mhoney Posted October 11, 2016 Posted October 11, 2016 Just wanted to point out that a new aluminum case is available for the Odroid-C2 that not only looks cool, but keeps your Odroid from throttling due to heat. Fourdee over at DietPi did a really nice review of the case - http://dietpi.com/phpbb/viewtopic.php?f=9&t=730 What do you guys think?
tkaiser Posted October 12, 2016 Posted October 12, 2016 What do you guys think? Looks nice, is pretty expensive and I don't see the necessity especially given the huge amount of efforts to replace the heatsink (others reported that earlier) I don't know what I'm doing wrong but I repeated the test done by your tester and get rather different numbers (room temp ~23°C, stock heatsink): root@odroidc2:~# armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq CPU 20:08:13: 500MHz 0.01 1% 0% 0% 0% 0% 0% 38.0°C 20:08:18: 500MHz 0.01 1% 0% 0% 0% 0% 0% 38.0°C 20:08:23: 500MHz 0.01 1% 0% 0% 0% 0% 0% 38.0°C 20:08:28: 500MHz 0.00 1% 0% 0% 0% 0% 0% 39.0°C 20:08:33: 500MHz 0.00 1% 0% 0% 0% 0% 0% 38.0°C 20:08:38: 500MHz 0.00 1% 0% 0% 0% 0% 0% 38.0°C 20:08:43: 500MHz 0.00 1% 0% 0% 0% 0% 0% 38.0°C 20:08:48: 500MHz 0.00 1% 0% 0% 0% 0% 0% 38.0°C 20:08:53: 500MHz 0.00 1% 0% 0% 0% 0% 0% 38.0°C 20:08:58: 500MHz 0.00 1% 0% 0% 0% 0% 0% 38.0°C 20:09:04: 1536MHz 0.32 1% 0% 1% 0% 0% 0% 44.0°C 20:09:09: 1536MHz 0.62 3% 0% 2% 0% 0% 0% 45.0°C 20:09:14: 1536MHz 0.89 4% 0% 3% 0% 0% 0% 46.0°C 20:09:19: 1536MHz 1.14 5% 0% 4% 0% 0% 0% 46.0°C 20:09:24: 1536MHz 1.37 6% 0% 6% 0% 0% 0% 46.0°C 20:09:30: 1536MHz 1.58 7% 0% 7% 0% 0% 0% 46.0°C 20:09:35: 1536MHz 1.77 8% 0% 8% 0% 0% 0% 46.0°C 20:09:40: 1536MHz 1.95 10% 0% 9% 0% 0% 0% 47.0°C 20:09:45: 1536MHz 2.11 11% 0% 10% 0% 0% 0% 47.0°C 20:09:51: 1536MHz 2.26 12% 0% 11% 0% 0% 0% 47.0°C 20:09:56: 1536MHz 2.40 13% 0% 12% 0% 0% 0% 47.0°C 20:10:01: 1536MHz 2.53 14% 0% 13% 0% 0% 0% 48.0°C 20:10:06: 1536MHz 2.65 15% 0% 14% 0% 0% 0% 47.0°C 20:10:12: 1536MHz 2.76 16% 0% 15% 0% 0% 0% 47.0°C 20:10:17: 1536MHz 2.86 17% 0% 16% 0% 0% 0% 48.0°C 20:10:22: 1536MHz 3.03 17% 0% 17% 0% 0% 0% 48.0°C 20:10:27: 1536MHz 3.18 18% 0% 18% 0% 0% 0% 48.0°C 20:10:32: 1536MHz 3.24 19% 0% 19% 0% 0% 0% 48.0°C 20:10:38: 1536MHz 3.30 20% 0% 20% 0% 0% 0% 48.0°C 20:10:43: 1536MHz 3.36 21% 0% 20% 0% 0% 0% 48.0°C 20:10:48: 