First of all forgive my English, I do not speak the language and certainly make mistakes. use google translator to write;-)
I have the Orange Pi + 2e and I installed "Debian Jessie," but I can not run the wifi that is integrated, I am new to linux, so everything costs me more.
According to the specifications https://linux-sunxi.org/Orange_Pi_Plus_2E the wifi chip is Realtek RTL8189FTV
Would appreciate some help, thank you very much.
Please provide the output of 'lsmod'. If there is no '8189fs' listed then please try a 'modprobe 8189fs' and then follow these instructions here: https://github.com/igorpecovnik/lib/issues/493#issuecomment-252751466
Please report back whether it works and if you do not succeed we need the output from 'dmesg'
Thanks for the reply, I have done what you mention, when intengo enabled connection in nmtui, out error.
I leave here what you ask:
root@orangepiplus2e:~# lsmod
sunxi_cir               1601  0
8189fs               1050491  0
login as: root
root@192.168.1.102's password:
  ___                               ____  _         ____  _____
 / _ \ _ __ __ _ _ __   __ _  ___  |  _ \(_)  _    |___ \| ____|
| | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | |_| |_    __) |  _|
| |_| | | | (_| | | | | (_| |  __/ |  __/| |_   _|  / __/| |___
 \___/|_|  \__,_|_| |_|\__, |\___| |_|   |_| |_|   |_____|_____|
                       |___/
Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun8i
System load:   0.30             Up time:       7 min
Memory usage:  3 % of 2013Mb    IP:            192.168.1.102
CPU temp:      52°C
Usage of /:    86% of 1.5G
Last login: Sun Oct 16 11:40:03 2016 from 192.168.1.2
root@orangepiplus2e:~# dmesg
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.112-sun8i (root@xenial) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #14 SMP PREEMPT Wed Sep 14 20:29:31 CEST 2016
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: sun8i
[    0.000000] cma: CMA: reserved 256 MiB at b0000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] On node 0 totalpages: 524288
[    0.000000] free_area_init_node: node 0, pgdat c0a24900, node_mem_map c0b5d000
[    0.000000]   Normal zone: 1710 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 192850 pages, LIFO batch:31
[    0.000000]   HighMem zone: 2898 pages used for memmap
[    0.000000]   HighMem zone: 326830 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] PERCPU: Embedded 8 pages/cpu @c1d7a000 s11968 r8192 d12608 u32768
[    0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 519680
[    0.000000] Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 panic=10 consoleblank=0 enforcing=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] allocated 4194304 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 2048MB = 2048MB total
[    0.000000] Memory: 1796504k/1796504k available, 300648k reserved, 1056768K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc095bce8   (9552 kB)
[    0.000000]       .init : 0xc095c000 - 0xc09aeec0   ( 332 kB)
[    0.000000]       .data : 0xc09b0000 - 0xc0a29750   ( 486 kB)
[    0.000000]        .bss : 0xc0a29f04 - 0xc0b5cf90   (1229 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:544
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.000272] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000296] pid_max: default: 32768 minimum: 301
[    0.000635] Mount-cache hash table entries: 512
[    0.001603] Initializing cgroup subsys cpuacct
[    0.001618] Initializing cgroup subsys memory
[    0.001665] Initializing cgroup subsys devices
[    0.001676] Initializing cgroup subsys freezer
[    0.001687] Initializing cgroup subsys blkio
[    0.001710] Initializing cgroup subsys perf_event
[    0.001792] CPU: Testing write buffer coherency: ok
[    0.001837] ftrace: allocating 25740 entries in 76 pages
[    0.030293] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.030311] [sunxi_smp_prepare_cpus] enter
[    0.030347] Setting up static identity map for 0x40691938 - 0x40691990
[    0.031292] CPU1: Booted secondary processor
[    0.031292] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.031425] CPU2: Booted secondary processor
[    0.031425] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.040487] CPU3: Booted secondary processor
[    0.040487] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.040607] Brought up 4 CPUs
[    0.040607] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.040899] devtmpfs: initialized
[    0.050883] wakeup src cnt is : 2.
[    0.050897] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.050908] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0
[    0.050918] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.050929] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.050940] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8
[    0.050950] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.050961] sunxi pm init
[    0.051098] pinctrl core: initialized pinctrl subsystem
[    0.061107] NET: Registered protocol family 16
[    0.062330] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.062397] script_sysfs_init success
[    0.062425] sunxi_dump_init success
[    0.063305] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.063305] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.063305] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.063305] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.063305] script config pll_video to 297 Mhz
[    0.063305] script config pll_de to 864 Mhz
[    0.063305] script config pll_ve to 402 Mhz
[    0.063305] sunxi_default_clk_init
[    0.063305] try to set pll6ahb1 to 200000000
[    0.063305] try to set ahb clk source to pll6ahb1
[    0.063305] set ahb clk source to pll6ahb1
[    0.063305] try to set ahb1 to 200000000
[    0.063305] try to set apb1 to 100000000
[    0.070236] bio: create slab <bio-0> at 0
[    0.070310] [ARISC] :sunxi-arisc driver v1.04
[    0.091742] [ARISC] :arisc version: [v0.1.58]
[    0.182011] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.183606] SCSI subsystem initialized
[    0.183606] usbcore: registered new interface driver usbfs
[    0.183606] usbcore: registered new interface driver hub
[    0.183606] usbcore: registered new device driver usb
[    0.183606] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.183606] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.183606] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.183606] Linux video capture interface: v2.00
[    0.183606] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.183606] cfg80211: Calling CRDA to update world regulatory domain
[    0.183606] Switching to clocksource arch_sys_counter
[    0.193959] FS-Cache: Loaded
[    0.194244] CacheFiles: Loaded
[    0.205372] NET: Registered protocol family 2
[    0.216591] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.217190] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.218950] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.220040] TCP: Hash tables configured (established 131072 bind 65536)
[    0.220052] TCP: reno registered
[    0.220066] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.220104] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.220457] NET: Registered protocol family 1
[    0.220869] RPC: Registered named UNIX socket transport module.
[    0.220881] RPC: Registered udp transport module.
[    0.220889] RPC: Registered tcp transport module.
[    0.220897] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.221085] Trying to unpack rootfs image as initramfs...
