 6.967905] SPI driver fb_ili9341 has no spi_device_id for ilitek,ili9341 [ 6.969815] fb_ili9341 spi1.0: fbtft_property_value: buswidth = 8 [ 6.969841] fb_ili9341 spi1.0: fbtft_property_value: debug = 0 [ 6.969849] fb_ili9341 spi1.0: fbtft_property_value: rotate = 90 [ 6.969860] fb_ili9341 spi1.0: fbtft_property_value: fps = 25 [ 7.301423] graphics fb1: fb_ili9341 frame buffer, 320x240, 150 KiB video memory, 16 KiB buffer memory, fps=25, spi1.0 at 18 MHz a new device appears: but I get a white screen, I`m at a loss. dts: /dts-v1/; /plugin/; / { compatible = "rockchip,rk3399"; fragment@0 { target = <&pinctrl>; __overlay__ { spidev { ili9341_pins: ili9341_pins { rockchip,pins = <1 23 1 &pcfg_pull_none>, <1 24 1 &pcfg_pull_none>; }; }; }; }; fragment@1 { target = <&spi1>; __overlay__ { status = "okay"; cs-gpios = <&gpio1 10 1>; #address-cells = <1>; #size-cells = <0>; spidev { compatible = "ilitek,ili9341"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&ili9341_pins>; spi-max-frequency = <160000000>; rotate = <90>; bgr; fps = <25>; buswidth = <8>; reset-gpios = <&gpio1 23 0>; dc-gpios = <&gpio1 24 0>; debug = <0>; }; }; }; }; Help me please 0 Quote Link to comment Share on other sites More sharing options...
grecha Posted August 27, 2022 Author Share Posted August 27, 2022 I did it. thank you all for your help) /dts-v1/; /plugin/; / { compatible = "rockchip,rk3399"; fragment@0 { target = <&spi1>; __overlay__ { status = "okay"; #address-cells = <1>; #size-cells = <0>; spidev { compatible = "ilitek,ili9341"; status = "okay"; spi-max-frequency = <4000000000>; rotate = <90>; bgr; fps = <25>; buswidth = <8>; reset-gpios = <&gpio1 23 1>; dc-gpios = <&gpio1 24 0>; led-gpios = <&gpio1 3 0>; debug = <0>; }; }; }; }; 0 Quote Link to comment Share on other sites More sharing options...
Spartan Posted March 16 Share Posted March 16 Dear author, could you describe in more detail the process of connecting and setting up this display to orangepi-4-lts? There is very little information on the Internet on this topic, in particular for this board Thank you in advance 0 Quote Link to comment Share on other sites More sharing options...