1536MHz 3.41 22% 0% 21% 0% 0% 0% 49.0°C 20:10:53: 1536MHz 3.46 23% 0% 22% 0% 0% 0% 49.0°C 20:10:59: 1536MHz 3.50 23% 0% 23% 0% 0% 0% 49.0°C 20:11:04: 1536MHz 3.54 24% 0% 24% 0% 0% 0% 49.0°C 20:11:09: 1536MHz 3.58 25% 0% 24% 0% 0% 0% 49.0°C 20:11:14: 1536MHz 3.61 26% 0% 25% 0% 0% 0% 49.0°C 20:11:20: 1536MHz 3.64 26% 0% 26% 0% 0% 0% 49.0°C 20:11:25: 1536MHz 3.67 27% 0% 27% 0% 0% 0% 50.0°C 20:11:30: 1536MHz 3.70 28% 0% 27% 0% 0% 0% 49.0°C 20:11:35: 1536MHz 3.72 28% 0% 28% 0% 0% 0% 50.0°C 20:11:40: 1536MHz 3.74 29% 0% 29% 0% 0% 0% 50.0°C 20:11:46: 1536MHz 3.77 30% 0% 29% 0% 0% 0% 50.0°C 20:11:51: 1536MHz 3.78 30% 0% 30% 0% 0% 0% 50.0°C 20:11:56: 1536MHz 3.80 31% 0% 31% 0% 0% 0% 50.0°C 20:12:01: 1536MHz 3.82 32% 0% 31% 0% 0% 0% 51.0°C 20:12:07: 1536MHz 3.83 32% 0% 32% 0% 0% 0% 51.0°C 20:12:12: 1536MHz 3.85 33% 0% 32% 0% 0% 0% 51.0°C 20:12:17: 1536MHz 3.86 33% 0% 33% 0% 0% 0% 51.0°C 20:12:22: 1536MHz 3.95 34% 0% 34% 0% 0% 0% 51.0°C 20:12:27: 1536MHz 3.96 35% 0% 34% 0% 0% 0% 51.0°C 20:12:33: 1536MHz 3.96 35% 0% 35% 0% 0% 0% 52.0°C 20:12:38: 1536MHz 3.96 36% 0% 35% 0% 0% 0% 51.0°C 20:12:43: 1536MHz 3.97 36% 0% 36% 0% 0% 0% 52.0°C 20:12:48: 1536MHz 3.97 37% 0% 36% 0% 0% 0% 52.0°C 20:12:54: 1536MHz 3.97 37% 0% 37% 0% 0% 0% 52.0°C 20:12:59: 1536MHz 3.97 38% 0% 37% 0% 0% 0% 52.0°C 20:13:04: 1536MHz 3.98 38% 0% 38% 0% 0% 0% 51.0°C 20:13:09: 1536MHz 3.98 39% 0% 38% 0% 0% 0% 52.0°C 20:13:15: 1536MHz 3.98 39% 0% 39% 0% 0% 0% 52.0°C 20:13:20: 1536MHz 3.98 40% 0% 39% 0% 0% 0% 53.0°C 20:13:25: 1536MHz 3.98 40% 0% 40% 0% 0% 0% 52.0°C 20:13:30: 1536MHz 3.98 41% 0% 40% 0% 0% 0% 52.0°C 20:13:35: 1536MHz 3.99 41% 0% 41% 0% 0% 0% 53.0°C 20:13:41: 1536MHz 3.99 42% 0% 41% 0% 0% 0% 53.0°C 20:13:46: 1536MHz 4.07 42% 0% 42% 0% 0% 0% 53.0°C 20:13:51: 1536MHz 4.06 43% 0% 42% 0% 0% 0% 53.0°C 20:13:56: 1536MHz 4.06 43% 0% 43% 0% 0% 0% 53.0°C 20:14:02: 1536MHz 4.05 43% 0% 43% 0% 0% 0% 53.0°C 20:14:07: 1536MHz 4.05 44% 0% 43% 0% 0% 0% 53.0°C 20:14:12: 1536MHz 4.04 44% 0% 44% 0% 0% 0% 53.0°C 20:14:17: 1536MHz 4.04 45% 0% 44% 0% 0% 0% 53.0°C 20:14:23: 1536MHz 4.11 45% 0% 45% 0% 0% 0% 54.0°C 20:14:28: 1536MHz 4.10 45% 0% 45% 0% 0% 0% 54.0°C 20:14:33: 1536MHz 4.09 46% 0% 45% 0% 0% 0% 54.0°C 20:14:38: 1536MHz 4.08 46% 0% 46% 0% 0% 0% 54.0°C 20:14:44: 1536MHz 4.08 47% 0% 46% 0% 