[    0.407549] Freeing initrd memory: 3040K
[    0.408093] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.408218] sunxi_reg_init enter
[    0.409130] audit: initializing netlink socket (disabled)
[    0.409180] type=2000 audit(0.400:1): initialized
[    0.410471] highmem bounce pool size: 64 pages
[    0.411350] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.411538] misc fatfs initialized
[    0.412261] NFS: Registering the id_resolver key type
[    0.412633] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.412647] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.413413] NTFS driver 2.1.30 [Flags: R/W].
[    0.413731] fuse init (API version 7.18)
[    0.414491] Btrfs loaded
[    0.414515] msgmni has been set to 1450
[    0.415924] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.415946] io scheduler noop registered
[    0.415956] io scheduler deadline registered
[    0.416028] io scheduler cfq registered (default)
[    0.416432] [DISP]disp_module_init
[    0.416743] cmdline,init_disp=
[    0.416772] cmdline,disp=
[    0.425708] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.442109] Console: switching to colour frame buffer device 160x45
[    0.459402] [DISP]disp_module_init finish
[    0.459624] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.459937] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.459950] sw_uart_pm()890 - uart0 clk is already enable
[    0.459968] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.460438] console [ttyS0] enabled
[    0.460991] sunxi_cmatest_init enter
[    0.461029] sunxi_cmatest_init success
[    0.465140] brd: module loaded
[    0.469020] loop: module loaded
[    0.469318] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    0.469333] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    0.469916] spi spi0: master is unqueued, this is deprecated
[    0.470288] tun: Universal TUN/TAP device driver, 1.6
[    0.470299] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.471606] PPP generic driver version 2.4.2
[    0.471798] PPP BSD Compression module registered
[    0.471809] PPP Deflate Compression module registered
[    0.474574] PPP MPPE Compression module registered
[    0.474592] NET: Registered protocol family 24
[    0.474668] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.494775] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.494810] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    0.495388] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    0.510036] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    0.510683] hub 1-0:1.0: USB hub found
[    0.510708] hub 1-0:1.0: 1 port detected
[    0.531076] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.531107] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    0.531531] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    0.550034] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    0.550571] hub 2-0:1.0: USB hub found
[    0.550595] hub 2-0:1.0: 1 port detected
[    0.570961] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.570989] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    0.571387] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    0.590035] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    0.590571] hub 3-0:1.0: USB hub found
[    0.590591] hub 3-0:1.0: 1 port detected
[    0.610950] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.610979] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    0.611373] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    0.630030] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    0.630573] hub 4-0:1.0: USB hub found
[    0.630592] hub 4-0:1.0: 1 port detected
[    0.630969] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.651065] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.651094] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    0.651126] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    0.714546] hub 5-0:1.0: USB hub found
[    0.714566] hub 5-0:1.0: 1 port detected
[    0.734934] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.734963] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    0.734995] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    0.794576] hub 6-0:1.0: USB hub found
[    0.794600] hub 6-0:1.0: 1 port detected
[    0.814976] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.815004] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    0.815036] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    0.874566] hub 7-0:1.0: USB hub found
[    0.874586] hub 7-0:1.0: 1 port detected
[    0.894978] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.895006] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    0.895038] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    0.954539] hub 8-0:1.0: USB hub found
[    0.954559] hub 8-0:1.0: 1 port detected
[    0.954920] Initializing USB Mass Storage driver...
[    0.955149] usbcore: registered new interface driver usb-storage
[    0.955159] USB Mass Storage support registered.
[    0.955215] usbcore: registered new interface driver ums-alauda
[    0.955262] usbcore: registered new interface driver ums-cypress
[    0.955317] usbcore: registered new interface driver ums-datafab
[    0.955369] usbcore: registered new interface driver ums_eneub6250
[    0.955416] usbcore: registered new interface driver ums-freecom
[    0.955465] usbcore: registered new interface driver ums-isd200
[    0.955511] usbcore: registered new interface driver ums-jumpshot
[    0.955557] usbcore: registered new interface driver ums-karma
[    0.955604] usbcore: registered new interface driver ums-onetouch
[    0.955664] usbcore: registered new interface driver ums-realtek
[    0.955715] usbcore: registered new interface driver ums-sddr09
[    0.955764] usbcore: registered new interface driver ums-sddr55
[    0.955813] usbcore: registered new interface driver ums-usbat
[    0.956028]  uinput result 0 , vmouse_init
[    0.956632] mousedev: PS/2 mouse device common for all mice
[    0.956855] sunxikbd_init failed.
[    0.957360] ls_fetch_sysconfig_para: type err  device_used = -1073060220.
[    0.957612] =========script_get_err============
[    0.957622] ltr_init: ls_fetch_sysconfig_para err.
[    0.957933] [RTC] WARNING: Rtc time will be wrong!!
[    0.957943] [RTC] WARNING: use *internal OSC* as clock source
[    0.958191] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    0.958240] i2c /dev entries driver
[    0.958633] IR RC5(x) protocol handler initialized
[    0.958760] sunxi cedar version 0.1
[    0.958806] [cedar]: install start!!!
[    0.959000] [cedar]: install end!!!
[    0.959234] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18)
[    0.959404] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19)
[    0.959572] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    0.959740] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29)
[    0.959907] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    0.960090] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    0.960259] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    0.960427] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    0.960594] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    0.960793] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
[    0.960988] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
[    0.961182] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    0.961377] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
[    0.961572] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    0.961766] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    0.961961] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    0.962156] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    0.962351] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    0.962366] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    0.962527] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    0.962704] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    0.962717] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    0.962728] timeout_to_interv, line 167
[    0.962736] interv_to_timeout, line 189
[    0.962745] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    0.963158] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    0.963373] calibrat: max_cpufreq 1296Mhz Type 0!
[    0.963685] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Sep 14 2016 at 20:28:08
[    0.963721] [mmc]: get mmc0's sdc_power is null!
[    0.963750] [mmc]: get mmc1's sdc_power is null!
[    0.963759] [mmc]: get mmc1's 2xmode ok, val = 1
[    0.963768] [mmc]: get mmc1's ddrmode ok, val = 1
[    0.963797] [mmc]: get mmc2's sdc_power is null!
[    0.963806] [mmc]: get mmc2's 2xmode ok, val = 1
[    0.963816] [mmc]: get mmc2's ddrmode ok, val = 1
[    0.963828] [mmc]: MMC host used card: 0x7, boot card: 0x5, io_card 2
[    0.964873] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    0.965985] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    0.966557] [mmc]: sdc2 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    0.967525] [mmc]: sdc0 power_supply is null
[    0.968995] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    0.971814] no blue_led, ignore it!
