Hqnicolas Posted November 19, 2022 Author Share Posted November 19, 2022 (edited) On 11/17/2022 at 11:12 PM, tmm1 said: Does /dev/dri actually exist? Yes, it's working fine on my ubuntu 20.04 Kernel 4.19.219 RK3566 H96MAX (DELETED FILE DUE DEPRECATED KERNEL4) , I use /dev/dri/renderD128 on Tdarr to ffmpeg videos over lan to h264 mp4. What you trying to do? 👀 Be sure thar your device have Vaapi capable on chip be sure that you kernel SDK have drivers to run it be sure that your DTS / DTB shows where the Api Run and How it Run. Edited June 15, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
tmm1 Posted November 19, 2022 Share Posted November 19, 2022 I don't have RK3566 box yet, but waiting on one to arrive soon (tomorrow 🤞). So with 4.19 rockchip kernel, the hardware venc is available via vaapi? Can you share the output of `vainfo`? 0 Quote Link to comment Share on other sites More sharing options...
jeffbouchard Posted November 19, 2022 Share Posted November 19, 2022 (edited) I have H96 MAX RK3566 but 8GB I imagine it will run the same, do you know? they are still Android rooted I want to make them as pure Linux as possible Thanks downloading Edited November 19, 2022 by jeffbouchard 0 Quote Link to comment Share on other sites More sharing options...
tmm1 Posted November 19, 2022 Share Posted November 19, 2022 @hotnikq BTW doesn't rockchip have official 5.10 kernel also? https://github.com/rockchip-linux/kernel/tree/develop-5.10 Maybe it can help with your HDMI issue. In my area I only found one "RUPA" box with RK3566 available for quick delivery. But it seems on Ali there are many options now: X96 X6 H96 MAX V56 X88 PRO 20 HK1 RBOX R2 T95 1 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 19, 2022 Author Share Posted November 19, 2022 (edited) @tmm1 you were right, it is not possible to allocate memory to the device, I believe that because RKNPU dont work on this compilation. i think ffmpeg fallback to CPU when vaapi fail. driver rknpu version 0.4.2. dont find the RKNPU or memory allocation. /usr/lib/jellyfin-ffmpeg/ffmpeg -v debug -init_hw_device drm=dr:/dev/dri/renderD128 -init_hw_device vaapi=va@dr Edited November 20, 2022 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 19, 2022 Author Share Posted November 19, 2022 (edited) @tmm1 can you work around the DTS / DTB file to make RKnpu working on this device? i think it's about rknpu_reserved memory it's different from android Linux use iommu to load rknpu the SDK to compile is the Pine64 Custom Partition Parameter.txt Quote FIRMWARE_VER: 1.0 MACHINE_MODEL: RK3568 MACHINE_ID: 007 MANUFACTURER: RK3568 MAGIC: 0x5041524B ATAG: 0x00200800 MACHINE: 0xffffffff CHECK_MASK: 0x80 PWR_HLD: 0,0,A,0,1 TYPE: GPT CMDLINE: mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(misc),0x00010000@0x00008000(boot),0x00010000@0x00018000(recovery),0x00010000@0x00028000(backup),-@0x00038000(rootfs:grow) uuid:rootfs=614e0000-0000-4b53-8000-1d28000054a9 Edited November 20, 2022 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 20, 2022 Author Share Posted November 20, 2022 @jeffbouchard to run in a 8gb device you will need to change the MiniLoaderAll.bin as I mention here in this topic 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 20, 2022 Author Share Posted November 20, 2022 @tmm1 can you translate the kernelconfig and DTS to kernel 5 from original kernel 4? 0 Quote Link to comment Share on other sites More sharing options...