0% 0% 54.0°C 20:14:49: 1536MHz 4.07 47% 0% 47% 0% 0% 0% 54.0°C 20:14:54: 1536MHz 4.07 47% 0% 47% 0% 0% 0% 54.0°C 20:14:59: 1536MHz 4.06 48% 0% 47% 0% 0% 0% 54.0°C 20:15:04: 1536MHz 4.06 48% 0% 48% 0% 0% 0% 54.0°C 20:15:10: 1536MHz 4.05 48% 0% 48% 0% 0% 0% 54.0°C 20:15:15: 1536MHz 4.05 49% 0% 48% 0% 0% 0% 54.0°C 20:15:20: 1536MHz 4.04 49% 0% 49% 0% 0% 0% 54.0°C 20:15:25: 1536MHz 4.04 49% 0% 49% 0% 0% 0% 54.0°C 20:15:31: 1536MHz 4.04 50% 0% 49% 0% 0% 0% 54.0°C 20:15:36: 1536MHz 4.03 50% 0% 50% 0% 0% 0% 55.0°C 20:15:41: 1536MHz 4.03 50% 0% 50% 0% 0% 0% 55.0°C 20:15:46: 1536MHz 4.03 51% 0% 50% 0% 0% 0% 55.0°C 20:15:52: 1536MHz 4.03 51% 0% 51% 0% 0% 0% 55.0°C 20:15:57: 1536MHz 4.02 51% 0% 51% 0% 0% 0% 55.0°C 20:16:02: 1536MHz 4.02 52% 0% 51% 0% 0% 0% 54.0°C 20:16:07: 1536MHz 4.02 52% 0% 52% 0% 0% 0% 54.0°C 20:16:13: 1536MHz 4.02 52% 0% 52% 0% 0% 0% 54.0°C 20:16:18: 1536MHz 4.09 53% 0% 52% 0% 0% 0% 55.0°C 20:16:23: 1536MHz 4.08 53% 0% 53% 0% 0% 0% 55.0°C 20:16:28: 1536MHz 4.08 53% 0% 53% 0% 0% 0% 54.0°C 20:16:33: 1536MHz 4.07 53% 0% 53% 0% 0% 0% 55.0°C 20:16:39: 1536MHz 4.06 54% 0% 53% 0% 0% 0% 55.0°C 20:16:44: 1536MHz 4.06 54% 0% 54% 0% 0% 0% 55.0°C 20:16:49: 1536MHz 4.05 54% 0% 54% 0% 0% 0% 55.0°C 20:16:54: 1536MHz 4.05 55% 0% 54% 0% 0% 0% 55.0°C 20:16:59: 1536MHz 4.05 55% 0% 55% 0% 0% 0% 55.0°C 20:17:05: 1536MHz 4.04 55% 0% 55% 0% 0% 0% 56.0°C 20:17:10: 1536MHz 4.04 55% 0% 55% 0% 0% 0% 56.0°C 20:17:15: 1536MHz 4.04 56% 0% 55% 0% 0% 0% 55.0°C 20:17:20: 1536MHz 4.03 56% 0% 56% 0% 0% 0% 56.0°C 20:17:26: 1536MHz 4.03 56% 0% 56% 0% 0% 0% 55.0°C 20:17:31: 1536MHz 4.03 56% 0% 56% 0% 0% 0% 55.0°C 20:17:36: 1536MHz 4.03 57% 0% 56% 0% 0% 0% 55.0°C 20:17:41: 1536MHz 4.02 57% 0% 57% 0% 0% 0% 56.0°C 20:17:47: 1536MHz 4.02 57% 0% 57% 0% 0% 0% 56.0°C 20:17:52: 1536MHz 4.02 57% 0% 57% 0% 0% 0% 56.0°C 20:17:57: 1536MHz 4.02 58% 0% 57% 0% 0% 0% 56.0°C 20:18:02: 1536MHz 4.02 58% 0% 58% 0% 0% 0% 56.0°C 20:18:07: 1536MHz 4.02 58% 0% 58% 0% 0% 0% 56.0°C 20:18:13: 1536MHz 4.01 58% 0% 58% 0% 0% 0% 56.0°C 20:18:18: 1536MHz 4.01 58% 0% 58% 0% 0% 0% 56.0°C 20:18:23: 1536MHz 4.08 59% 0% 58% 0% 0% 0% 56.0°C 20:18:28: 1536MHz 4.08 59% 0% 59% 0% 0% 0% 56.0°C 20:18:34: 1536MHz 4.07 59% 0% 59% 0% 0% 0% 56.0°C 20:18:39: 1536MHz 4.07 59% 0% 59% 0% 0% 0% 56.0°C 20:18:44: 