FOYU FO-Y3 MXQ Pro 8K 5G (Allwinner H3 + Kingston eMCP 08EMCP08-NL3DT227 8GB + 1GB DDR3)
The board is marked as MXQ-HX-V2.0.
CPU: Allwinner H3
DDR: 1GB LPDDR3 HS400
ROM: 8GB eMCP (both DDR and eMMC are on the same eMCP chip)
Wi-Fi: sv6256p
LAN: ?? (100Mb)
Here's a picture:
Before I start soldering the headers for the serial port and start debugging myself... has anyone any idea if there are compatible images among the ones already available?
I've already tried:
Beelink X2
Orange Pi PC
Orange Pi PC +
Orange Pi Zero
Sunvell R69
and none of these worked.
Thanks!
Edited by donluca
Here's the bootlog taken from the serial port:
https://pastebin.com/ctKEHm3m
EDIT: ok, I basically have the same issue as this:
Is there any chance a maintainer could add to the community repository a version with u-boot configured for LPDDR3 running at 336Mhz (DRAM value: 003939f9)?
Edited by donluca
It seems like I'm still unable to boot, even with a custom u-boot I made, making sure that the RAM configuration is correct.
Can anyone confirm that the following options are correct?
CONFIG_DRAM_CLK=336
CONFIG_DRAM_ZQ=3750393
CONFIG_DRAM_TYPE=7
Those are based on the bootlog I've posted previously.
I'm using the configuration for the OrangePi PC which has similar hardware.
The error I get is DRAM: 0MiB
Edited by donluca
Sorry I didn't.
In the end I just returned the item to the seller because it was different from the one listed (which was an actual MXQ Pro and not a fake one).