[    0.972066] Registered led device: red_led
[    0.972179] Registered led device: green_led
[    0.972196] no led_0, ignore it!
[    0.972203] no led_1, ignore it!
[    0.972210] no led_2, ignore it!
[    0.972217] no led_3, ignore it!
[    0.972224] no led_4, ignore it!
[    0.972231] no led_5, ignore it!
[    0.972238] no led_6, ignore it!
[    0.972245] no led_7, ignore it!
[    0.973066] usbcore: registered new interface driver usbhid
[    0.973076] usbhid: USB HID core driver
[    0.978302] asoc: sndcodec <-> sunxi-codec mapping ok
[    0.979176] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    0.979363] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    0.979377] [DAUDIO0] driver not init,just return.
[    0.980090] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    0.983163] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    0.984286] oprofile: using arm/armv7-ca7
[    0.984478] u32 classifier
[    0.984486]     Performance counters on
[    0.984493]     input device check on
[    0.984500]     Actions configured
[    0.984687] IPv4 over IPv4 tunneling driver
[    0.985312] TCP: bic registered
[    0.985323] TCP: cubic registered
[    0.985331] TCP: westwood registered
[    0.985338] TCP: highspeed registered
[    0.985346] TCP: hybla registered
[    0.985353] TCP: htcp registered
[    0.985360] TCP: vegas registered
[    0.985368] TCP: veno registered
[    0.985375] TCP: scalable registered
[    0.985383] TCP: lp registered
[    0.985390] TCP: yeah registered
[    0.985397] TCP: illinois registered
[    0.985405] Initializing XFRM netlink socket
[    0.985646] NET: Registered protocol family 10
[    0.986811] NET: Registered protocol family 17
[    0.986841] NET: Registered protocol family 15
[    0.986890] Registering the dns_resolver key type
[    0.987360] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.987382] ThumbEE CPU extension supported.
[    0.987404] Registering SWP/SWPB emulation handler
[    0.987974] registered taskstats version 1
[    0.988432] cmdline,disp=
[    0.988744] [HDMI] power vcc-hdmi-18
[    1.001717] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.004230] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.009541] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.009656] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.012152] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.019447] ths_fetch_sysconfig_para: type err  device_used = 1.
[    1.020765] CPU Budget:corekeeper enabled
[    1.020994] CPU Budget:Register notifier
[    1.021007] CPU Budget:register Success
[    1.021019] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    1.024211] [rf_pm]: module power0 name vcc-wifi-33
[    1.024225] [rf_pm]: failed to fetch module_power0_vol
[    1.024235] [rf_pm]: mod has no chip_en gpio
[    1.024243] [rf_pm]: regulator on.
[    1.024258] [rf_pm]: set losc_out 32k out[wifi_pm]: wifi gpio init is OK !!
[    1.024595] [rfkill]: init no bt used in configuration
[    1.024607] ALSA device list:
[    1.024615]   #0: audiocodec
[    1.024623]   #1: sndhdmi
[    1.025512] Freeing init memory: 328K
[    1.031637] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.033036] [mmc]: sdc0 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    1.033147] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    1.033299] [mmc]: sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    1.033396] mmc0: new high speed SDHC card at address b368
[    1.033978] mmcblk0: mmc0:b368 00000 7.51 GiB
[    1.035999]  mmcblk0: p1
[    1.036693] mmcblk mmc0:b368: Card claimed for testing.
[    1.036711] mmc0:b368: 00000 7.51 GiB
[    1.036757] *******************sd init ok*******************
[    1.036782] [mmc]: sdc2 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.038344] [mmc]: sdc2 power_supply is null
[    1.050080] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.071798] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.071945] systemd-udevd[98]: starting version 215
[    1.074380] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.082999] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.083468] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.083587] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.083707] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.086213] [mmc]: sdc2 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.101372] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.113541] [mmc]: sdc2 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.114077] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.114290] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.114436] [mmc]: sdc2 set ios: clk 25000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    1.114523] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    1.114637] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing MMC-HS(SDR20) dt B
[    1.114781] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B
[    1.115022] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing MMC-HS(SDR20) dt B
[    1.115157] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.115260] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.115388] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.115547] mmc1: new high speed DDR MMC card at address 0001
[    1.116237] mmcblk1: mmc1:0001 AWPD3R 14.5 GiB
[    1.116542] mmcblk1boot0: mmc1:0001 AWPD3R partition 1 4.00 MiB
[    1.116847] mmcblk1boot1: mmc1:0001 AWPD3R partition 2 4.00 MiB
[    1.118612]  mmcblk1: p1
[    1.119935] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.121728]  mmcblk1boot1: unknown partition table
[    1.122685] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.123840]  mmcblk1boot0: unknown partition table
[    1.124186] mmcblk mmc1:0001: Card claimed for testing.
[    1.124206] mmc1:0001: AWPD3R 14.5 GiB
[    1.124260] *******************mmc init ok *******************
[    1.151256] mmcblk0: r/w command failed, status = 0x80000900
[    1.151280] end_request: I/O error, dev mmcblk0, sector 15759096
[    1.151300] Buffer I/O error on device mmcblk0, logical block 1969887
[    1.201297] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.233136] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.233987] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.234428] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.234705] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.235079] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.235401] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.235880] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.236204] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.236585] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.236908] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.237283] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.237635] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.237947] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.238272] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.238760] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.239059] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.239424] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.239707] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.240173] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.240454] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.240827] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.241159] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.241473] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.241761] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.245552] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.245965] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.246348] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.246785] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.247161] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.247507] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.247828] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.248188] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.248467] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.248856] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.249161] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.249523] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.249833] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.250281] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.250585] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.250877] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.251166] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.251447] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.251724] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.251999] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.252273] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.252550] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.252823] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.253111] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.253405] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.253698] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.253998] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.254290] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.254578] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.254858] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.255136] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.255411] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.255685] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.255972] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.256254] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.256528] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.256809] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.257090] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.257378] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.257659] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.257941] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.258243] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.258529] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.258817] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.259108] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.259518] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.259843] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    1.620048] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5
[    2.107505] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    2.113860] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    4.917440] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    6.160328] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    6.160667] systemd[1]: Detected architecture 'arm'.