tmm1 Posted November 20, 2022 Share Posted November 20, 2022 I think you can use the same kernel config. I'm not sure about DTB. For video encoding, I found someone implemented rkmppenc for ffmpeg here: https://github.com/jjm2473/ffmpeg-rk/commits/enc I'm still waiting for hardware delivery to try it myself 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 20, 2022 Author Share Posted November 20, 2022 @tmm1 currently the execution takes place via iommu and not with memory allocation. to use memory allocation via CMA DMA, you need to disable the iommu framework. and that's a job for another, I don't intend to spend another 30 days on this development. DTS structure: set NPU Quote npu@fde40000 { compatible = "rockchip,rknpu"; reg = <0x00000000 0xfde40000 0x00000000 0x00010000>; interrupts = <0x00000000 0x00000097 0x00000004>; clocks = <0x00000002 0x00000002 0x0000001f 0x00000023 0x0000001f 0x00000028 0x0000001f 0x00000029>; clock-names = "scmi_clk", "clk", "aclk", "hclk"; assigned-clocks = <0x0000001f 0x00000023>; assigned-clock-rates = <0x23c34600>; resets = <0x0000001f 0x0000002b 0x0000001f 0x0000002c>; reset-names = "srst_a", "srst_h"; power-domains = <0x00000021 0x00000006>; operating-points-v2 = <0x0000005d>; iommus = <0x0000005e>; status = "okay"; rknpu-supply = <0x0000005f>; phandle = <0x00000171>; set Power domain to NPU Quote power-management@fdd90000 { compatible = "rockchip,rk3568-pmu", "syscon", "simple-mfd"; reg = <0x00000000 0xfdd90000 0x00000000 0x00001000>; phandle = <0x00000170>; power-controller { compatible = "rockchip,rk3568-power-controller"; #power-domain-cells = <0x00000001>; #address-cells = <0x00000001>; #size-cells = <0x00000000>; status = "okay"; phandle = <0x00000021>; pd_npu@6 { reg = <0x00000006>; clocks = <0x0000001f 0x00000027 0x0000001f 0x00000025 0x0000001f 0x00000026>; pm_qos = <0x00000045>; }; iommu NPU Quote iommu@fde4b000 { compatible = "rockchip,iommu-v2"; reg = <0x00000000 0xfde4b000 0x00000000 0x00000040>; interrupts = <0x00000000 0x00000097 0x00000004>; interrupt-names = "rknpu_mmu"; clocks = <0x0000001f 0x00000028 0x0000001f 0x00000029>; clock-names = "aclk", "iface"; power-domains = <0x00000021 0x00000006>; #iommu-cells = <0x00000000>; status = "okay"; phandle = <0x0000005e>; }; 0 Quote Link to comment Share on other sites More sharing options...
tmm1 Posted November 20, 2022 Share Posted November 20, 2022 You're trying to use vaapi driver which is deprecated: http://rockchip.wikidot.com/rockchip-va-driver I think rkmppenc from ffmpeg-rk will have better results. I will try it soon. 0 Quote Link to comment Share on other sites More sharing options...
tmm1 Posted November 20, 2022 Share Posted November 20, 2022 21 hours ago, tmm1 said: BTW doesn't rockchip have official 5.10 kernel also? https://github.com/rockchip-linux/kernel/tree/develop-5.10 Maybe it can help with your HDMI issue. sorry I was mistaken about this. apparently 5.10 tree is only for rk5688 https://github.com/JeffyCN/mirrors/issues/2#issuecomment-1006208918 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 20, 2022 Author Share Posted November 20, 2022 (edited) 5 hours ago, tmm1 said: sorry I was mistaken about this. apparently 5.10 tree is only for rk3588 https://github.com/JeffyCN/mirrors/issues/2#issuecomment-1006208918 Rk3566 run Kernel 5, you just need to translate the device tree, look at the quartz64a and firefly station P2, M2. Edited November 20, 2022 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 22, 2022 Author Share Posted November 22, 2022 (edited) Release Version v0.3 BETA ❎ No Video out (device tree bad arg) ❎ No Virtualization (kernel config) ❎ No Docker (kernel capability) H96 MAX RK3566 Board V56 Kernel 4.19.219 Linux FIT Image Rockchip EMMC Ubuntu 20.04 LTS This image has been compiled without any standardization and should be used for experimental purposes only, there is no guarantee of compatibility with your device Download Link: DELETED FILE DUE DEPRECATED KERNEL4 👈 Download Link: DELETED FILE DUE DEPRECATED KERNEL4 👈 This FIT image needs to be flashed on the internal storage, this board don't have SD CARD Reader. Just Press the RESET Button when connect male-male USB 2.0 (BLACK) to Desktop MAKE Backup Rockchip Firmware emmc Install Drivers, Driver Assistant Download RkDevTool Download Upgrade Rockchip Firmware eemc Maskrom mode Loader mode when the Board Boot UP you will need to conect RJ45 LAN, Find the IP Addres on your PiHole, Firewall or Lan Router and SSH to the ubuntu. Quote User: ubuntu Password: ubuntu First BOOT COMANDS: Quote ### Partition " / " resized to FULL DISK ### $ df -h sudo resize2fs /dev/mmcblk2p6 $ df -h 🏆 help to add this board in armbian standart, you don't need to be a programmer to help the community, just need a copy of the V56 board and a x86 computer to compile new versions. Base Parameters to build: H96-MAX-Uboot-legacy.img Partition-Parameter.txt H96-MAX-8gb-MiniLoaderAll.bin H96-MAX-4gb-MiniLoaderAll.bin DTB + DTS + rockchip_defconfig SDK Used into this Build: SDK 4.19.219 LINUX to RK3566 H96 MAX Please, Use a debug Tool TTL UART Baud rate: 1500000 Data bit: 8 Stop bit: 1 Parity check: none Flow control: none ☑️ CP2104 TTL Tested! ☑️ CP2102 TTL Tested! ☑️ CP210X TTL Tested! Rockchip boards are unbrikable in a worse case you need to short the EMMC CLK pin to GND on the other side of the board and upload the righ LoaderALL.bin File from a linux machine that you backup. to connect the RK3566 on Desktop USB Maskrom Mode. @tmm1 @Walma @mvpwar @Carol Let's debug it! Edited June 15, 2023 by hotnikq 2 Quote Link to comment Share on other sites More sharing options...
tmm1 Posted November 22, 2022 Share Posted November 22, 2022 13 hours ago, hotnikq said: H96-MAX-8gb-MiniLoaderAll.bin H96-MAX-4gb-MiniLoaderAll.bin how did you find these? 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 22, 2022 Author Share Posted November 22, 2022 (edited) @tmm1 as i mentioned for the russians. Find your Backup ROM or download from WEB. "4G-RK3566_userdebug_H96_Max_RK3566_11_20210810.1920.img" "8G-RK3566_userdebug_H96_Max_RK3566_11_20210421.2051.img" extract the image using the "windows" app or use it on "linux" app $ imgRePackerRK.exe /cid /2nd /debug /log update.img imgRePackerRK_107h_test imgRePackerRK_107m_test imgRePackerRK_107 Under Linux extract image: Quote $ sudo ./imgrepackerrk /cid imagefile.img 👆👆 it was solved by RedScorpio From XDA inside the extracted ROM image folder of your device, you will find the file MiniLoaderAll.bin Edited May 2 by Hqnicolas 1 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 22, 2022 Author Share Posted November 22, 2022 @tmm1 are you working on a 4gb or 8gb box? did you have a TTL UART tool to debug? 0 Quote Link to comment Share on other sites More sharing options...
tmm1 Posted November 22, 2022 Share Posted November 22, 2022 The box I found is RUPA 4GB RK3566. It had a SD card port so I realized it's more similar to T95 Plus. I tried the firmware from t95plus.com and it is working with HDMI. I will try to find a H96 Max V56 also to help out. I assume you already tried t95 firmware and it doesn't boot on your device? I am very interested in 5.10 kernel (for docker) and video encoding with rkmppenc on this chipset. 0 Quote Link to comment Share on other sites More sharing options...
