Kenneth Hidalgo Posted June 10, 2023 Share Posted June 10, 2023 Need help 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 11, 2023 Author Share Posted June 11, 2023 23 hours ago, Kenneth Hidalgo said: RkDevTool v2.86 how to change language Drop it on folder config.ini 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 11, 2023 Author Share Posted June 11, 2023 8 hours ago, Kenneth Hidalgo said: Need help you probably downloaded this RKdev from a RADXA forum.... i see this SPL flash before. Just edit it like an Table, righ click left click and let it like the attach file you will need to get the partitions config from device... "Dev Partition" button config.cfg 0 Quote Link to comment Share on other sites More sharing options...
Kenneth Hidalgo Posted June 11, 2023 Share Posted June 11, 2023 Exactly RADXA download 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 11, 2023 Author Share Posted June 11, 2023 @Kenneth Hidalgo after setup your device user and password, please upload armbian debug. sudo armbianmonitor -u send link to this forum thread 0 Quote Link to comment Share on other sites More sharing options...
Kenneth Hidalgo Posted June 11, 2023 Share Posted June 11, 2023 it looks like this 0 Quote Link to comment Share on other sites More sharing options...
Kenneth Hidalgo Posted June 11, 2023 Share Posted June 11, 2023 I can't do the second step 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 11, 2023 Author Share Posted June 11, 2023 (edited) 54 minutes ago, Kenneth Hidalgo said: I can't do the second step uncheck both checkboxes.... by left click them.... righ click on table... create new line. set address by double click it and typing... set name by double click it and typing... it´s an tabble. like office.... or you can simply drop this file on RKdev folder and start the program... config.cfg Edited June 11, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 11, 2023 Author Share Posted June 11, 2023 (edited) i will build an Storage on Cifis Samba connection over gigabit. CasaOS on other device will share the Cifis over web https on Nextcloud. 1x H96 Max v56 1x USB 3.0 HUB 4x USB3 to Sata3 4x HDD 1x Power Supply On Remote server Kernel6 to mount disks at Logon automatically: /etc/fstab //192.168.0.11/fotos /DATA/fotos cifs username=UsErNaMe,password=PASSWORD,iocharset=utf8,file_mode=0777,dir_mode=0777,x-systemd.automount,x-systemd.idle-timeout=60 //192.168.0.11/arquivos /DATA/arquivos cifs username=UsErNaMe,password=PASSWORD,iocharset=utf8,file_mode=0777,dir_mode=0777,x-systemd.automount,x-systemd.idle-timeout=60 On Remote server Kernel5 to mount disks at Logon automatically: /etc/fstab x-systemd.automount,x-systemd.idle-timeout=1min //192.168.0.11/fotos /DATA/fotos cifs username=UsErNaMe,password=DONTWEAKPASSWORD,iocharset=utf8,file_mode=0777,dir_mode=0777 //192.168.0.11/arquivos /DATA/arquivos cifs username=UsErNaMe,password=DONTWEAKPASSWORD,iocharset=utf8,file_mode=0777,dir_mode=0777 Edited June 11, 2023 by hotnikq 1 Quote Link to comment Share on other sites More sharing options...
Kenneth Hidalgo Posted June 12, 2023 Share Posted June 12, 2023 I'm trying but I haven't been able to do it yet, I don't know what I'm doing wrong. I install the update.img and then the rkdev does not appear with that information 0 Quote Link to comment Share on other sites More sharing options...
Kenneth Hidalgo Posted June 12, 2023 Share Posted June 12, 2023 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 12, 2023 Author Share Posted June 12, 2023 (edited) 12 hours ago, Kenneth Hidalgo said: and then the rkdev does not appear with that information rkdev automatically? where you read it? it will never happend... the table need to be edited by hand... Brow.... Just copy the Config.cfg that i posted here...... and drop it on the rkdev folder. it's an table that need to be edited by you.... You will need to edit manually Remove the checkbox from that lines that you have... Your 2 lines that you have is for RADXA DEVICE! Like i said before. On 6/11/2023 at 11:56 AM, hotnikq said: uncheck both checkboxes.... by left click them.... righ click on table... create new line. set address by double click it and typing... set name by double click it and typing... it´s an tabble. like office.... or you can simply drop this file on RKdev folder and start the program... did you ever use any office suite for editing tables? Just copy the Line number 8... Edited June 12, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Kenneth Hidalgo Posted June 13, 2023 Share Posted June 13, 2023 0 Quote Link to comment Share on other sites More sharing options...