[    6.167222] systemd[1]: Set hostname to <orangepiplus2e>.
[    6.286911] mmcblk0: r/w command failed, status = 0x80000900
[    6.286933] end_request: I/O error, dev mmcblk0, sector 53320
[    6.293138] EXT4-fs error (device mmcblk0p1): ext4_find_entry:941: inode #1283: comm systemd-sysv-ge: reading directory lblock 0
[    6.611811] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    6.614492] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    6.614849] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.614927] systemd[1]: Expecting device dev-ttyS0.device...
[    6.615511] systemd[1]: Starting Remote File Systems (Pre).
[    6.615900] systemd[1]: Reached target Remote File Systems (Pre).
[    6.616057] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    6.616970] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.617071] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    6.617279] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    6.617338] systemd[1]: Starting Paths.
[    6.617665] systemd[1]: Reached target Paths.
[    6.617735] systemd[1]: Starting Encrypted Volumes.
[    6.618071] systemd[1]: Reached target Encrypted Volumes.
[    6.618139] systemd[1]: Starting Root Slice.
[    6.618549] systemd[1]: Created slice Root Slice.
[    6.618610] systemd[1]: Starting User and Session Slice.
[    6.619086] systemd[1]: Created slice User and Session Slice.
[    6.619147] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    6.619720] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    6.619782] systemd[1]: Starting Delayed Shutdown Socket.
[    6.620288] systemd[1]: Listening on Delayed Shutdown Socket.
[    6.620358] systemd[1]: Starting Journal Socket (/dev/log).
[    6.620849] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.620938] systemd[1]: Starting udev Control Socket.
[    6.621352] systemd[1]: Listening on udev Control Socket.
[    6.621429] systemd[1]: Starting udev Kernel Socket.
[    6.621822] systemd[1]: Listening on udev Kernel Socket.
[    6.621907] systemd[1]: Starting Journal Socket.
[    6.622358] systemd[1]: Listening on Journal Socket.
[    6.622479] systemd[1]: Starting System Slice.
[    6.622955] systemd[1]: Created slice System Slice.
[    6.623070] systemd[1]: Started File System Check on Root Device.
[    6.623124] systemd[1]: Starting system-serial\x2dgetty.slice.
[    6.623712] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    6.623773] systemd[1]: Starting system-getty.slice.
[    6.624272] systemd[1]: Created slice system-getty.slice.
[    6.624402] systemd[1]: Starting Increase datagram queue length...
[    6.690879] systemd[1]: Starting Restore / save the current clock...
[    6.774776] systemd[1]: Started Set Up Additional Binary Formats.
[    6.774907] systemd[1]: Starting udev Coldplug all Devices...
[    6.840954] systemd[1]: Mounting POSIX Message Queue File System...
[    6.910580] systemd[1]: Mounted Huge Pages File System.
[    6.911140] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    6.955539] systemd[1]: Starting Load Kernel Modules...
[    7.011265] systemd[1]: Mounting Debug File System...
[    7.125702] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    7.127259] [mmc]: sdc1 power_supply is null
[    7.140072] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    7.150583] systemd[1]: Starting LSB: Set keymap...
[    7.161956] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    7.190595] systemd[1]: Starting Slices.
[    7.191095] systemd[1]: Reached target Slices.
[    7.193801] systemd[1]: Mounted Debug File System.
[    7.194475] systemd[1]: Mounted POSIX Message Queue File System.
[    7.225684] [wifi_pm]: set wl_reg_on 1 !
[    7.255108] systemd[1]: Started Increase datagram queue length.
[    7.345048] systemd[1]: Started Restore / save the current clock.
[    7.515423] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    7.605059] systemd[1]: Started Load Kernel Modules.
[    7.694928] systemd[1]: Started LSB: Set keymap.
[    7.784828] systemd[1]: Started udev Coldplug all Devices.
[    7.786874] systemd[1]: Time has been changed
[    7.787203] systemd[1]: Mounting FUSE Control File System...
[    7.950468] systemd[1]: Starting Apply Kernel Variables...
[    8.021091] systemd[1]: Mounted Configuration File System.
[    8.021436] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.070794] systemd[1]: Starting Syslog Socket.
[    8.075669] systemd[1]: Listening on Syslog Socket.
[    8.075816] systemd[1]: Starting Journal Service...
[    8.160032] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[    8.215576] systemd[1]: Started Journal Service.
[    8.676423] systemd-udevd[185]: starting version 215
[    8.901175] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    8.989988] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.000306] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.001413] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.004564] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.004997] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.005441] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.005816] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.006349] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.010515] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.010975] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.013118] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.014084] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.015756] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.016675] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.018514] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.019452] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.019889] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.020546] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.020913] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.027089] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.028109] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.028686] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.029043] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.030138] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.030586] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.030976] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.031335] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.031718] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.032107] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.032477] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.033007] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.033824] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.037947] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.038373] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.038821] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.039635] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.040268] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.040674] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.041120] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.041480] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.041843] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.042556] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.043008] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.043384] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.043770] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.044123] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.044485] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.044828] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.045151] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.045563] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.045908] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.046285] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.046707] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.047090] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.047743] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.048180] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.048661] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.049284] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.050210] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.050593] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.051033] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.051423] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.051886] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.052289] [mmc]: sdc2 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 8 timing UHS-DDR50 dt B
[    9.160064] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[    9.527659] EXT4-fs (mmcblk0p1): warning: mounting fs with errors, running e2fsck is recommended
[    9.530951] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    9.747885] Adding 131068k swap on /var/swap.  Priority:-1 extents:1 across:131068k SS
[   10.160055] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   10.162099] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   10.867709] systemd-journald[184]: Received request to flush runtime journal from PID 1
[   11.160064] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   11.169413] gmac0: probed
[   11.200425] gmac0 gmac0: eth0: eth0: PHY ID 001cc915 at 0 IRQ poll (gmac0-0:00)
[   12.160061] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   12.397408] EXT4-fs warning (device mmcblk0p1): ext4_resize_begin:32: There are errors in the filesystem, so online resizing is not allowed
[   12.744485] Registered IR keymap rc-empty
[   12.746538] rc0: sunxi-ir as /devices/virtual/rc/rc0
[   12.752638] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0
[   13.160038] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   13.161097] [mmc]: sdc1 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   14.160027] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   15.160023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   16.160020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   16.160051] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   16.160180] [mmc]: sdc1 power_supply is null
[   16.162761] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   16.164286] [mmc]: sdc1 power_supply is null
[   16.180046] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   16.200303] PHY: gmac0-0:00 - Link is Up - 1000/Full
[   16.201992] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   17.200020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   18.200019] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   19.200021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   19.202050] [mmc]: sdc1 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   20.200018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   21.200023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   21.270022] eth0: no IPv6 routers present
[   22.200021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   22.201067] [mmc]: sdc1 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   23.200019] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   24.200017] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   25.200018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   25.200048] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   25.200176] [mmc]: sdc1 power_supply is null
[   25.202757] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   25.204281] [mmc]: sdc1 power_supply is null
[   25.220058] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   25.242151] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   26.240021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   27.240021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   28.240020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   28.242049] [mmc]: sdc1 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   29.240021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   30.240019] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   31.240020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   31.241062] [mmc]: sdc1 set ios: clk 200000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   32.240019] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   33.240023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   34.240020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   34.240051] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   34.240178] [mmc]: sdc1 power_supply is null
[   34.242760] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   34.244284] [mmc]: sdc1 power_supply is null
[   34.260039] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   34.282328] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   35.280021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   36.280020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   37.280020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   37.282049] [mmc]: sdc1 set ios: clk 150000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   38.280018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   39.280018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   40.280018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   40.281056] [mmc]: sdc1 set ios: clk 150000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   41.280043] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   42.280018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   43.280016] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!!
