s-petersen Posted November 1, 2022 Posted November 1, 2022 My MXQ TV box died today, I was running Armbian stretch, and I had been listening to Mplayer playing Mp3s for several hours as background music, when the player stopped because it ran through the list, I went to change directories, but there were none found( I was running off the SSD), so I tried the root directory, also no files found. I closed the terminal window, and tried to restart, which just resulted in a boot loop. Thinking the file system was corrupt, I disconnected the SSD,and tried to boot the Android system from the internal Nand? which also resulted in similar behavior, I tried a different monitor, and removed all peripherals , Android partially booted, then died again, it seems like a video or memory issue. I had an interesting time getting everything working, and also the ability to get GPIO working with a USB GPIO was feeding my Raspberry Pi withdrawal problem. After all of this, I don't feel I will buy a newer TV box, There is no real support, and most of the officially supported boards cost much more than a Raspberry Pi Zero, and are not nearly as flexible. Raspberry OS Or Raspian just works, and the GPIO requires very little fiddling to get working. I would have gladly contributed if some TV boxes were supported, but it was made clear that would never happen, I am sincerely happy that balbes150 and SteeMan put the effort in all those years ago, and got my box to a usable condition, I only wished I had joined when the TV boxes were supported back then. Thanks for the memories...
Edy Cretu Posted November 21, 2022 Posted November 21, 2022 hello! since u got it working can u share the files cuz im not able too get a s905 mxq pro 4k to boot
s-petersen Posted November 21, 2022 Author Posted November 21, 2022 My box used a S805 processor, but the 905 is supported by other files pretty well I believe. Does your box lock up on boot?
brusli Posted November 22, 2022 Posted November 22, 2022 It just shows the the s905 logo and thats it, i have tried to found other files for it but most of them are not online anymore
s-petersen Posted November 22, 2022 Author Posted November 22, 2022 I will try to find the other files, I know that I have seen them recently
s-petersen Posted November 23, 2022 Author Posted November 23, 2022 (edited) You can try here, but I am not positive it is a safe site https://androidfilehost.com/?w=search&s=Armbian&type=files&sort_by=name&sort_dir=DESC Edited November 23, 2022 by s-petersen
SteeMan Posted November 26, 2022 Posted November 26, 2022 @brusli Also given that the archived builds @s-petersen linked to are over 3 years old, I'm not sure they are something you would want to use anyway (even if you trust a random third party download site). Three year old builds equal three years of unpatched security vulnerabilities.
s-petersen Posted November 26, 2022 Author Posted November 26, 2022 Can you point to a more recent place to find files that may work?, I know you are one of the most knowledgeable people on this topic. I had trouble finding the files that made my box work also, I know the files are old, but this category of hobby type equipment is not something I would even care if it were compromised, as it is a "toy" for experimentation. My goal was for a jukebox if it didn't fail, a replacement for a Raspberry Pi. Thanks for your efforts, so we have a place to start tinkering with these boxes!
