rock64 Tvheadend problem with Kernel 5.15.y current
I installed tvheadend on Armbian 22.08 Jammy and Bullseye using the 5.15 kernel.  Tvheadend runs fine for a while and then freezes and disconnects filling the log file with the following message:
rock64 kernel : au0828: recv_control_msg() Failed receiving control message, error -71.
At first I thought it was a problem with Jammy, but I still had the same problem on Bullseye.  So I switched to the legacy kernel 4.4.213-rockchip64  and  I do not have the problem.
I am using a Rock64 Ver. 2 with usb dvb tuner for tvheadend and it is stable running Bullseye with kernel 4.4.213.
I am not sure what changed between these kernel versions, but it seems to cause this problem.
