SonicXiang Posted November 28, 2022 Posted November 28, 2022 (edited) Can this Community build upgrade by running apt update & apt upgrade? Edited November 28, 2022 by SonicXiang
SteeMan Posted November 28, 2022 Posted November 28, 2022 @SonicXiang It should work. I haven't tested a kernel upgrade yet, but if it doesn't work, that would be a bug that needs to be fixed.
SonicXiang Posted November 28, 2022 Author Posted November 28, 2022 Got following error where upgrade from 6.0.7 to 6.0.8 and 6.0.8 to 6.0.10. Running on a s905l box with meson-gxl-s905x-p212.dtb aml-s9xx-box:~:# apt upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 1 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] y Setting up linux-image-edge-meson64 (22.11.0-trunk.0138) ... * dkms: running auto installation service for kernel 6.0.10-meson64 [ OK ] update-initramfs: Generating /boot/initrd.img-6.0.10-meson64 W: Couldn't identify type of root file system for fsck hook update-initramfs: Converting to u-boot format Free space after deleting the package linux-image-edge-meson64 in /boot: 396M mv: cannot stat '/boot/vmlinuz-6.0.10-meson64': No such file or directory dpkg: error processing package linux-image-edge-meson64 (--configure): installed linux-image-edge-meson64 package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: linux-image-edge-meson64 E: Sub-process /usr/bin/dpkg returned an error code (1)
SteeMan Posted November 28, 2022 Posted November 28, 2022 @SonicXiang Did the upgrade work (is the new kerkel installed)? Or is the box left unbootable?
SonicXiang Posted November 28, 2022 Author Posted November 28, 2022 The upgrade seems works good,. Kernal version is 6.0.10 after reboot.
SonicXiang Posted December 7, 2022 Author Posted December 7, 2022 Succeed upgrade kernel from 6.0.10 to 6.0.11
SteeMan Posted December 7, 2022 Posted December 7, 2022 I should have added a comment to this thread that I created a fix for this issue and it was pushed to mainline a few days ago.
Gaaf Posted February 9, 2023 Posted February 9, 2023 When doing an upgrade with apt, how does one obtain new versions for these packages? armbian-bsp-cli-aml-s9xx-box linux-u-boot-aml-s9xx-box-edge I've been able to update all Armbian packages to 2023.2.0 except these, which are stuck at 2022.11.0 as they're not in any repository I could find.
Gaaf Posted February 10, 2023 Posted February 10, 2023 Well, after installing to eMMC yesterday, today I suddenly got a new version of armbian-bsp-cli-aml-s9xx-box and linux-u-boot-aml-s9xx-box-edge got a replacement in linux-u-boot-aml-s9xx-box-current. No idea why/how these were suddenly available.
SteeMan Posted February 10, 2023 Posted February 10, 2023 @Gaaf What version did you originally have installed (file name and download location)? How did you upgrade from 22.11.0 to 23.2.0? It looks like you are switching from the current stable kernel to the unstable edge kernel? How did you switch? Is that what you intended? Basically I need more information about your environment and how you have upgraded it, to be able to explain what you are seeing.
tnt Posted March 21, 2023 Posted March 21, 2023 (edited) Hi all! I tried to put the version https://github.com/armbian/community/releases/download/202307/Armbian_23.02.0-trunk_Aml-s9xx-box_lunar_edge_6.2.0-rc3_xfce_desktop.img.xz#aml-s9xx-box on tv box. Installation takes place both on the SD card and on emmc. But the following errors got in: 1. There is no entry about the user in /etc/sudoers, so the sudo command does not work. 2. The apt-get upgrade command results in a brick. Can anyone suggest a solution to problem #2? Running on a s912(mecool m8s pro l) box with meson-gxm-q201.dtb ERRORS: Failed to try-restart systemd-networkd.service: Unit systemd-networkd.service is masked. Setting file flags is only supported on regular files and directories, cannot set on '/var/log/journal'. Setting file flags is only supported on regular files and directories, cannot set on '/var/log/journal'. Failed to try-restart systemd-networkd.service: Unit systemd-networkd.service is masked. (Reading database ... 184652 files and directories currently installed.) Errors were encountered while processing: initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1) Edited March 21, 2023 by tnt add err
SteeMan Posted March 21, 2023 Posted March 21, 2023 @tnt Two things I'll note. Unless you are only testing, you should use the stable builds (not the unstable development community builds) located here: https://redirect.armbian.com/aml-s9xx-box/archive/ Second, in moving to the new armbian build framework post 23.02 release, there is an incompatible change in how the kernel .deb package is installed. After this change there no longer is a /boot/uImage file created. So the /boot/extlinux/extlinux.conf file will need to be changed if you upgrade to a later built kernel changing from uImage to Image. I don't know if this might be what you are running into, or some other instability in the development/unstable tree.
tnt Posted March 21, 2023 Posted March 21, 2023 On 3/21/2023 at 12:31 PM, SteeMan said: Unless you are only testing, you should use the stable builds (not the unstable development community builds) located here: https://redirect.armbian.com/aml-s9xx-box/archive/ Expand Sorry I didn't see this location. On 3/21/2023 at 12:31 PM, SteeMan said: After this change there no longer is a /boot/uImage file created. So the /boot/extlinux/extlinux.conf file will need to be changed if you upgrade to a later built kernel changing from uImage to Image. Expand It really helped, I didn't pay attention to the Image file even though I checked extlinux.conf
