Hqnicolas Posted December 22, 2024 Author Posted December 22, 2024 (edited) On 12/7/2024 at 1:14 PM, Hqnicolas said: I should spend a week to update the google drive on this device Updated Links for this topic with Unofficial images Kernel 6.12.6 server noble https://drive.google.com/file/d/1ulAH8sqdGkkWeAEFSHqTZaWg1N1Yrqnh/view?usp=sharing desktop noble https://drive.google.com/file/d/1sVKe_HbmxcSpuls_AAGIOnyaxcYKTkKl/view?usp=sharing jammy server https://drive.google.com/file/d/1C_P2ojuMdtTgT9aMAjoblPDSVw1tD8Wr/view?usp=sharing jammy desktop https://drive.google.com/file/d/1pmOXNiedEWzHetJZ4CmASZKZsgAElQag/view?usp=sharing bookworm server https://drive.google.com/file/d/1NvUwikDr08RdY6oJj3PFtx-N16_QkMtR/view?usp=sharing bookworm desktop https://drive.google.com/file/d/1VtHnIidMDT8P-wzL_Wwv4v6TUzrgNC2z/view?usp=sharing How to flash: Same as V1.1 Quote Quote Edited December 23, 2024 by Hqnicolas 0 Quote
ring1012 Posted January 1, 2025 Posted January 1, 2025 Thank you @Hqnicolas, 4g32g img did not work for me. I had no debug tool, so I don't know what're the blockers. But I tried to install retroarch in armbian, and load the cores from https://github.com/christianhaitian/retroarch-cores, it works for me. 0 Quote
Hqnicolas Posted January 2, 2025 Author Posted January 2, 2025 (edited) On 1/1/2025 at 8:09 AM, ring1012 said: 4g32g img did not work for me. Can you share your experience? I literally downloaded the 32gb image to test and everything went fine, google didn't corrupt the file "yet" On 1/1/2025 at 8:09 AM, ring1012 said: But I tried to install retroarch in armbian, and load the cores from https://github.com/christianhaitian/retroarch-cores, it works for me. You're talking about this kernel 6.6 images? the image contains many built-in features, such as kodi and internet game archive with retroarch android emulator and Windows emulator Quote Edited January 3, 2025 by Hqnicolas 0 Quote
GBEM Posted December 21, 2025 Posted December 21, 2025 (edited) Hello, fellow H96 musers. I've just acquired a 4G/32G H96 Max V56, and tried to flash an image that works on an earlier 8G/64G H96 Max V56, using the appropriate 4G booloader rather than the one I used for the 8G. The HAOS image boots fine, but everything about the Ethernet and WiFi must be wrong, as I have no networking hardware configured. I'm curious to know if there are differences between the 4G/32G board and the 8G/64G, other than eMMC size, that might account for the above outcome? Tthe only other thing I can think of, is that the 4G/32G board I recently acquired has different WiFi/Bluetooth and Ethernet chips fitted, and the drivers from my 8G/64G build aren't suited? 8G/64G H96 Max V56 PCB: LP6E27116A0 Wifi/BT: HC16335, S3144335 Ethernet: Realtek, RTL8211 4G/32G H96 Max V56 PCB: LS6E28533A0 Wifi/BT: SKI.WB800D80S.1_D40, 2023AP20230(M) Ethernet: Maxio, MAE0621A-02C Thoughts, or driver suggestions, anyone? GBEM 👽 p.s. If anyone has the stock rom for this box I'd be entirely grateful. Through absent mindedness, I foolishly didn't preserve mine. Edited December 22, 2025 by GBEM 0 Quote
WINEDS Posted December 22, 2025 Posted December 22, 2025 (edited) See my recent posts in the 64gb thread. You'll need to build an image with MAE0621A-02C support. The same thread will also give you some hints for to make the WiFi work with aic8800. Edited December 23, 2025 by WINEDS 0 Quote
