How to get a working LED/VFD front display on Tanix TX3 mini-A?
Since I'm less than a noob in linux, can anyone please help me with the commands that I need to execute the following instructions?
Thanks in advance.
Instructions:
1. Install the dtb file meson-gxl-s905w-tx3-mini-vfd.dtb.gz and boot your tx3 box with this file. (This assumes that you boot from SD/USB so that you don't risk bricking your box.)
2. Download the vfd code (module and daemon) tarball vfdd-20181209.tar.xz from a link at the bottom of the page http://www.rvq.fr/linux/tanix-vfd.php and unpack it someplace on your tx3 box.
3. Build the vfd module (natively): Install the *.deb package from Balbes/Armbian with linux kernel headers for the kernel you are running. Then, copy the contents of vfdd-20181209/vfdmod/vfdmod/ to some place in the kernel headers tree, say drivers/vfd Go to drivers/vfd and write up a Makefile somewhat like this;
    KERNEL_SOURCE := /usr/src/linux-headers-4.19.7-aml-s9xxx
    PWD := $(shell pwd)
    default:
        ${MAKE} -C ${KERNEL_SOURCE} M=${PWD} modules
    clean:
        ${MAKE} -C ${KERNEL_SOURCE} M=${PWD} clean
   Run 'make' and build the module vfdmod.ko
4. Check that the module loads: insmod vfdmod.ko
5. Build the daemon vfdd: Go to the directory vfdd-20181209/ and run make. The daemon executable vfdd should emerge. After inspection/editing of the Makefile in vfdd-20181209/ (e.g. BINDIR, ETCDIR) you can run 'make install' to copy the the daemon executable and configuration file to their proper locations (or do this manually).
6. Test the daemon: Check the vfd conf file (default /etc/vfd.conf) and edit according to taste, or leave as-is. Start the daemon with recipe as in vfdd-20181209/vfdd.runit.in If everything is OK some nice little numbers and symbols should now emerge on the front LED display of your tx3 box.
Note:
The dtb file meson-gxl-s905w-tx3-mini-vfd.dtb (md5sum is fe846c5c3c7903b15c0725c2bd289fe5) is an augmentation of the Balbes/Armbian file meson-gxl-s905w-tx3-mini.dtb where the following definition has been added/compiled in (method; hack to Balbes' Armbian cross compile build environment) to support vfd (as per recipe in vfdd-20181209):
    meson-vfd {
        compatible = "amlogic,aml_vfd";
        dev_name = "meson-vfd";
        status = "okay";
        gpios = <&gpio_ao GPIOAO_4  GPIO_ACTIVE_HIGH>,  /* STB */
            <&gpio GPIODV_27 GPIO_ACTIVE_HIGH>,  /* CLK */
            <&gpio GPIODV_26 GPIO_ACTIVE_HIGH>;  /* DI/DO */
   (A dtb file can easily be decompiled and inspected by decompiling it with dtc, the device tree compiler.)
  On 12/7/2022 at 4:29 AM, joaormn said:
4.19.7
Expand
Not sure where you got those instructions from, but given that they are for an ancient kernel version, there is no way they are going to work with current builds.