[   43.280042] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[   43.280160] [mmc]: sdc1 power_supply is null
I couldn't get WiFi working on my home network Armbian Jessie on OPi+2E using wicd - so I removed wicd and installed network-manager and network-manager-xfce...  and it just worked...
Your installation (or SD card) is broken anyway: 'There are errors in the filesystem, so online resizing is not allowed'
Please start here again: http://docs.armbian.com/User-Guide_Getting-Started/#how-to-prepare-a-sd-card
Hello again.
I bought a new memory card, I installed Armbian_5.20_Orangepiplus2e_Debian_jessie_3.4.112_desktop again and I executed
Apt-get update
Apt-get upgrade
reboot
And still without detection wifi,
I leave here dmseg
[    0.000000] Linux version 3.4.112-sun8i (root@xenial) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #10 SMP PREEMPT Sun Oct 23 16:06:55 CEST 2016
[    0.000000] free_area_init_node: node 0, pgdat c0a22a00, node_mem_map c0b5c000
[    0.000000] PERCPU: Embedded 8 pages/cpu @c1d79000 s11968 r8192 d12608 u32768
[    0.000000] Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 panic=10 consoleblank=0 enforcing=0 loglevel=1
[    0.000000] Memory: 1796488k/1796488k available, 300664k reserved, 1056768K highmem
[    0.000000]       .text : 0xc0008000 - 0xc095ad38   (9548 kB)
[    0.000000]       .init : 0xc095b000 - 0xc09adec0   ( 332 kB)
[    0.000000]       .data : 0xc09ae000 - 0xc0a27850   ( 487 kB)
[    0.000000]        .bss : 0xc0a28004 - 0xc0b5b090   (1229 kB)
[    0.000270] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000293] pid_max: default: 32768 minimum: 301
[    0.000631] Mount-cache hash table entries: 512
[    0.001594] Initializing cgroup subsys cpuacct
[    0.001610] Initializing cgroup subsys memory
[    0.001656] Initializing cgroup subsys devices
[    0.001668] Initializing cgroup subsys freezer
[    0.001679] Initializing cgroup subsys blkio
[    0.001703] Initializing cgroup subsys perf_event
[    0.001782] CPU: Testing write buffer coherency: ok
[    0.001827] ftrace: allocating 25741 entries in 76 pages
[    0.030310] [sunxi_smp_prepare_cpus] enter
[    0.030346] Setting up static identity map for 0x40691778 - 0x406917d0
[    0.031300] CPU1: Booted secondary processor
[    0.031300] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.031431] CPU2: Booted secondary processor
[    0.031431] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.040489] CPU3: Booted secondary processor
[    0.040489] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.040609] Brought up 4 CPUs
[    0.040609] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.040900] devtmpfs: initialized
[    0.050590] wakeup src cnt is : 2.
[    0.050604] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.050615] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0
[    0.050626] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.050637] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000
[    0.050647] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8
[    0.050658] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40
[    0.050669] sunxi pm init
[    0.050806] pinctrl core: initialized pinctrl subsystem
[    0.060838] NET: Registered protocol family 16
[    0.061831] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.061897] script_sysfs_init success
[    0.061926] sunxi_dump_init success
[    0.062806] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.062806] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.062806] plat: add bmp085 device
[    0.062806] plat: add pcf8591 device
[    0.062806] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.062806] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.062806] script config pll_video to 297 Mhz
[    0.062806] script config pll_de to 864 Mhz
[    0.062806] script config pll_ve to 402 Mhz
[    0.062806] sunxi_default_clk_init
[    0.062806] try to set pll6ahb1 to 200000000
[    0.062806] try to set ahb clk source to pll6ahb1
[    0.062806] set ahb clk source to pll6ahb1
[    0.062806] try to set ahb1 to 200000000
[    0.062806] try to set apb1 to 100000000
[    0.070234] bio: create slab <bio-0> at 0
[    0.070305] [ARISC] :sunxi-arisc driver v1.04
[    0.090492] [ARISC] :arisc version: [v0.1.58]
[    0.181041] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.182638] SCSI subsystem initialized
[    0.182638] usbcore: registered new interface driver usbfs
[    0.182638] usbcore: registered new interface driver hub
[    0.182638] usbcore: registered new device driver usb
[    0.182638] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.182638] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.182638] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.182638] Linux video capture interface: v2.00
[    0.182638] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.182638] cfg80211: Calling CRDA to update world regulatory domain
[    0.182638] Switching to clocksource arch_sys_counter
[    0.193989] FS-Cache: Loaded
[    0.194276] CacheFiles: Loaded
[    0.205462] NET: Registered protocol family 2
[    0.216690] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.217291] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.219050] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.220140] TCP: Hash tables configured (established 131072 bind 65536)
[    0.220152] TCP: reno registered
[    0.220166] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.220205] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.220563] NET: Registered protocol family 1
[    0.220978] RPC: Registered named UNIX socket transport module.
[    0.220990] RPC: Registered udp transport module.