GBEM Posted December 22, 2025 Posted December 22, 2025 (edited) Thanks, @WINEDS. I see you guy's are all over it, have at least the Ethernet sorted, and hints on the path to WiFi. I found an AllWinner CPU board from Radxa, that uses the same network peripherals as the newer H96 Max V56. The Radxa Cubie A5E is reported to feature WiFi6 and Bluetooth 5.4(?) using it's BLink BL-M8800DS2, which would be a step-up for me. https://docs.radxa.com/en/cubie/a5e/other-system/tina-os/build-system <- bsp, etc. Wish me luck. GBEM 👽 Edited December 24, 2025 by GBEM 1 Quote
WINEDS Posted December 23, 2025 Posted December 23, 2025 (edited) The WiFi is easy. Just : wget https://github.com/radxa-pkg/aic8800/releases/download/4.0%2Bgit20250410.b99ca8b6-3/aic8800-firmware_4.0+git20250410.b99ca8b6-3_all.deb wget https://github.com/radxa-pkg/aic8800/releases/download/4.0%2Bgit20250410.b99ca8b6-3/aic8800-sdio-dkms_4.0+git20250410.b99ca8b6-3_all.deb dpkg -i aic8800-firmware_4.0+git20250410.b99ca8b6-3_all.deb dpkg -i aic8800-sdio-dkms_4.0+git20250410.b99ca8b6-3_all.deb You will need the Linux kernel headers installed though. Edited December 23, 2025 by WINEDS 0 Quote
GBEM Posted December 23, 2025 Posted December 23, 2025 (edited) Thanks, @WINEDS, for the extra WiFi links and info. The sources for these will have everything I'll need. @WINEDS, you have made a series of changes to the DTS in my_rk3566-h96-tvbox3.dts, that adapt the build for the Maxio MAE0621A Ethernet and AIC AIC8800D80 WiFi and Bluetooth modules. I'll need to adapt these changes, to a quite different Home Assistant OS DTS file that worked with the earlier hardware. The my_rk3566-h96-tvbox3.dts file is large. I'm concerned that I'll miss something that's been added, conceivably with catastrophic result. There isn't a diff of your DTS file, that lists changes to support the 2025 Ethernet, WiFi and Bluetooth integration, is there? If not, are there any gotchas I should be looking for? GBEM 👽 Edited December 24, 2025 by GBEM 0 Quote
WINEDS Posted December 24, 2025 Posted December 24, 2025 To get the ethernet working you have no option but to build an image with kernel support for mae621. See these posts : 0 Quote
Marco Antonio Gomes Posted February 17 Posted February 17 Hello everyone, I have a Lemfo H96 Max V56 (8GB RAM / 64GB eMMC). Board PCB Version: HCY RK3566 - 1X32 - V13 - 2021-03-27 I am relatively new to the Linux world. So far, the only image I have managed to flash and boot successfully is an old Linaro Debian 10 (vendor image from 2019). However, this version lacks hardware acceleration (it runs on llvmpipe), which makes it unusable for my specific needs. My Goal: I want to run a modern Linux with a Desktop environment to use PortMaster and RetroArch. For this, I critically need a system with working Panfrost/Mali GPU drivers. The Problem: I have read through this thread, but I am finding it quite confusing to pinpoint exactly where to start given the various methods (Legacy vs Mainline/Chainloader). Also, it seems some file links are dead or pointing to empty repositories. Request: Could someone please guide me to the correct/updated files for my specific 8GB board? The correct MiniLoader/SPL (.bin) for RKDevTool. A working Desktop Image (.img) (Armbian Bookworm or Ubuntu) that supports GPU acceleration. I am already comfortable using RKDevTool and putting the device into Maskrom mode, so I just need the correct file set to avoid bricking the device. Thanks in advance for any help! 0 Quote
Hqnicolas Posted February 18 Author Posted February 18 On 2/16/2026 at 9:44 PM, Marco Antonio Gomes said: Board PCB Version: HCY RK3566 - 1X32 - V13 - 2021-03-27 Salve Marcão, did you try this method? https://github.com/armbian/community/releases/ https://forum.armbian.com/topic/28895-efforts-to-develop-firmware-for-h96-max-v56-rk3566-8g64g/page/8/#findComment-187569 0 Quote