Kenneth Hidalgo Posted June 13, 2023 Share Posted June 13, 2023 I still can't do the second step, after doing the first step it tells me "MASKROM device" no Loader 0 Quote Link to comment Share on other sites More sharing options...
Kenneth Hidalgo Posted June 13, 2023 Share Posted June 13, 2023 i do not know what I'm doing 0 Quote Link to comment Share on other sites More sharing options...
Kenneth Hidalgo Posted June 13, 2023 Share Posted June 13, 2023 This is the information of my device with the original image 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 13, 2023 Author Share Posted June 13, 2023 8 hours ago, Kenneth Hidalgo said: I still can't do the second step, after doing the first step it tells me "MASKROM device" no Loader After complete the first step.... disconect the device... push the bottom on the board.... and conect again... release the bottom. do the second step...... 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 13, 2023 Author Share Posted June 13, 2023 8 hours ago, Kenneth Hidalgo said: i do not know what I'm doing watch backup and restore videos for rockchip devices 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 13, 2023 Author Share Posted June 13, 2023 (edited) 8 hours ago, Kenneth Hidalgo said: This is the information of my device with the original image haaa... you droped my config.cfg file finally! on line root.... 0x0000A000 the last Row is "..." where you can select the img file just select the armbian root.img file that you downloaded on tutorial. select write by address and Run... Edited June 13, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
ufsm Posted June 13, 2023 Share Posted June 13, 2023 Greetings Brazilian friend. My box has 8GB of ram. I also soldered the SD card adapter and couldn't via SD with the Wipe file. With the Rockchip image you created, I did the first step successfully. But the second step my device goes into maskrom mode and I can't go on, maybe for the 8Gb model it's a different procedure I apologize if the English is not understandable 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 13, 2023 Author Share Posted June 13, 2023 2 hours ago, ufsm said: I also soldered the SD card adapter and couldn't via SD with the Wipe file. power the device on, and after just a second put the SD card on it...... 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 13, 2023 Author Share Posted June 13, 2023 (edited) On 6/13/2023 at 10:28 AM, ufsm said: I did the first step successfully. now you will need to unplug the device. press the back button with a toothpick and reconnect male to male USB to you computer, ...........Go to step 2 Edited June 14, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 13, 2023 Author Share Posted June 13, 2023 (edited) 3 hours ago, ufsm said: But the second step my device goes into maskrom mode and Please confirm that you flash the first step with the "update.img" file... and disconect the device after flash.... when press the back button with a toothpick and reconnect the device H96 MAX V56 RK3566 need to be reconized. if it return maskrom even when press the back button with a toothpick and reconnect you will need to do the first step again.... Edited June 13, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 14, 2023 Author Share Posted June 14, 2023 (edited) Since v0.7ARMBIAN23 works for me. i will no long test new images, my device is on production stage. I will deliver some alternative root versions within the armbian spheres for you to use in v0.7 step 2. i discovered windows WSL2 + windows terminal + usbipd i'm compiling Linux: Debian 12 "Bookworm" will release it soon as a v0.5DEBIAN12 first "sd-card" and after test.... v0.7DEBIAN12 ROOT PARTITION with 2 trick steps. since kernel v4 to this device is deprecate i will start to free space on my google drive. Removed/deleted files: Ubuntu_20.04.5_K4.19.219_RK3566_H96_MAX_8GB_No_Video_OUT_WIFI_OK_PARTITIONING.tar Ubuntu_20.04.5_K4.19.219_RK3566_H96_MAX_4GB_No_Video_OUT_WIFI_OK_PARTITIONING.tar Edited June 15, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Kenneth Hidalgo Posted June 15, 2023 Share Posted June 15, 2023 I already pressed the button with the stick but it is still in MASKROOM mode 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 15, 2023 Author Share Posted June 15, 2023 6 hours ago, Kenneth Hidalgo said: I already pressed the button with the stick but it is still in MASKROOM mode with your example, I made a new edition in the v0.7 text, go back