gooparm Posted September 8, 2022 Posted September 8, 2022 Actuaylly, I have a two problem. First is, If I print large outputs, It's out was unpredictable. $PS1 randomly added ...snip... ], "locs": [ "ALX", "SOP", "PNX", "NYC" ], "jbound": "0.010000", "tbound": "0.05" } ] } 20220908.04:53:56 root@openskyr2s:~# , <<<<<<--------------------- really randomly appeared my $PS1 in output / Even I use less/more, it sometimes happens. "val1": 4, "val2": 0, "subkey1": [ "blah" ], "filters": [ ...snip... Second is, Prints large outputs(jq , cat) to default console few times, I completely can not execute 'htop' or 'mesg'. If I change $TERM linux to xterm-256color, 'htop' works again. But still 'mesg' commands hung. Above two issue was not resolved apt update/upgrade. - dmesg was clean - stty ixon/ixoff, add delays - seterial low_latency What I tried above, it does not helped output stability. Here is my stty conf 20220908.05:14:06 root@openskyr2s:~# cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=nanopi-r2s BOARD_NAME="Nanopi R2S" BOARDFAMILY=rockchip64 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=13f5fba13 VERSION=22.05.3 LINUXFAMILY=rockchip64 ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image BRANCH=current 20220908.05:14:15 root@openskyr2s:~# uname -a Linux openskyr2s 5.15.52-rockchip64 #22.05.4 SMP PREEMPT Mon Jul 4 09:40:29 CEST 2022 aarch64 GNU/Linux 20220908.05:14:20 root@openskyr2s:~# stty -a speed 1500000 baud; rows 57; columns 227; line = 0; intr = ^C; quit = ^\; erase = ^?; kill = ^U; eof = ^D; eol = <undef>; eol2 = <undef>; swtch = <undef>; start = ^Q; stop = ^S; susp = ^Z; rprnt = ^R; werase = ^W; lnext = ^V; discard = <undef>; min = 1; time = 0; -parenb -parodd -cmspar cs8 hupcl -cstopb cread -clocal -crtscts -ignbrk -brkint -ignpar -parmrk -inpck -istrip -inlcr -igncr icrnl -ixon -ixoff -iuclc -ixany -imaxbel iutf8 opost -olcuc -ocrnl onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0 isig icanon -iexten echo echoe echok -echonl -noflsh -xcase -tostop -echoprt echoctl echoke -flusho -extproc 20220908.05:14:22 root@openskyr2s:~# Any suggestions, solutions are welcome.
