I have a box with a s905w cpu. The idea is to install Linux to run klipper in my 3d printer. My age doesn't help a lot (65). But still love to learn new things. So the box will be used as a server. Am I in the right direction if I use this instruction to install? Any help is well appreciated.
I moved your post to a new topic.  But to answer your question, yes, you are going down the right path.  What model TV box do you have?
Post back once you have tried the install using the instructions in the FAQ and let us know how things went.
