bee395 Posted September 9, 2022 Share Posted September 9, 2022 Hey all, I'm unable to boot Armbian from the SD card of my Radxa Zero 1 GB. When I download one of the official Armbian Radxa Zero images I always get the message "ALERT! UUID=eba52b2e-b77a-47b9-9619-ebda85946883 does not exists. Dropping to a shell!" Previously I ask the Radxa community on Discord, were I received the suggestion that the CMA memory maybe was configured too high. I tried to make an image from master (4b21499534, after https://github.com/armbian/build/pull/4151 was merged) but that didn't help. When I run `dmesg` I get the following repeating error "mmc1: error -84 whilst initialising SD card" When I run `blkid` I do not get any output But when I insert the SD card in my laptop and run `blkid` I get: "/dev/sda1: LABEL="armbian_root" UUID="eba52b2e-b77a-47b9-9619-ebda85946883" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="9a366be2-01" So the uuid seems to be correct. I'm not able to boot into Armbian, but the official non-Armbian images from the Radxa site work just fine on this device with the same SD card. Does anybody know what could be the problem, or any ideas how it can be solved? (The file upload was not working for me, so this is a link to the screenshot image: https://imgur.com/a/UPakZPm) 0 Quote Link to comment Share on other sites More sharing options...
Luis_D Posted January 10, 2023 Share Posted January 10, 2023 Hello bee395, what kind of SD-card do you use? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted January 10, 2023 Share Posted January 10, 2023 This was most likely solved by now, but don't have a device to test. @monkaBlyat @Yakov 0 Quote Link to comment Share on other sites More sharing options...
Yakov Posted January 10, 2023 Share Posted January 10, 2023 I was able to boot Armbian on Radxa Zero only with built-in flash memory (2 and 4 GB versions). 1 GB and 512 MB versions constantly reload on boot. I tried several SD cards (SanDisk, Adata, Samsung and noname), cards running on 2 and 4 GB versions do not run on 0.512 and 1 GB boards. I have on hand 512 MB, 2 and 4 GB versions of the boards. How can I help? https://armbian.atlassian.net/browse/AR-1148 1 Quote Link to comment Share on other sites More sharing options...
Yakov Posted January 10, 2023 Share Posted January 10, 2023 The last image that normally boots on the 512 MB version of the boards is: Armbian_21.08.0-trunk_Radxa-zero_focal_current_5.10.58_xfce_desktop.img 0 Quote Link to comment Share on other sites More sharing options...
Sajeev Sankaran Posted March 29 Share Posted March 29 dear sir, I tried this image but keeps on rebooting on radxa zero 512mb non emcc version. currently only manjaro Gnome is the only one that partially works. always freezes on manjaro. Is there a known fix Regards Sajeev 0 Quote Link to comment Share on other sites More sharing options...
