[CNX-Software] - MangoPi MQ Quad SBC – Allwinner H616 meets Raspberry Pi Zero W form factor
MangoPi MQ Quad Allwinner H616 SBC
MangoPi MQ Quad is an Allwinner H616 quad-core Arm Cortex-A53 SBC following Raspberry Pi Zero W form factor, and the company’s earlier MangoPi MQ Pro RISC-V SBC featuring the Allwinner D1 processor. The MangoPi MQ Quad also comes with 1GB RAM, a mini HDMI output, two USB Type-C ports, WiFI 4 and Bluetooth connectivity, a microSD card, as well a 40-pin Raspberry Pi-compatible GPIO header and an FPC connector with USB, Ethernet, and more GPIOs for expansion. MangoPi MQ Quad specifications: SoC – Allwinner H616 quad-core Cortex-A53 @ 1.5GHz with Mali-G31 MP2 GPU with OpenGL 3.2, Vulkan 1.1, OpenCL 2.0 API support System Memory – 1GB DDR3L Storage – MicroSD card slot, a footprint for SPI flash (on the bottom of the board) Video Output – Mini HDMI 2.0 port up to 4Kp60 Connectivity – 802.11 b/g/n WiFi 4 and Bluetooth 4.2 via RTL8723DS; ceramic and u.FL antennas included USB [...]
The post MangoPi MQ Quad SBC – Allwinner H616 meets Raspberry Pi Zero W form factor appeared first on CNX Software - Embedded Systems News.
View the full article
I just got one, but have no idea if that would start with the OrangePi Zero2 image, and what library I should use for the GPIO.
@gounthar Did you managed to run OrangePi Zero2 image on the MangoPi MQ Quad?
This board looks promising, build quality is nice, and performance should be aloso good, but software support is really poor.
It does not start with
Armbian_23.02.0-trunk_Orangepizero2_sid_edge_6.1.6.img/Armbian_23.02.0-trunk_Orangepizero2_sid_edge_6.1.6_minimal.img
nor with
Armbian_22.11.3_Orangepizero2_bullseye_edge_6.1.4_minimal.img
That was maybe not the best idea I ever had. 🤔
Edited by gounthar
The supplied Debian image boots and starts an X session, but my USB-C hub (with Ethernet) is not recognized (it works with the RISC-V Nezha build from @balbes150), and my WaveShare hat (with USB and Ethernet) neither.
I'm kind of stuck, as I would like to add an existing WiFi network and get rid of all cables but the power. 🤷‍♂️