tmm1 Posted November 22, 2022 Share Posted November 22, 2022 2 hours ago, hotnikq said: did you have a TTL UART tool to debug? I have one (CP2102N) but I have to learn how to use it. I guess I have to open the box to be able to connect it? When I tried 5.10 image it didn't boot so I need to attach debug next to make better progress. Unfortunately it is now the holiday season so I will be traveling for the next week. 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted November 23, 2022 Author Share Posted November 23, 2022 (edited) @tmm1 T95 is a much easier box to work with as it is more widespread among users, I have already tried their firmware, very incompatible. UART TTL debug needs to be soldered on board pins RX-TX and TX-RX, GND-GND. RUPA 4GB RK3566 makes me fell X88 Pro 20 Rk3566 i'm runing jellyfin and nextcloud at H96 MAX V56 RK3566 Kernel 4.19 SATA3 Devices at Full speed on USB3 HUB, Gigabit Ethernet, I dont need HDMi on this device and i dont expect full GPU acceleration with this. it's fine to a 60U$ TV box to run as proxy / data / DNS service. Today i received the H96 MAX RK3318 V12 4gb/64gb and soon will arrive here a Rock Pi 3a 8GB/ with NVME board EDIT: RK3318, RK3328 is to slow 4core 1ghz DDR3 "fast ethernet 10/100mb" Tested: kernel 5.15 and 6.09 EDIT: RK3566 with kernel 4.19 still a better througput speed over USB-SATA and Lan link Edited November 23, 2022 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
tmm1 Posted December 1, 2022 Share Posted December 1, 2022 I received the box. How can I open it? I didn't find the screws. 0 Quote Link to comment Share on other sites More sharing options...
mvpwar Posted December 1, 2022 Share Posted December 1, 2022 Quote This FIT image needs to be flashed on the internal storage, this board don't have SD CARD Reader. Just Press the RESET Button when connect male-male USB 2.0 (BLACK) to Desktop MAKE Backup Rockchip Firmware emmc Install Drivers, Driver Assistant Download RkDevTool Download Upgrade Rockchip Firmware eemc Maskrom mode Loader mode Make backup fail by rkDumper v1.1.1.2(latest) How did you backup? "short the EMMC CLK pin to GND"? Thanks!! Found: LOADER device (RK3566 2207:350a) #9 --- Firmware dumping --- Found LOADER Rockchip device First 0x0010 NAND blocks reading Command to read failed -- Rockchip device resetting -- Found LOADER Rockchip device Command to reset failed DriverAssitant_v4.91 (the same error at v5.11) rkDumper 1.1.1.2 (1.08 no support rk3566) 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted December 1, 2022 Author Share Posted December 1, 2022 (edited) Today i received Rock 3A rk3568 User interface X11 Feels Laggy "dont have hardware acceleration to" Mali Panfrost drivers are not Opensource for linux, just android Manjaro-ARM-gnome-rock3a-22.10 Works Amazing with hardware acceleration on Rock 3A rk3568 Desktop for desktop environment i recomend the original Android or LibreElec "android" for server, we are on the right path here! @tmm1 you need to slide the bottom of the box with plastic straws to find the screws. @mvpwar to backup, i use linux, i think windows drivers for RK35xx are outdated, I didn't stop to see this To backup Quote $ sudo rkdeveloptool -h $ sudo rkdeveloptool rl 0 9999999 dump_with_rk_tool.img #### change 9999999 to the number of sectors from your flash To Restore Quote $ sudo rkdeveloptool wl 0 dump_with_rk_tool.img Edited December 1, 2022 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
mvpwar Posted December 2, 2022 Share Posted December 2, 2022 @hotnikq thx 0 Quote Link to comment Share on other sites More sharing options...
