i have 2 sd cards, 32 and 16gb. on every of them i burned ubuntu xfce and debian cli using dd and armbian imager (8 total tries). none worked. board every time booted into Android which locates on 16gb internal eMMC. what should i do? i looked into manual but no luck. i dont have DC to power board while doing maskrom. maybe i can wipe emmc from itself ( boot into android 12 and destroy it)? or i noticed that when i connect board via usb type c to my mac, it still powers on, so maybe i dont even need dc power to get maskrom device? im geniue lost now, i was searching in web for solution past 3 hours
OKAY SO I SPEND 5 HOURS FIGURING IT OUT AND I (oh i should cald down) figured out that issue was in images. none of images that were listed on page for orange pi 4 lts did not work. the second i inserted sd cart with official OS from orange pi it booted.
btw there is log when any armbian image is used:
In
channel 0
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x3
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x83
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x3
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 MHz, current 856MHz
OUT
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 353
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
FwPartOffset=2000 , 0
StorageInit ok = 251529
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3335db8 signature is wrong
recovery gpt...
recovery gpt fail!
Trust Addr:0x4000, 0x0
Trust Addr:0x4400, 0x0
Trust Addr:0x4800, 0x0
Trust Addr:0x4c00, 0x0
Trust Addr:0x5000, 0x0
Trust Addr:0x5400, 0x0
Trust Addr:0x5800, 0x0
Trust Addr:0x5c00, 0x0
Addr:0x4000 No find trust.img!
LoadTrustBL error:-3
SecureMode = 0
GPT part:  0, name:         security, start:0x2000, size:0x2000
GPT part:  1, name:            uboot, start:0x4000, size:0x2000
GPT part:  2, name:            trust, start:0x6000, size:0x2000
GPT part:  3, name:             misc, start:0x8000, size:0x2000
GPT part:  4, name:             dtbo, start:0xa000, size:0x2000
GPT part:  5, name:           vbmeta, start:0xc000, size:0x800
GPT part:  6, name:             boot, start:0xc800, size:0x14000
GPT part:  7, name:         recovery, start:0x20800, size:0x36000
GPT part:  8, name:           backup, start:0x56800, size:0xba000
GPT part:  9, name:            cache, start:0x110800, size:0xc0000
GPT part: 10, name:         metadata, start:0x1d0800, size:0x8000
GPT part: 11, name:    baseparameter, start:0x1d8800, size:0x800
GPT part: 12, name:            super, start:0x1d9000, size:0x614000
GPT part: 13, name:         userdata, start:0x7ed000, size:0x1531fdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
Trust Addr:0x6000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0x10aad0
RunBL31 0x40000 @ 315316 us
NOTICE:  BL31: v1.3(release):845ee93
NOTICE:  BL31: Built : 15:51:11, Jul 22 2020
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1196): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-278-gef70f120a #zhangzj #9 Fri Sep 17 09:39:24 UTC 2021 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09 #orangepi (Sep 14 2022 - 19:19:13 +0800)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2, raw, 0xff1a0000
DRAM:  3.8 GiB
Sysmem: init
Relocation Offset: f5a70000
Relocation fdt: f3c642c0 - f3c66cdb
CR: M/C/I
Using default environment
DM: v1
dwmmc@fe320000: 1, sdhci@fe330000: 0
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
boot mode: None
Android 12.0, Build 2022.6, v2
Found DTB in boot part
DTB: rk-kernel.dtb
HASH(c): OK
ANDROID: fdt overlay OK
I2c0 speed: 400000Hz
PMIC:  RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 1100000 uV
warning: bad baseparameter
Model: OrangePi 4 LTS
Rockchip UBOOT DRM driver version: v1.0.1