there and execute the new text edition. if it keep maskroom, i think you will need a TTL debug to find out whats wrong 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 15, 2023 Author Share Posted June 15, 2023 (edited) If you like what you see here and want to help: Donate Armbian the like button only costs a few dollars. Armbian Needs you help! ######################### WHAT IS THIS? ######################### This is an SD-card image! With this images you can create a v0.7 image and apply it to the v1.0 image from @hotnikq With v0.7 root You can create a v0.8 image from @hzdm To use, and test the v0.5 image You will need do solder an SD-card Reader. Server Version v0.5DEBIAN12 BETA Desktop Version v0.5DEBIAN12 BETA check before if your device has the regulator: fan53555 check before if your device has: tcs4525 check before if your device has: RK809-5 works with 4gb and 8gb devices ######################### HOW TO USE IT ######################### using the T95 Method flash the Wipe_part on Boot partition flash the Wipe_part on Recovery partition Connect the power cord... wait 1 second and in a fraction of second, connect the sd-Card on device..... if it doesn't boot, try again in a different timming 2 seconds after power. On sd card flash the unnoficial modified debian #################### SOLDERED READER EXAMPLE #################### ########################### END ########################### ######################### FIRST BOOT ######################### user: root password: 1234 This is default armbian for original debian 12 image Updated dtb file here Drop the rk3566-firefly-roc-pc.dtb file inside the /boot/dtb/rockchip/ ######################### WHAT IS THIS? ######################### Base image: Armbian_23.08.0-trunk_Station-m2_bookworm_edge_6.2.16_xfce_desktop.img ✔️ H96 Max RK3566 4gb and 8gb ✔️ boot from SD-CARD Soldered ✔️ runs kernel 6.2 DESKTOP ✔️ Boot on Linux XFCE Ambian✔️ display video HDMi ✔️ detect internal MMC ✔️ Detect SD-CARD ✔️ Detect USB 2.0 port ✖️ (need to drop the rk3566-firefly-roc-pc.dtb Detect USB 3.0 port ✔️ (nothing better than an usb hub) ######################### HOW TO BUILD IT ######################### Runtime [ 6:05 min ] [✨] Repeat Build Options ./compile.sh build BOARD=station-m2 BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=yes RELEASE=bookworm ######################### HOW PUT IT ON MMC ######################### you can use it to make a v0.7 ROOT image. how? On 6/8/2023 at 7:16 PM, hotnikq said: any resemblance to this topic is mere adaptation Mount that image virtual device like /media/armbian_boot fdisk -l your-armbian-image-for-sd-card.img mount -o loop your-armbian-image-for-sd-card.img /media/armbian_boot if you can't "like WSL2" sudo apt-get install kpartx sudo kpartx -av your-armbian-image-for-sd-card.img sudo mount -o loop /dev/mapper/loop0p1 /media/armbian_boot Second Step: prepare an sd card or usb flash dummy , can be anithing with 6gb fdisk /dev/mmcblk1 N default default (lower this value to match the size of your root image) T 1 W third step: format that flash drive for ext4 mkfs.ext4 /dev/mmcblk1p1 fourth step: mount that clear partition and copy the entire virtual drive to the flash device mount /dev/mmcblk1p1 /mnt rsync -avx /media/armbian_boot/ /mnt fifth Step: Edit your uuid From Armbian Boot config "uuid for /dev/mmcblk1p1" blkid nano -w /mnt/boot/extlinux/extlinux.conf sixth step: make an hardware RAW.img from hardware flash drive with these parameters sudo dd if=/dev/mmcblk1p1 of=~/root.img bs=4096 status=progress PS: can be /dev/SDA" I do it on my h96max" so it's mmcblk1 now you have an ROOT IMAGE MADE BY YOURSELF! ./mkupdate.sh Uboot Legacy, Parameter.txt to create the Rockchip image Edited Sunday at 07:58 PM by Hqnicolas 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 15, 2023 Author Share Posted June 15, 2023 (edited) On 6/13/2023 at 10:28 AM, ufsm said: I can't go on, maybe for the 8Gb model it's a different procedure same procedure for 2, 4, 8gb devices.... @Kenneth Hidalgo posted a Linaro6.2 distro kernel 4, and it works on my device. Since you both have this problem with my tutorial, i will test the tutorial on my device, downloading files from the links that i post, the .tar.xz file can be corrupt. how you extract the .tar.xz files? @ufsm UPDATE: TESTED AND WORKING 4gb/32gb device Please extract file.xz with 7zip Please extract file.tar with 7zip Edited June 15, 2023 by hotnikq 0 Quote Link to comment Share on other sites More sharing options...