mvpwar Posted December 2, 2022 Share Posted December 2, 2022 #rkdeveloptool rfi Flash Info: Manufacturer: SAMSUNG, value=00 Flash Size: 59640 MB Flash Size: 122142720 Sectors Block Size: 512 KB Page Size: 2 KB ECC Bits: 0 Access Time: 40 Flash CS: Flash<0> #rkdeveloptool rl 0 122142720 h96_max_flash.img Read LBA to file (100%) #ll -h h96_max_flash.img -rw-r--r-- 1 root root 59G 12月 2 22:32 h96_max_flash.img How to flash PARTITIONING.img<Ubuntu_20.04.5_K4.19.219_RK3566_H96_MAX_8GB_No_Video_OUT_WIFI_OK_PARTITIONING.img> to internal storage ? Use rkdeveloptool wl ? WriteLBA: wl <BeginSec> <File> WriteLBA: wlx <PartitionName> <File> WriteGPT: gpt <gpt partition table> WriteParameter: prm <parameter> I found the FIT PARTITIONING.img is quite different from my backup img file when using fdisk command to list the partitions Disk Ubuntu_20.04.5_K4.19.219_RK3566_H96_MAX_8GB_No_Video_OUT_WIFI_OK_PARTITIONING.img:6.92 GiB,7430220288 字节,14512149 个扇区 单元:扇区 / 1 * 512 = 512 字节 扇区大小(逻辑/物理):512 字节 / 512 字节 I/O 大小(最小/最佳):512 字节 / 512 字节 磁盘标签类型:dos 磁盘标识符:0x38e8005b Disk h96_max_flash.img:58.24 GiB,62537072640 字节,122142720 个扇区 单元:扇区 / 1 * 512 = 512 字节 扇区大小(逻辑/物理):512 字节 / 512 字节 I/O 大小(最小/最佳):512 字节 / 512 字节 磁盘标签类型:gpt 磁盘标识符:FA7B0000-0000-4212-8000-216500001AD8 设备 起点 末尾 扇区 大小 类型 h96_max_flash.img1 16384 24575 8192 4M 未知 h96_max_flash.img2 24576 32767 8192 4M 未知 h96_max_flash.img3 32768 40959 8192 4M 未知 h96_max_flash.img4 40960 49151 8192 4M 未知 h96_max_flash.img5 49152 51199 2048 1M 未知 h96_max_flash.img6 51200 133119 81920 40M 未知 h96_max_flash.img7 133120 141311 8192 4M 未知 h96_max_flash.img8 141312 337919 196608 96M 未知 h96_max_flash.img9 337920 1124351 786432 384M 未知 h96_max_flash.img10 1124352 2009086 884735 432M 未知 h96_max_flash.img11 2009087 2041854 32768 16M 未知 h96_max_flash.img12 2041855 2042878 1024 512K 未知 h96_max_flash.img13 2042879 2044926 2048 1M 未知 h96_max_flash.img14 2044927 2077694 32768 16M 未知 h96_max_flash.img15 2077695 9122814 7045120 3.4G 未知 h96_max_flash.img16 9122815 122142686 113019872 53.9G 未知 Should I WriteParameter by Parameter.txt, flash the MiniLoaderAll.bin to Loader, finally flash the FIT PARTITIONING.img to rootfs ? THX! @hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted December 2, 2022 Author Share Posted December 2, 2022 (edited) @mvpwar after backup into linux, to flash the Linux distro inside the box i use a Windows computer The image Type is "UPDATE IMG" is easy to handle on windows Just Flash the whole firmware.img This tutorial is from the Rock 3a i'm working on https://wiki.radxa.com/Rock/flash_the_image but it works on h96 max The linux filesystem used on this project is different from original android filesystem Edited December 2, 2022 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted December 2, 2022 Author Share Posted December 2, 2022 (edited) @mvpwar you be the first to test a 8gb device, please report your experience and application here. ❎ No Video out (device tree bad arg) ❎ No Virtualization (kernel config) ❎ No Docker (kernel capability) This is a "server" image, without display Follow this instructions after flash, to use the machine you will need to SSH inside it. On 11/21/2022 at 11:04 PM, hotnikq said: This FIT image needs to be flashed on the internal storage, this board don't have SD CARD Reader. Just Press the RESET Button when connect male-male USB 2.0 (BLACK) to Desktop MAKE Backup Rockchip Firmware emmc Install Drivers, Driver Assistant Download RkDevTool Download Upgrade Rockchip Firmware eemc Maskrom mode Loader mode when the Board Boot UP you will need to conect RJ45 LAN, Find the IP Addres on your PiHole, Firewall or Lan Router and SSH to the ubuntu. Quote User: ubuntu Password: ubuntu First BOOT COMANDS: Quote ### Partition " / " resized to FULL DISK ### $ df -h sudo resize2fs /dev/mmcblk2p6 $ df -h 🏆 help to add this board in armbian standart, you don't need to be a programmer to help the community, just need a copy of the V56 board and a x86 computer to compile new versions. Edited December 2, 2022 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
