can't change network under openmediavault and no linux header
Hello, first of all thank you for the development of the Armbian software. I am currently using version Armbian_22.08.2_Uefi-x86_bullseye_current_5.15.69 on my Terramaster F5-221.
Unfortunately I have two small problems. Firstly, there is no linux header for the kernel used for compiling.
Secondly, unfortunately I can't add a network interface in openmediavault. That always gives me an error. It works on Debian with Openmediavault. unfortunately this surprises me.
Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; omv-salt deploy run --no-color systemd-networkd 2>&1' with exit code '1': NAS-Steinke:
In the name of all developers, maintainers and support staff, thank you!
We can't have universal approach as x86 is yet another hardware family. Via armbian-config -> software or
apt install linux-headers-current-x86
I don't know what they use - systemd networking, network manager, netplan on top of something, ifupdown ... ? Our default is Network Manager, so not so skilled user can easily set it up.
The problem with the newtwork manager from armbian is the missing wake on lan function.
The linux header is running under ubuntu but not unde debian. under debian, i get an error, that the compiler was different. It was compile under ubuntu and not under debian.
i can't download it via armbian-config -> software, because i get an grep error.
AFAIK this feature is no enabled by default. It must work pretty much this way: https://www.lisenet.com/2013/set-up-wake-on-lan-wol-on-a-debian-wheezy-server/
This is known problem and we are developing things toward solution. We produce all different Docker images for that reason https://github.com/armbian/build/pkgs/container/build but what is missing is building header package under each one and store them into different repositories.
Fix for that was just merged https://github.com/armbian/build/pull/4263 and updates are pushing out ASAP.
i have change it and it's work for me.
i have found a nother solution via systemd. I think this solution is easier and i think is also possible to add it to your manager.
https://wiki.ubuntuusers.de/Wake_on_LAN/
Method 1.
