November 4, 20224 yr hello guys bluetooth stopped working uname -a Linux pinebook 5.15.76-rockchip64 #22.08.8 SMP PREEMPT Sun Oct 30 10:57:32 CET 2022 aarch64 GNU/Linux dmesg | grep Bluetooth [ 9.863147] Bluetooth: Core ver 2.22 [ 9.863249] Bluetooth: HCI device and connection manager initialized [ 9.863261] Bluetooth: HCI socket layer initialized [ 9.863266] Bluetooth: L2CAP socket layer initialized [ 9.863276] Bluetooth: SCO socket layer initialized [ 9.972130] Bluetooth: HCI UART driver ver 2.3 [ 9.972144] Bluetooth: HCI UART protocol H4 registered [ 9.972147] Bluetooth: HCI UART protocol BCSP registered [ 9.972218] Bluetooth: HCI UART protocol LL registered [ 9.972222] Bluetooth: HCI UART protocol ATH3K registered [ 9.972261] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 9.972460] Bluetooth: HCI UART protocol Intel registered [ 9.972609] Bluetooth: HCI UART protocol Broadcom registered [ 9.972646] Bluetooth: HCI UART protocol QCA registered [ 9.972649] Bluetooth: HCI UART protocol AG6XX registered [ 9.972688] Bluetooth: HCI UART protocol Marvell registered [ 12.322372] Bluetooth: hci0: command 0xfc18 tx timeout [ 20.450331] Bluetooth: hci0: BCM: failed to write update baudrate (-110) [ 20.450363] Bluetooth: hci0: Failed to set baudrate [ 20.799400] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 20.799435] Bluetooth: BNEP filters: protocol multicast [ 20.799461] Bluetooth: BNEP socket layer initialized blueman-manager blueman-manager 14.32.28 ERROR Manager:147 on_dbus_name_appeared: Default adapter not found, blueman-manager 14.32.28 ERROR Manager:151 on_dbus_name_appeared: No adapter(s) found, exitin stopped working after last system update Edited November 4, 20224 yr by perchibald
November 20, 20223 yr Hi, I'm experiencing the same problem. Rolling back to kernel pinebook 5.15.74-rockchip64 made Bluetooth work again. Cheers, Ivan
November 29, 20223 yr bluetooth is also not working for me in newest build. I have pinebook Pro. thanks any advice?
December 9, 20223 yr I used Armbian Build for Pinebook Pro laptop, Armbian 22.11 Jammy XFCE Nov 30, 2022. built onto SD card. Booted to Armbian SD card used armbian-config installed Bluetooth from armbian-config I saw icon show on on the task bar , when i clicked it to start Bluetooth, it crashed. I tried Removing and Installing Bluetooth many times and shutting down and restarting laptop. the Bluetooth Icon does no appear in the task bar. and the blueman-manager and adapter do not open when I type them in the run box. Bluetooth hardware works on this pinebook Pro Laptop, but only when i tried things like Manajaro XFCE And KDE on Emmc . on manjaro, Bluetooth works on both of those and I see icon in task bar and I connected 3 different bluetooth /BLE devices. It just doesn't work for Armbian i have freshly loaded. I also tried 4 different SD cards now all with armbian. Other things run fine, Internet , wifi, etc, just not the Bluetooth. Only on Armbian, I'm not seeing the Bluetooth Icon in taskbard and Blueman keeps crashing. I have uninstalled and reinstalled it at least 10 times now using armbian-config. I also checked did armbian Updates. Nothing will bring the bluetooth icon back and I can't connect devices (bluetooth hardware seems to work fine on other distros with same laptop). is this a Bug or something I am doing wrong with the Install of Bluetooth? Edited December 9, 20223 yr by River-mochi
December 9, 20223 yr @ivan_holmes I just tried from inside armbian-config to roll back to older kernel 5.15.74-rockchip64 and it soft bricked the Pinebook Pro. how did you install 5.15.74 did you do it from inside of the armbian-config , others to switch kernel (since that did not work for me). or some other method? I now have newest Armbian Gnome SD card booted up on PbPro using the EMMC switch trick (emmc switch off, hit power button, count 2-3 seconds , push switch back on). on SD boot, Armbian Gnome , Bluetooth also does not work, using the Gui settings, no matter how many times I hit Bluetooth on, it doesn't turn on. Are there any command line options I could check?
December 14, 20223 yr 10.12.2022 в 00:17, River-mochi сказал: I just tried from inside armbian-config to roll back to older kernel 5.15.74-rockchip64 and it soft bricked the Pinebook Pro. how did you install 5.15.74 did you do it from inside of the armbian-config , others to switch kernel (since that did not work for me). or some other method? Downgrade from armbian-config, broke boot for me too Just take image from https://imola.armbian.com/archive/pinebook-pro/archive/ for example https://imola.armbian.com/archive/pinebook-pro/archive/Armbian_22.08.1_Pinebook-pro_bullseye_current_5.15.63.img.xz and don't forget "armbian-config -> System -> Freeze" for prevent kernel update
February 21, 20233 yr I am running Armbian 22.11 on my PineBook Pro from both eMMC and SD and have installed the latest upgrades. It is now the end of February and I have still not found any way to get BlueTooth or the camera to work. If anyone has a solution, I sure would appreciate some insight.