Hqnicolas Posted June 16, 2023 Author Share Posted June 16, 2023 (edited) 🏆 help to add other boards in armbian standart, you don't need to be a programmer to help the community, just need a copy of the ARM BOARD and a x86 computer to compile new versions. If you like what you see here and want to help: Donate Armbian, the like button only costs a few dollars. Armbian Needs you help! ####################### Just a Few clicks to help ################## This is an internal mmc trick 2-step image! You no longer need to solder an SD-card Reader like the creepy Release Version v0.5 BETA that i made. check before if your device has the regulator: fan53555 check before if your device has: tcs4525 check before if your device has: RK809-5 works with 4gb and 8gb devices How to use it: - install RKDevTool Drivers Rockchip - Use RkDevTool v2.86 - Drop Config.cfg the RkDevTool config file on folder Righ click on white background from RKDevTool click on Load Config Select the Config.cfg Step 1: Armbian 23.11 Kernel 6.2 H96 MAX 4GB/32GB Rk3566 Server unofficial Armbian 23.11 Kernel 6.2 H96 MAX 8GB/64GB Rk3566 Server unofficial Extract this file.xz with 7zip Extract this file.tar with 7zip Connect Your device: How? press the back button with a toothpick and connect male to male USB to you computer. Flash the Update Image on entire device as an Upgrade Firmware After Complete ! ! Disconect your device ! ! Step 2: Reconnect Your device: How? press the back button with a toothpick and connect male to male USB to you computer. Flash the GPT image inside the MMC GPT partition how: on RkDevTool v2.86 double click the number on table set Address on 0x00000000 set Name on gpt select the root file to flash on the "..." the dot right side of the table........ mark, Write by address after flash, it's done, use HDMI and USB to create user and password, regular armbian install... The Gpt file The Server 4gb Update image The Server 8gb Update image Yes, you can Skip Root flash. But you can drop the v0.7 Root.img file. Please Reflash GPT.img after new Root.img Debian 12 BookWorm Server Minimal ROOT Quote Armbian_23.11.0-trunk_Station-m2_jammy_edge_6.2.16_Server_Minimal.img ✔️ Boot from internal MMC ✔️ Runs kernel 6.2 Server ✔️ display video HDMi ✔️ detect internal MMC ✔️ Detect SD-CARD ✔️ Detect USB 2.0 port ✖️ (no USB2.0 on Server Images) Detect USB 3.0 port ✔️ (use a cheap usb hub 3.0) ##################################### END ############################################## ############################### HOT TO CREATE IMAGES ##################################### if you wanna do all that creepy again with other devices and images, (please do it on other devices) and topic this is all you need to create this image, first step: Compile armbian on linux desktop dont forgot to do it with modified DTS file: in this case DTB + DTS Files for you to edit because you want to help the community any resemblance to this topic is mere adaptation Mount that image virtual device like /media/armbian_boot fdisk -l your-armbian-image-for-sd-card.img mount -o loop your-armbian-image-for-sd-card.img /media/armbian_boot if you can't "like WSL2" sudo apt-get install kpartx sudo kpartx -av your-armbian-image-for-sd-card.img sudo mount -o loop /dev/mapper/loop0p1 /media/armbian_boot Second Step: prepare an sd card or usb flash dummy , can be anithing with 6gb fdisk /dev/mmcblk1 N default default (lower this value to match the size of your root image) T 1 W third step: format that flash drive for ext4 mkfs.ext4 /dev/mmcblk1p1 fourth step: mount that clear partition and copy the entire virtual drive to the flash device mount /dev/mmcblk1p1 /mnt/ rsync -avx /media/armbian_boot/ /mnt/ fifth Step: Edit your uuid From Armbian Boot config "uuid for /dev/mmcblk1p1" blkid nano -w /mnt/boot/extlinux/extlinux.conf sync umount /mnt sixth step: make an hardware RAW.img from hardware flash drive with these parameters sudo dd if=/dev/mmcblk1p1 of=~/root.img bs=4096 status=progress PS: can be /dev/SDA" I do it on my h96max" so it's mmcblk1 If you want a GPT.img backup dd if=/dev/mmcblk1 of=gpt.img bs=16896 count=1 dd if=/dev/mmcblk1p1 of=gpt1.img bs=16896 count=1 dd if=/dev/mmcblk1p2 of=gpt2.img bs=16896 count=1 now you have an ROOT IMAGE MADE BY YOURSELF! Update.img CREATE the Update Image on linux with the rockchip software. Linux Pack Rockchip Firmware ./mkupdate.sh Uboot Legacy, Parameter.txt to create the Rockchip image this process generate two files: File1: Linux_Pack_Firmware/rockdev/Image/update.img File2: Linux_Pack_Firmware/rockdev/update.img I generally use the File2 to flash my device on upgrade Firmware RKDevTool open new topics when performing this procedure on a device other than the H96MAX I will be happy to help This topic is Closed until Kernel 7 i dont wanna talk about RK3566 for the rest of my short life thanks to the armbian community for 42U$ now i have a docker service with kernel 6.2 gigabit network and how many hard drives i can connect to the usb hub we're running it "Cuban internet style" with 42U$ computers to escape government censorship. i laughed at china, now it happens here in latin america. Edited April 17 by Hqnicolas 3 Quote Link to comment Share on other sites More sharing options...