I2c7 speed: 100000Hz
Monitor has basic audio support
hdmi info isn't saved in main block
mode:1920x1080
hdmi@ff940000:  detailed mode cloc 148500 kHz, flags[5]
    H: 1920 2008 2052 2200
    V: 1080 1084 1089 1125
bus_format: 2025
CEA mode used vic=16
final pixclk = 148500000 tmdsclk = 148500000
xfer: num: 2, addr: 0x54
xfer: num: 1, addr: 0x54
[dw_hdmi_i2c_write] write offset 21 success
PHY powered down in 0 iterations
PHY PLL locked 1 iterations
sink has audio support
hdmi_set_clk_regenerator: fs=48000Hz ftdms=148.500MHz N=6144 cts=148500
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  aplll 816000 KHz
  apllb 816000 KHz
  dpll 856000 KHz
  cpll 24000 KHz
  gpll 800000 KHz
  npll 600000 KHz
  vpll 148000 KHz
  aclk_perihp 133333 KHz
  hclk_perihp 66666 KHz
  pclk_perihp 33333 KHz
  aclk_perilp0 266666 KHz
  hclk_perilp0 88888 KHz
  pclk_perilp0 44444 KHz
  hclk_perilp1 100000 KHz
  pclk_perilp1 50000 KHz
Net:   eth0: ethernet@fe300000
Hit key to stop autoboot('CTRL+C'):  0
ANDROID: reboot reason: "(none)"
optee api revision: 2.0
TEEC: Reset area[0] info...
TEEC: Reset area[1] info...
Vboot=0, AVB images, AVB verify
read_is_device_unlocked() ops returned that device is UNLOCKED
avb_slot_verify.c:762: ERROR: vbmeta: Error verifying vbmeta image: OK_NOT_SIGNED
get image from preloaded partition...
Could not find "system" partition
Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000...
Fdt Ramdisk skip relocation
## Booting Android Image at 0x0027f800 ...
Kernel: 0x00280000 - 0x01e5d010 (28533 KiB)
ramdisk:    0x0a200000 - 0x0a34d708 (1334 KiB)
## Flattened Device Tree blob at 0x08300000
   Booting using the fdt blob at 0x08300000
   XIP Kernel Image from 0x00280000 to 0x00280000 ... OK
   kernel loaded at 0x00280000, end = 0x01e5d010
  'reserved-memory' ramoops@110000: addr=110000 size=f0000
   Using Device Tree in place at 0000000008300000, end 000000000831d220
failed to reserve drm-cubic-lut memory
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x0a200000 - 0xf8000000 (size: 0xede00000)
Total: 840.79 ms
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 4.19.232 (orangepi@ubuntu) (Android (7284624, based on r416183b) clang version 12.0.5 (https://android.googlesource.com/toolchain/llvm-project c935d99d7cf2016289302412d708641d52d2f7ee), LLD 12.0.5 (/buildbot/src/android/llvm-toolchain/out/llvm-project/lld c935d99d7cf2016289302412d708641d52d2f7ee)) #14 SMP PREEMPT Thu Sep 1 11:19:51 CST 2022
[    0.000000] Machine model: OrangePi 4 LTS
[    0.000000] earlycon: uart8250 at MMIO32 0x00000000ff1a0000 (options '')
[    0.000000] bootconsole [uart8250] enabled
console:/ $ INF USER-TA:read_data_from_uboot_ta:661: (read_data_from_uboot_ta) filename(security_partition) !
ERR [0x1] TEE-CORE:ree_fs_open:1492: tee file not exists
ERR USER-TA:read_data_from_uboot_ta:689: TEE_InvokeTACommand returned 0xffff0000
INF USER-TA:TA_OpenSessionEntryPoint:341: Hello Rockchip Keymaster! rpmb :1
ERR [0x0] TEE-CORE:ree_fs_open:1492: tee file not exists
INF USER-TA:TA_InvokeCommandEntryPoint:2132: -------1111-----TA_InvokeCommandEntryPoint------105
INF USER-TA:TA_OpenSessionEntryPoint:96: Hello Rockchip Weaver! rpmb :1
INF USER-TA:TA_OpenSessionEntryPoint:114: Hello Rockchip gatekeeper! rpmb :1
and this is how it looks when official image is used:
In
channel 0
CS = 0
MR0=0x18
MR4=0x3
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x3
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x3
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x3
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
ChipType = 0x10, 352
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=14928MB
StorageInit ok = 108458
SecureMode = 0
recovery gpt...