[    0.220998] RPC: Registered tcp transport module.
[    0.221006] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.221197] Trying to unpack rootfs image as initramfs...
[    0.408542] Freeing initrd memory: 3060K
[    0.408924] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.409051] sunxi_reg_init enter
[    0.409973] audit: initializing netlink socket (disabled)
[    0.410072] type=2000 audit(0.410:1): initialized
[    0.411296] highmem bounce pool size: 64 pages
[    0.412175] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.412358] misc fatfs initialized
[    0.413080] NFS: Registering the id_resolver key type
[    0.413463] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.413477] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.414239] NTFS driver 2.1.30 [Flags: R/W].
[    0.414567] fuse init (API version 7.18)
[    0.415280] Btrfs loaded
[    0.415304] msgmni has been set to 1450
[    0.416710] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.416731] io scheduler noop registered
[    0.416740] io scheduler deadline registered
[    0.416807] io scheduler cfq registered (default)
[    0.417220] [DISP]disp_module_init
[    0.417520] cmdline,init_disp=
[    0.417548] cmdline,disp=
[    0.427251] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.443725] Console: switching to colour frame buffer device 160x45
[    0.461083] [DISP]disp_module_init finish
[    0.461306] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.461624] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.461638] sw_uart_pm()890 - uart0 clk is already enable
[    0.461656] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.461990] console [ttyS0] enabled
[    0.462528] sunxi_cmatest_init enter
[    0.462573] sunxi_cmatest_init success
[    0.466669] brd: module loaded
[    0.470658] loop: module loaded
[    0.470957] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    0.470972] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    0.471571] spi spi0: master is unqueued, this is deprecated
[    0.471881] tun: Universal TUN/TAP device driver, 1.6
[    0.471891] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.473185] PPP generic driver version 2.4.2
[    0.473395] PPP BSD Compression module registered
[    0.473405] PPP Deflate Compression module registered
[    0.476158] PPP MPPE Compression module registered
[    0.476177] NET: Registered protocol family 24
[    0.476252] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.496354] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.496387] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    0.496995] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    0.510649] hub 1-0:1.0: USB hub found
[    0.510674] hub 1-0:1.0: 1 port detected
[    0.531048] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.531078] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    0.531497] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    0.550033] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    0.550050] ehci_irq: highspeed device connect
[    0.550559] hub 2-0:1.0: USB hub found
[    0.550586] hub 2-0:1.0: 1 port detected
[    0.570949] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.570978] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    0.571370] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    0.590031] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    0.590574] hub 3-0:1.0: USB hub found
[    0.590594] hub 3-0:1.0: 1 port detected
[    0.610952] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.610981] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    0.630043] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    0.630578] hub 4-0:1.0: USB hub found
[    0.630602] hub 4-0:1.0: 1 port detected
[    0.630986] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.651063] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.651092] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    0.651124] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    0.714559] hub 5-0:1.0: USB hub found
[    0.714581] hub 5-0:1.0: 1 port detected
[    0.734948] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.734977] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    0.735008] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    0.794580] hub 6-0:1.0: USB hub found
[    0.794605] hub 6-0:1.0: 1 port detected
[    0.810044] ehci_irq: highspeed device disconnect
[    0.810072] ohci_irq: fullspeed or lowspeed device connect
[    0.814980] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.815008] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    0.815041] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    0.874573] hub 7-0:1.0: USB hub found
[    0.874593] hub 7-0:1.0: 1 port detected
[    0.894963] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    0.894990] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    0.895021] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    0.954541] hub 8-0:1.0: USB hub found
[    0.954561] hub 8-0:1.0: 1 port detected
[    0.954901] Initializing USB Mass Storage driver...
[    0.955131] usbcore: registered new interface driver usb-storage
[    0.955142] USB Mass Storage support registered.
[    0.955198] usbcore: registered new interface driver ums-alauda
[    0.955246] usbcore: registered new interface driver ums-cypress
[    0.955302] usbcore: registered new interface driver ums-datafab
[    0.955355] usbcore: registered new interface driver ums_eneub6250
[    0.955403] usbcore: registered new interface driver ums-freecom
[    0.955450] usbcore: registered new interface driver ums-isd200
[    0.955496] usbcore: registered new interface driver ums-jumpshot
[    0.955543] usbcore: registered new interface driver ums-karma
[    0.955592] usbcore: registered new interface driver ums-onetouch
[    0.955655] usbcore: registered new interface driver ums-realtek
[    0.955706] usbcore: registered new interface driver ums-sddr09
[    0.955754] usbcore: registered new interface driver ums-sddr55
[    0.955803] usbcore: registered new interface driver ums-usbat
[    0.956019]  uinput result 0 , vmouse_init
[    0.956627] mousedev: PS/2 mouse device common for all mice
[    0.956853] sunxikbd_init failed.
[    0.957598] ls_fetch_sysconfig_para: type err  device_used = -1073060220.
[    0.957609] =========script_get_err============
[    0.957617] ltr_init: ls_fetch_sysconfig_para err.
[    0.957930] [RTC] WARNING: Rtc time will be wrong!!
[    0.957940] [RTC] WARNING: use *internal OSC* as clock source
[    0.958190] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    0.958239] i2c /dev entries driver
[    0.958638] IR RC5(x) protocol handler initialized
[    0.958765] sunxi cedar version 0.1
[    0.958811] [cedar]: install start!!!
[    0.959005] [cedar]: install end!!!
[    0.959245] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18)
[    0.959417] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19)
[    0.959586] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    0.959754] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29)
[    0.959922] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    0.960094] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    0.960264] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    0.960434] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    0.960602] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    0.960802] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
[    0.960997] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
[    0.961192] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a)
[    0.961387] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
[    0.961582] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a)
[    0.961777] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b)
[    0.961972] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
[    0.962167] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d)
[    0.962362] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e)
[    0.962377] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    0.962540] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    0.962717] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    0.962730] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    0.962741] timeout_to_interv, line 167
[    0.962749] interv_to_timeout, line 189
[    0.962758] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    0.963168] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    0.963382] calibrat: max_cpufreq 1296Mhz Type 0!
[    0.963691] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Oct 23 2016 at 16:04:43
[    0.963724] [mmc]: get mmc0's sdc_power is null!
[    0.963752] [mmc]: get mmc1's sdc_power is null!
