konki Posted December 10, 2022 Share Posted December 10, 2022 Hello dear armbianites, I'm trying to make the hc1 optimization for the odroid HC2 board permanent, every time the kernel is updated, armbiam loses the optimization and an admin action is needed to apply the optimization again via ambianconfig > System DTB > optimized board configuration, followed by a reboot. My Odroid HC2 suffers from temperature sensor problems, which can be easily bypassed. But I avoid restarts of this server which hosts an OMV instance for personal needs. I understand that the /boot/armbianEnv.txt file passes the information to /boot/boot.ini, but this file seems to be overwritten when the kernel is updated! is there any possibility of upstream action like 'first.boot' after update? konki 0 Quote Link to comment Share on other sites More sharing options...
Myron Posted December 11, 2022 Share Posted December 11, 2022 If possible, please provide diagnostic logs with ... armbianmonitor -u ... and post the link here. It'll may help others determine what the issue is. 0 Quote Link to comment Share on other sites More sharing options...
konki Posted December 11, 2022 Author Share Posted December 11, 2022 hi, here is a log before the kernel update: https://paste.armbian.com/xawajuyito the board loses HC1 optimization just after apt-upgrade, here is a log before reboot: https://paste.armbian.com/itocatefak I apply hc1 optimization again via ambianconfig>System DTB >optimized board configuration, before reboot the board crashed during reboot several times before finally booting completely: https://paste.armbian.com/gufozeyedi /boot/armbianEnv.txt contained 2 lines board_name=hc1 after reboot! This is not my initial question, but it's a problem I've encountered for at least 6-8 months, hardware or software problem? Thanks konki 0 Quote Link to comment Share on other sites More sharing options...
konki Posted March 1, 2023 Author Share Posted March 1, 2023 Hi, I ended up by disabling the kernel update (the loaded kernel is Linux 5.4.225-odroidxu4). My odroidhc2 has been running for over 3 months now. This is a workaround not a solution! Is there a solution to freeze the HC1/HC2 optimization during the kernel update? Thanks konki 0 Quote Link to comment Share on other sites More sharing options...