mvpwar Posted December 3, 2022 Share Posted December 3, 2022 @hotnikq THX ! Welcome to Ubuntu 20.04.5 LTS (GNU/Linux 4.19.219+ aarch64) * Documentation: https://help.ubuntu.com * Management: https://landscape.canonical.com * Support: https://ubuntu.com/advantage This system has been minimized by removing packages and content that are not required on a system that users do not log into. To restore this content, you can run the 'unminimize' command. 0 updates can be applied immediately. New release '22.04.1 LTS' available. Run 'do-release-upgrade' to upgrade to it. Last login: Sat Dec 3 01:47:41 2022 from 192.168.2.186 ubuntu@rk3566-evb3-ddr3-v10:~$ df -h Filesystem Size Used Avail Use% Mounted on udev 2.0G 0 2.0G 0% /dev tmpfs 394M 1.1M 393M 1% /run /dev/mmcblk2p6 58G 5.9G 49G 11% / tmpfs 2.0G 0 2.0G 0% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup tmpfs 394M 0 394M 0% /run/user/0 tmpfs 394M 4.0K 394M 1% /run/user/1000 ubuntu@rk3566-evb3-ddr3-v10:~$ free -m total used free shared buff/cache available Mem: 3930 167 3122 1 639 3721 Swap: 0 0 0 The Ubuntu os only recognizes 4G memory which flashed the 8G image 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted December 3, 2022 Author Share Posted December 3, 2022 (edited) @mvpwar i think i know what is happend here. is something i make to solve "swiotlb buffer is full" errors i set the kernel memory to 4gb to make the iommu stop address "2⁶⁴" 64bit this kernel trik Stop buffer overflow errors and memory leak you can change it to 8gb i'm searching here how to change it EDIT: i did this You can limit the amount of RAM the kernel addresses by adding this to boot parameters: mem=4096M i make it via DTS File Before compile rk3566-quartz64-a.dts Quote chosen { bootargs = "earlycon=uart8250,mmio32,0xfe660000 swiotlb=8192 mem=4096M console=ttyFIQ0 root=PARTUUID=614e0000-0000-4b53-8000-1d28000054a9 rw rootwait"; i make this change to rk3566-quartz64-a.dtb you can change it and debug, if it doesnt work you can reflash the update image again to repair rk3566-quartz64-a.dtb Edited December 3, 2022 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
mvpwar Posted December 3, 2022 Share Posted December 3, 2022 @hotnikq How to mount the emmc boot partition? root@rk3566-evb3-ddr3-v10:/# ls -l /dev/disk/by-partlabel/boot lrwxrwxrwx 1 root root 15 Dec 3 20:25 /dev/disk/by-partlabel/boot -> ../../mmcblk2p3 root@rk3566-evb3-ddr3-v10:/# mount /dev/mmcblk2p3 /mnt mount: /mnt: wrong fs type, bad option, bad superblock on /dev/mmcblk2p3, missing codepage or helper program, or other error. root@rk3566-evb3-ddr3-v10:/home/ubuntu# find / -name "*.dtb" find: ‘/proc/1507’: No such file or directory or how to replace the dtb file? root@rk3566-evb3-ddr3-v10:/# fdisk -l Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disk /dev/mmcblk2: 58.25 GiB, 62537072640 bytes, 122142720 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 37250000-0000-4851-8000-2F1900005AC0 Device Start End Sectors Size Type /dev/mmcblk2p1 16384 24575 8192 4M unknown /dev/mmcblk2p2 24576 32767 8192 4M unknown /dev/mmcblk2p3 32768 98303 65536 32M unknown /dev/mmcblk2p4 98304 163839 65536 32M unknown /dev/mmcblk2p5 163840 229375 65536 32M unknown /dev/mmcblk2p6 229376 122142655 121913280 58.1G unknown root@rk3566-evb3-ddr3-v10:/etc/grub.d# parted GNU Parted 3.3 Using /dev/mmcblk2 Welcome to GNU Parted! Type 'help' to view a list of commands. (parted) p Model: MMC CJNB4R (sd/mmc) Disk /dev/mmcblk2: 62.5GB Sector size (logical/physical): 512B/512B Partition Table: gpt Disk Flags: Number Start End Size File system Name Flags 1 8389kB 12.6MB 4194kB uboot 2 12.6MB 16.8MB 4194kB misc 3 16.8MB 50.3MB 33.6MB boot 4 50.3MB 83.9MB 33.6MB recovery 5 83.9MB 117MB 33.6MB backup 6 117MB 62.5GB 62.4GB ext4 rootfs (parted) quit 1 Quote Link to comment Share on other sites More sharing options...
