I've flashed the Armbian SPI image following these instructions: https://wiki.radxa.com/Rock5/install/spi
I've flashed this image: Armbian_22.11.2_Rock-5b_jammy_legacy_5.10.110_gnome_desktop.img.xz to a M.2 NVME SSD
I own a DVB-S2 USB 2.0 device from PCTVSystems: https://www.linuxtv.org/wiki/index.php/Pinnacle_PCTV_DVB-S2_Stick_(461e) currently working in a RPi4 with OSMC.
Firmware file (dvb-demod-m88ds3103.fw) is on /lib/firmware
When I connect it to Rock5b I can see it with lsusb command
Bus 002 Device 003: ID 2013:0258 PCTV Systems DVB-S2 Stick 461e
and dmesg
usb 2-1: new high-speed USB device number 3 using ehci-platform
usb 2-1: New USB device found, idVendor=2013, idProduct=0258, bcdDevice= 1.00
usb 2-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
usb 2-1: Product: PCTV 461
usb 2-1: Manufacturer: PCTV
usb 2-1: SerialNumber: 0011530470
But I fail to see it on /dev (on the RPi4 i can see it as /dev/dvb)
Any suggestion? How to diagnose this particular issue?
Thanks,
chapas
If you see the device with lsusb, it is just that (the device is plugged in).
Do you see the modules needed to use the device?
The third step might making a link from the usb-device to /dev/dvb
I would  suggest testing lsmod on the RPI with the DVB plugged in.
Then a "ls -ali /dev/" with the DVB plugged in (the "-al" should be obvious, the "i", checking the inodes, is especially important for devices).
If the plugins are not available, it is probably not going to work with the vendor kernel.
If the /dev/dvb is the only part missing it probably can be fixed with some udev rules.