[    0.963761] [mmc]: get mmc1's 2xmode ok, val = 1
[    0.963770] [mmc]: get mmc1's ddrmode ok, val = 1
[    0.963798] [mmc]: get mmc2's sdc_power is null!
[    0.963807] [mmc]: get mmc2's 2xmode ok, val = 1
[    0.963817] [mmc]: get mmc2's ddrmode ok, val = 1
[    0.963830] [mmc]: MMC host used card: 0x7, boot card: 0x0, io_card 2
[    0.967455] [mmc]: sdc0 power_supply is null
[    0.970988] no blue_led, ignore it!
[    0.971232] Registered led device: red_led
[    0.971349] Registered led device: green_led
[    0.971366] no led_0, ignore it!
[    0.971374] no led_1, ignore it!
[    0.971381] no led_2, ignore it!
[    0.971388] no led_3, ignore it!
[    0.971395] no led_4, ignore it!
[    0.971402] no led_5, ignore it!
[    0.971409] no led_6, ignore it!
[    0.971416] no led_7, ignore it!
[    0.972240] usbcore: registered new interface driver usbhid
[    0.972253] usbhid: USB HID core driver
[    0.977073] asoc: sndcodec <-> sunxi-codec mapping ok
[    0.977937] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    0.978124] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    0.978137] [DAUDIO0] driver not init,just return.
[    0.981905] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    0.982951] oprofile: using arm/armv7-ca7
[    0.983140] u32 classifier
[    0.983149]     Performance counters on
[    0.983156]     input device check on
[    0.983163]     Actions configured
[    0.983353] IPv4 over IPv4 tunneling driver
[    0.983983] TCP: bic registered
[    0.983995] TCP: cubic registered
[    0.984002] TCP: westwood registered
[    0.984010] TCP: highspeed registered
[    0.984017] TCP: hybla registered
[    0.984024] TCP: htcp registered
[    0.984032] TCP: vegas registered
[    0.984039] TCP: veno registered
[    0.984046] TCP: scalable registered
[    0.984054] TCP: lp registered
[    0.984061] TCP: yeah registered
[    0.984068] TCP: illinois registered
[    0.984076] Initializing XFRM netlink socket
[    0.984315] NET: Registered protocol family 10
[    0.985475] NET: Registered protocol family 17
[    0.985506] NET: Registered protocol family 15
[    0.985556] Registering the dns_resolver key type
[    0.985894] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.985915] ThumbEE CPU extension supported.
[    0.985938] Registering SWP/SWPB emulation handler
[    0.986491] registered taskstats version 1
[    0.986942] cmdline,disp=
[    0.987247] [HDMI] power vcc-hdmi-18
[    1.017969] ths_fetch_sysconfig_para: type err  device_used = 1.
[    1.019239] CPU Budget:corekeeper enabled
[    1.019470] CPU Budget:Register notifier
[    1.019482] CPU Budget:register Success
[    1.019496] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    1.022739] [rf_pm]: module power0 name vcc-wifi-33
[    1.022754] [rf_pm]: failed to fetch module_power0_vol
[    1.022764] [rf_pm]: mod has no chip_en gpio
[    1.022772] [rf_pm]: regulator on.
[    1.022787] [rf_pm]: set losc_out 32k out[wifi_pm]: set wl_reg_on 1 !
[    1.052718] mmc0: new high speed SDHC card at address 19b3
[    1.053213] mmcblk0: mmc0:19b3 SE08G 7.28 GiB
[    1.054468]  mmcblk0: p1
[    1.055024] mmcblk mmc0:19b3: Card claimed for testing.
[    1.055038] mmc0:19b3: SE08G 7.28 GiB
[    1.056616] [mmc]: sdc2 power_supply is null
[    1.123197] hci: ERR: sunxi_ehci is already enable, can not enable again
[    1.123210] hci: ERR: sunxi_ohci is already enable, can not enable again
[    1.134461] mmc2: new high speed DDR MMC card at address 0001
[    1.134932] mmcblk1: mmc2:0001 AWPD3R 14.5 GiB
[    1.135164] mmcblk1boot0: mmc2:0001 AWPD3R partition 1 4.00 MiB
[    1.135398] mmcblk1boot1: mmc2:0001 AWPD3R partition 2 4.00 MiB
[    1.136513]  mmcblk1: p1
[    1.138126]  mmcblk1boot1: unknown partition table
[    1.139489]  mmcblk1boot0: unknown partition table
[    1.139706] mmcblk mmc2:0001: Card claimed for testing.
[    1.139719] mmc2:0001: AWPD3R 14.5 GiB
[    1.141279] [mmc]: sdc1 power_supply is null
[    1.170046] usb 6-1: new full-speed USB device number 2 using sunxi-ohci
[    1.195173] [mmc]: sdc1 power_supply is null
[    1.199284] [mmc]: sdc1 power_supply is null
[    1.223234] [wifi_pm]: wifi gpio init is OK !!
[    1.223302] [rfkill]: init no bt used in configuration
[    1.223312] ALSA device list:
[    1.223319]   #0: audiocodec
[    1.223326]   #1: sndhdmi
[    1.224113] Freeing init memory: 328K
[    1.258860] [mmc]: sdc1 power_supply is null
[    1.262688] [mmc]: sdc1 power_supply is null
[    1.269353] systemd-udevd[100]: starting version 215
[    1.326050] [mmc]: sdc1 power_supply is null
[    1.330113] [mmc]: sdc1 power_supply is null
[    1.402758] [mmc]: sdc1 power_supply is null
[    1.463705] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-sunxi-ohci-1/input2
[    1.471042] logitech-djdevice 0003:046D:C52B.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4024] on usb-sunxi-ohci-1:1
[    1.620044] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5
[    2.593543] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    3.840314] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    3.840645] systemd[1]: Detected architecture 'arm'.
[    3.851071] systemd[1]: Set hostname to <orangepiplus2e>.
[    4.149527] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    4.152403] systemd[1]: Expecting device dev-ttyS0.device...
[    4.153120] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    4.153345] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.153418] systemd[1]: Starting Remote File Systems (Pre).
[    4.153817] systemd[1]: Reached target Remote File Systems (Pre).
[    4.153982] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    4.154912] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.155020] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    4.155220] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    4.155281] systemd[1]: Starting Paths.
[    4.155604] systemd[1]: Reached target Paths.
[    4.155666] systemd[1]: Starting Encrypted Volumes.