GPT part:  0, name: EFI System Partition, start:0x28, size:0x64000
GPT part:  1, name:                 , start:0x64800, size:0x1cc3000
recovery gpt success!
no find partition:uboot.
Trust Addr:0x4000, 0x58334c42
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xb5130
RunBL31 0x40000 @ 288354 us
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    SPSR = 0x3c9
U-Boot 2020.10-orangepi (Aug 01 2022 - 13:34:32 +0800)
Model: OrangePi 4 AI board
DRAM:  3.9 GiB
PMIC:  RK808
MMC:   mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
3341 bytes read in 9 ms (362.3 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
159 bytes read in 7 ms (21.5 KiB/s)
21540756 bytes read in 1823 ms (11.3 MiB/s)
10807969 bytes read in 920 ms (11.2 MiB/s)
102595 bytes read in 22 ms (4.4 MiB/s)
2698 bytes read in 16 ms (164.1 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
   Uncompressing Kernel Image
Moving Image from 0x2080000 to 0x2200000, end=40e0000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Data Size:    21540692 Bytes = 20.5 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f4a99000, end f5f23f54 ... OK
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Loading Device Tree to 00000000f4a17000, end 00000000f4a98fff ... OK
Starting kernel ...
Orange Pi 3.0.6 Focal ttyS2
orangepi4-lts login: orangepi
Password:
Login incorrect
orangepi4-lts login: admin
Password:
Login incorrect
Login timed out after 60 seconds.
Password:
Login incorrect
Password:
  ___  ____ ___   _  _     _   _____ ____
 / _ \|  _ \_ _| | || |   | | |_   _/ ___|
| | | | |_) | |  | || |_  | |   | | \___ \
| |_| |  __/| |  |__   _| | |___| |ocal with Linux 5.10.43
System load:   35%           	Up time:       4 min
Memory usage:  17% of 3.77G  	IP:
CPU temp:      78°C           	Usage of /:    19% of 14G
[ 0 security updates available, 2 updates total: apt upgrade ]
Last check: 2022-08-01 06:00
[ General system configuration (beta): orangepi-config ]
orangepi@orangepi4-lts:~$
so question appears, why none of releases did not work? why only official image? then the point of those images existing? or my OPi4LTS is broken?
Edited by acupofchicory
  • Solution
This image:
5b7b6e973a920094a91297e1b8f07a2352bb67da48e925652a75c58c185a576e Armbian_26.2.1_Orangepi4-lts_trixie_current_6.18.8_minimal.img.xz
uses U-Boot version:
U-Boot 2025.10-rc5_armbian-2025.10-rc5-S2f2a-P4b2d-H8e96-V50db-B2eb2-R448a (Feb 01 2026 - 04:45:24 +0000)
BUT, it seems your board has an older U-Boot version stored somewhere, and the one form vendor is again a different version.
For Rockchip SoC's, it is known that old U-Boot (from the vendor) does not work with new Armbian mainline based kernels. That 2025.10-rc5 version should work with 6.18 kernels, but if the board will likely start with that old U-Boot, skipping what is on the SD-card. You need to wipe SPI-flash and/or eMMC, so the only option is load the U-Boot from SD-card.
You can use the working vendor image to do wipe operations. Make sure you know how dd works. Use sudo lsblk to see what devices are there.
vendors tend to use outdated boot loaders from the ages on all their stuff which makes them compatible with their own (also in most cases outdated) stuff.
Armbian follows mainline. Either the old boot loader stuff cannot handle the chain-load the modern world or it is made in purpose ("vendor lock-in"). We may never know.....
it was this! after i booted from official OS i erased first 4mb of emmc to make it un-bootable. and i finally could load from armbian system