1536MHz 4.06 60% 0% 59% 0% 0% 0% 56.0°C 20:18:49: 1536MHz 4.06 60% 0% 60% 0% 0% 0% 56.0°C 20:18:54: 1536MHz 4.05 60% 0% 60% 0% 0% 0% 56.0°C 20:19:00: 1536MHz 4.05 60% 0% 60% 0% 0% 0% 56.0°C 20:19:05: 500MHz 3.72 60% 0% 60% 0% 0% 0% 49.0°C 20:19:10: 500MHz 3.42 60% 0% 59% 0% 0% 0% 48.0°C 20:19:15: 500MHz 3.15 59% 0% 59% 0% 0% 0% 48.0°C 20:19:20: 500MHz 2.90 59% 0% 59% 0% 0% 0% 48.0°C 20:19:25: 500MHz 2.67 59% 0% 59% 0% 0% 0% 48.0°C 38°C idle and 56°C with the light 'stress' workload. What am I'm doing wrong?! Might settings matter? ___ _ _ _ ____ ____ / _ \ __| |_ __ ___ (_) __| | / ___|___ \ | | | |/ _` | '__/ _ \| |/ _` | | | __) | | |_| | (_| | | | (_) | | (_| | | |___ / __/ \___/ \__,_|_| \___/|_|\__,_| \____|_____| Welcome to ARMBIAN Ubuntu 16.04.1 LTS 3.14.79-odroidc2 System load: 0.00 Up time: 6 min IP: 192.168.83.81 CPU temp: 39°C Usage of /: 32% of 7.0G [ 5 updates to install: apt-get upgrade ] Last login: Wed Oct 12 20:03:41 2016 from 192.168.83.91 tk@odroidc2:~$ stress -c $(nproc --all) -t 600 stress: info: [1525] dispatching hogs: 4 cpu, 0 io, 0 vm, 0 hdd stress: info: [1525] successful run completed in 600s tk@odroidc2:~$ uname -a Linux odroidc2 3.14.79-odroidc2 #8 SMP PREEMPT Tue Sep 13 23:00:48 CEST 2016 aarch64 aarch64 aarch64 GNU/Linux tk@odroidc2:~$ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=odroidc2 BOARD_NAME="Odroid C2" VERSION=5.16 LINUXFAMILY=odroidc2 BRANCH=default ARCH=arm64 BTW: Even running cpuburn-a53 doesn't lead to throttling on ODROID-C2 with default heatsink (temperature after 10 minutes just 75°C and SoC still happily clocking at the highest clockspeed). No thanks, I'm pretty satisfied with the stock heatsink (Hardkernel did a good job here). But here at Armbian we always do the necessary fine-tuning for the boards we support and that might make a difference? 1
arox Posted October 12, 2016 Posted October 12, 2016 No thanks, I'm pretty satisfied with the stock heatsink (Hardkernel did a good job here). Yes, it would be nice to have the heatsink in the enclosure as in certain intel fan-less device (or simply boosters), but for practical reasons it is not a good idea for odroid-c2. It would be more useful for boards with the CPU on the opposite side of the PCB than connectors and GPIO (as nanopi neo).
