Hi all.
Here my video about the MangoPi MQ-Pro.
It's not powerful, not cheap and not great at anything. But it is nice to see it works.
Everybody started out as a baby. So it now needs to grow.
MangoPi MQ-Pro 1GB
https://bret.dk/armbian-on-the-mangopi-mq-pro/
Armbian Jammy xfce4 5.19
Idle temp           57C
Max temp            63C
Blender NicoD       8h34m
7z b                573
Armbian Jammy 5.19 headless without display or usb connected with wifi
Idle temp           47C
Max temp            50C
Blender NicoD       7h44m
7z b                602
sbc-bench           http://ix.io/4cil
Power consumption idle no USB/Display 1080p        0.2A
Power consumption maxed out no USB/Display 1080p   0.3A
Armbian Sid 5.19 server with display
Idle temp           60C
No blender
7z b                566
Armbian Sid 5.19 server headless
Idle temp           46C
No blender
7z b                575
Power consumption idle no USB/Display 1080p        0.15A
Power consumption maxed out no USB/Display 1080p   0.24A
sd-read          12 MB/s          sd-write         10.3 MB/s       access time     1.07 msec
USB read         21.8 MB/s        USB write        7.6 MB/s        access time     1.08 msec
***SID can't log in with display. Works headless.
***Unstable USB. Doesn't always recognize devices. Must plug multiple times until it works.
***Desktop unstable. Sometimes logs out and restarts a new desktop.
***No browser in Armbian apts
***Doesn't shut down fully
The CPU integrated is the 64-bit XuanTie C906 RICS-V (up to 1GHz)
Furthermore, there is a HiFi4 DSP, a VPU(4K H.265/H264) and 2D graphics acceleration to improve its computing performance.
https://linuxgizmos.com/mangopi-mq-pro-a-possible-20-substitute-to-the-raspberry-pi-zero-w/
https://www.allwinnertech.com/uploads/pdf/2021070515231402.pdf
    Processor System:
        ‧SoC  Allwinner D1 XuanTie C906 RISC-V processor (up to 1GHz)
        HiFi4 DSP
        G2D 2D graphics accelerator
    Memory/storage:
        512MB (model MPi-MQ1PL)/1GB DDR3 (model MPi-MQ1PH)
    Networking:
        2.4Ghz 802.11b/g/n Wi-Fi 4
        Bluetooth 4.2 via RTL8723DS module + u.FL antenna connector
        Ethernet via expansion board connected to 24-pin connector
    Display/Audio:
        1x mini HDMI 1.4 port (up to 1080p60 or 4Kp30)
        20x Pin DSI/CTP/LVDS FPC connector
        24x Pin DVP/RGMII connector
        Audio out pads
    Other I/O:
        1x USB OTG Type-C port
        1x USB host Type-C port
    Expansion:
        40x pins Raspberry Pi compatible GPIO header
    Power:
         5V – USB Type-C port
    Dimensions:
        65 x 30 mm
 Additionally, the specifications for the Allwinner D1 processor are listed below:
    CPU Architecture:
        XuanTie C906 64bit RISC-V core (32 KB I-cache + 32 KB D-cache)
    DSP Architecture:
        HiFi4 DSP 600MH (32 KB I-cache + 32 KB D-cache, 64 KB I-ram + 64KB D-ram)
    Memory/Storage:
        2GB DDR2/DDR3(533MHz for DDR2/800MHz for DDR3)
        SD 3.0, eMMC 5.0, SPI Nor/NAND Flash
    Networking:
        10/100/1000M EMAC with RMII and RGMII interfaces
    Video Engine:
        Video decoding
            H.265 up to 4K@30fps/1080p@60fps
            H.264 up to 4K@24fps/1080p@60fps
            MPEG-1/2/4, JPEG, VC1 up to 1080p@60fps
            MJPEG up to 1080p@30fps
        Video encoding
            JPEG/MJPEG up to 1080p@60fps
            Supports input picture scaler up/down
    Video OUT:
        RGB LCD interface with DE/SYNC mode up to 1920 x 1080@60fps
        Dual link LVDS interface up to 1920 x 1080@60fps
        Single link LVDS interface up to 1366 x 768@60fps
        4-lane MIPI DSI interface up to 1920 x 1080@60fps
        HDMI 1.4b output interface up to 4K x 2K video format
        CVBS OUT interface, supports NTSC/PAL format; 10 bits DAC output
    Video IN:
        8-bit parallel CSI digital camera interface
        CVBS IN interface, supports NTSC/PAL format; 10-bit ADCs
    Audio:
        2x DACs (16-bit and 20-bit sample resolution)
        8KHz to 192KHz DAC sample rate
        3x ADCs (16-bit and 20-bit sample resolution)
        8KHz to 48KHz ADC sample rate
        Analog audio interfaces
            MICIN1P/N, MICIN2P/N, MICIN3P/N, FMINL/R, LINEINL/R,
            LINEOUTLP/N, LINEOUTRP/N, HPOUTL/R
        Digital audio interfaces
            I2S/PCM, DMIC, One Wire Audio IN/OUT
    Other I/O:
        USB2.0 OTG
        USB2.0 Host
        SDIO 3.0
        2x SPI
        6x UART
        4x Two Wire Interface
    Misc:
        PWM (8-ch)
        GPADC (2-ch)
        LRADC (1-ch)
        TPADC (4-ch)
        IR TX/RX
    Package:
        LFBGA 337 Pins (13mm x 13mm)
Price : 40euro with shipping
https://nl.aliexpress.com/item/1005004157984532.html?gatewayAdapt=4itemAdapt