[    4.156000] systemd[1]: Reached target Encrypted Volumes.
[    4.156071] systemd[1]: Starting Root Slice.
[    4.156480] systemd[1]: Created slice Root Slice.
[    4.156540] systemd[1]: Starting User and Session Slice.
[    4.157028] systemd[1]: Created slice User and Session Slice.
[    4.157094] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    4.157638] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    4.157701] systemd[1]: Starting Delayed Shutdown Socket.
[    4.158157] systemd[1]: Listening on Delayed Shutdown Socket.
[    4.158219] systemd[1]: Starting Journal Socket (/dev/log).
[    4.158679] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.158761] systemd[1]: Starting udev Control Socket.
[    4.159160] systemd[1]: Listening on udev Control Socket.
[    4.159234] systemd[1]: Starting udev Kernel Socket.
[    4.159649] systemd[1]: Listening on udev Kernel Socket.
[    4.159736] systemd[1]: Starting Journal Socket.
[    4.160247] systemd[1]: Listening on Journal Socket.
[    4.160380] systemd[1]: Starting System Slice.
[    4.160866] systemd[1]: Created slice System Slice.
[    4.160963] systemd[1]: Started File System Check on Root Device.
[    4.161018] systemd[1]: Starting system-serial\x2dgetty.slice.
[    4.161600] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    4.161663] systemd[1]: Starting system-getty.slice.
[    4.162178] systemd[1]: Created slice system-getty.slice.
[    4.162310] systemd[1]: Starting Increase datagram queue length...
[    4.200818] systemd[1]: Starting Restore / save the current clock...
[    4.250845] systemd[1]: Starting udev Coldplug all Devices...
[    4.324531] systemd[1]: Starting Load Kernel Modules...
[    4.381231] systemd[1]: Mounting Debug File System...
[    4.491011] [mmc]: sdc1 power_supply is null
[    4.491050] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    4.545180] [mmc]: sdc1 power_supply is null
[    4.549292] [mmc]: sdc1 power_supply is null
[    4.550898] systemd[1]: Mounting POSIX Message Queue File System...
[    4.589425] [wifi_pm]: set wl_reg_on 1 !
[    4.597115] UMP: UMP device driver  loaded
[    4.608858] [mmc]: sdc1 power_supply is null
[    4.610814] systemd[1]: Mounted Huge Pages File System.
[    4.612697] mali clk: 252 MHz
[    4.612741] [mmc]: sdc1 power_supply is null
[    4.612919] mali clk: 252 MHz
[    4.616570] systemd[1]: Started Set Up Additional Binary Formats.
[    4.616701] systemd[1]: Starting LSB: Set keymap...
[    4.622712] Mali: Mali device driver loaded
[    4.675219] [mmc]: sdc1 power_supply is null
[    4.679328] [mmc]: sdc1 power_supply is null
[    4.680614] systemd[1]: Starting Slices.
[    4.681139] systemd[1]: Reached target Slices.
[    4.683882] systemd[1]: Mounted POSIX Message Queue File System.
[    4.684480] systemd[1]: Mounted Debug File System.
[    4.720578] systemd[1]: Started Increase datagram queue length.
[    4.752053] [mmc]: sdc1 power_supply is null
[    4.804990] systemd[1]: Started Restore / save the current clock.
[    4.985334] systemd[1]: Started Load Kernel Modules.
[    5.055198] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    5.104991] systemd[1]: Started LSB: Set keymap.
[    5.154881] systemd[1]: Started udev Coldplug all Devices.
[    5.156953] systemd[1]: Time has been changed
[    5.157526] systemd[1]: Starting Create Static Device Nodes in /dev...
[    5.241031] systemd[1]: Mounted Configuration File System.
[    5.241225] systemd[1]: Mounting FUSE Control File System...
[    5.330570] systemd[1]: Starting Apply Kernel Variables...
[    5.410798] systemd[1]: Starting Syslog Socket.
[    5.415841] systemd[1]: Listening on Syslog Socket.
[    5.416008] systemd[1]: Starting Journal Service...
[    5.485527] systemd[1]: Started Journal Service.
[    5.734897] systemd-udevd[186]: starting version 215
[    6.138894] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x77)
[    6.138931] bmp085: probe of 0-0077 failed with error -70
[    6.164328] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x48)
[    6.164549] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x48)
[    6.599992] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    6.834513] Adding 131068k swap on /var/swap.  Priority:-1 extents:1 across:131068k SS
[    8.177648] systemd-journald[185]: Received request to flush runtime journal from PID 1
[    8.517449] gmac0: probed
[    8.550404] gmac0 gmac0: eth0: eth0: PHY ID 001cc915 at 0 IRQ poll (gmac0-0:00)
[   10.318363] Registered IR keymap rc-empty
[   10.319018] rc0: sunxi-ir as /devices/virtual/rc/rc0
[   10.320294] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0
[   10.521249] [DISP] disp_ioctl,line:1584:para err in disp_ioctl, cmd = 0x0,screen id = 65536
[   10.580389] [drm] Initialized drm 1.1.0 20060810
[   10.584891] Mali DRM initialize, driver name: mali_drm, version 2.1
[   10.585442] [drm] Initialized mali_drm 2.1.1 20101111 on minor 0
[   10.585503] Mali DRM initialize, driver name: mali_drm, version 2.1
[   10.585912] [drm] Initialized mali_drm 2.1.1 20101111 on minor 1
[   11.036470] vmouse_input_dev_open
[   13.550301] PHY: gmac0-0:00 - Link is Up - 1000/Full
[   18.890041] eth0: no IPv6 routers present
[   18.994893] Bluetooth: Core ver 2.16
[   18.994966] NET: Registered protocol family 31
[   18.994974] Bluetooth: HCI device and connection manager initialized
[   18.994985] Bluetooth: HCI socket layer initialized
[   18.994992] Bluetooth: L2CAP socket layer initialized
[   18.995012] Bluetooth: SCO socket layer initialized
[   19.014325] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   19.014340] Bluetooth: BNEP filters: protocol multicast
[   19.837680] Bluetooth: RFCOMM TTY layer initialized
[   19.837709] Bluetooth: RFCOMM socket layer initialized
[   19.837719] Bluetooth: RFCOMM ver 1.11
root@orangepiplus2e:~#
Update:
I bought another Orange Pi Plus 2E and it works perfectly the wifi, the other one that I have and for which I opened this post is defective.