tkaiser Posted October 13, 2016 Posted October 13, 2016 for practical reasons it is not a good idea for odroid-c2. It would be more useful for boards with the CPU on the opposite side of the PCB than connectors and GPIO (as nanopi neo). The original Banana Pi and Pro had the 'hot stuff' on the opposite side and I know of at least one person making a copper enclosure for BPi (taking care of SoC, DRAM and PMIC, the latter being the hottest chip). Unfortunately he never got back to me with actual temperature numbers (maybe because they were not that much better compared to el cheapo heatsinks?) The whole thing could work with ODROIDs too but for this price I would expect that DRAM is also considered (like it's done on Spreedbox -- just scroll down a little). When I did some consumption/performance tests the last weeks I was pretty surprised how heat affected consumption (don't find @ssvb's link where that is explained in detail). IIRC I tested with ODROID-C2 and got a variation of ~300mW depending on temperature (same cpufreq, same performance results, just cramping the board in a tiny enclosure vs. blowing air over the heatsink using a 12V fan). And the same 'problem' applies not only to CPU cores or SoCs but to DRAM too especially when clocked pretty high. So if I would use such an enclosure/heatsink combo it has to consider cooling DRAM too Anyway: ODROID C1/C1+ and C2 are two examples for the few SBC out there where the vendor already took care about heat dissipation and where it requires a lot of efforts to remove the stock heatsink. Providing such an enclosure for one of these boards seems a bit strange Edit: Found ssvb's link: http://asic-soc.blogspot.de/2008/03/process-variations-and-static-timing.html
mhoney Posted October 14, 2016 Author Posted October 14, 2016 Thanks for the input guys. Besides the Odroid XU4, which SBC do you think would benefit the most from an aluminum heat sink enclosure? We just finished up the RPi 3 enclosure and have a few more in the works, but we'd like to get the communities input on where an aluminum enclosure would be most beneficial.
tkaiser Posted October 14, 2016 Posted October 14, 2016 Yeah, a silent cooling solution for XU4 would be great. In case you haven't already please take a look at the various NanoPi: http://wiki.friendlyarm.com/wiki/index.php/Main_Page#NanoPC.2FPi_Series Yesterday I examined M1 and M3 a bit and came to the conclusion that if done correctly it should be possible to design a single enclosure/heatsink combo for M1, M2, M3 (and maybe also their upcoming A64 variant) if only the SoC should stay cool. If DRAM and PMIC (M2, M3 and A64) is also considered different enclosure tops are needed. BTW: pcDuino 4 Nano is an M1 OEM so you've another board already covered when supporting M1. Important: M2 and M3 should be able to connect to LCD, access to Micro USB is mandatory and if done right a ribbon cable could expose all 40 GPIO pins too! Now that some fantastic forum members improved camera drivers access to FPC connector on these boards is also important. Such an enclosure would also be interesting for NanoPi NEO and Air but I doubt people will spend more than 5 bucks here. Banana Pi M2+, M3, M64 and M2 Ultra would also be interesting for you (the last 3 maybe able to share one solution). M2+ overheats badly since vendor forgot voltage regulation and the SoCs of the three others all need improved heat dissipation. We have another 2 overheating candidates based on Actions Semi S500 but they come already with heatsinks and are not that popular. From the remaining devices you find at http://www.armbian.com/download/ only Pine64 is prone to overheating but this board might be too large for an all aluminum enclosure approach. Please keep us updated and feel free to ask if further questions occur
