madurani Posted November 15, 2022 Share Posted November 15, 2022 I used https://github.com/piter75/armbian-build for building images via vm-kvm for my Orange servers. Now I want compile application hostapd with forcing 40MHz, but I don't want build/compile it on orange pi servers. Is possible use environment armbian-build for building mentioned application? Or some docker container with armbian in which I can mentioned application to compile? 0 Quote Link to comment Share on other sites More sharing options...
going Posted November 16, 2022 Share Posted November 16, 2022 Developer-Guide_Build-Options EXTERNAL_NEW ( no | prebuilt | compile ) prebuilt: install extra applications from repository compile: compile extra applications in chroot Does this key work for the repository you are using? 0 Quote Link to comment Share on other sites More sharing options...
Solution madurani Posted November 16, 2022 Author Solution Share Posted November 16, 2022 I found "how to" for chroot of armbian-armhf image on my virtual kvm-amd64 server. There i can compile patched hostapd with forced 40Mhz and create deb file. This deb package, then I can distribute it on all my orange pi zero routers. Linux orion2 5.15.77-sunxi #trunk SMP Tue Nov 15 07:36:22 UTC 2022 armv7l GNU/Linux root@orion2:/var/log# iw wlan0 info Interface wlan0 ifindex 3 wdev 0x1 addr 00:19:86:11:da:a9 ssid orion2 type AP wiphy 0 channel 11 (2462 MHz), width: 40 MHz, center1: 2452 MHz txpower 30.00 dBm 0 Quote Link to comment Share on other sites More sharing options...
