bryant Posted December 20, 2022 Share Posted December 20, 2022 Hi, my previous Armbian (21.08.1 focal 5.10.60 desktop) was successfully installed to emmc. (install_aml_gxl_emmc.sh) After I tried the latest firmware (Armbian_23.02.0-trunk_Aml-s9xx-box_kinetic_edge_6.0.12_xfce_desktop), I felt a big change in speed. The problem is, I've tried several times to move it to emmc and it always fails to boot. (install-aml.sh) Any suggestions I need to look into before running the script again? Thank you 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted December 20, 2022 Share Posted December 20, 2022 4 hours ago, bryant said: install_aml_gxl_emmc.sh What build (exact file name) and download location did you have installed? This file you mention isn't anything I am familiar with, thus I would like to know where it came from. 0 Quote Link to comment Share on other sites More sharing options...
bryant Posted December 20, 2022 Author Share Posted December 20, 2022 Armbian_21.08.1_Amlogic-GXL_focal_current_5.10.60_desktop.img I followed a tutorial from youtube. If you need the .sh file, I'll attach it. #!/bin/sh echo "Start script create MBR and filesystem" hasdrives=$(lsblk | grep -oE '(mmcblk[0-9])' | sort | uniq) if [ "$hasdrives" = "" ] then echo "UNABLE TO FIND ANY EMMC OR SD DRIVES ON THIS SYSTEM!!! " exit 1 fi avail=$(lsblk | grep -oE '(mmcblk[0-9]|sda[0-9])' | sort | uniq) if [ "$avail" = "" ] then echo "UNABLE TO FIND ANY DRIVES ON THIS SYSTEM!!!" exit 1 fi runfrom=$(lsblk | grep /$ | grep -oE '(mmcblk[0-9]|sda[0-9])') if [ "$runfrom" = "" ] then echo " UNABLE TO FIND ROOT OF THE RUNNING SYSTEM!!! " exit 1 fi emmc=$(echo $avail | sed "s/$runfrom//" | sed "s/sd[a-z][0-9]//g" | sed "s/ //g") if [ "$emmc" = "" ] then echo " UNABLE TO FIND YOUR EMMC DRIVE OR YOU ALREADY RUN FROM EMMC!!!" exit 1 fi if [ "$runfrom" = "$avail" ] then echo " YOU ARE RUNNING ALREADY FROM EMMC!!! " exit 1 fi if [ $runfrom = $emmc ] then echo " YOU ARE RUNNING ALREADY FROM EMMC!!! " exit 1 fi if [ "$(echo $emmc | grep mmcblk)" = "" ] then echo " YOU DO NOT APPEAR TO HAVE AN EMMC DRIVE!!! " exit 1 fi DEV_EMMC="/dev/$emmc" echo $DEV_EMMC echo "Start backup u-boot default" dd if="${DEV_EMMC}" of=/root/u-boot-default-aml.img bs=1M count=4 echo "Start create MBR and partittion" parted -s "${DEV_EMMC}" mklabel msdos parted -s "${DEV_EMMC}" mkpart primary fat32 700M 956M parted -s "${DEV_EMMC}" mkpart primary ext4 957M 100% echo "Start restore u-boot" dd if=/root/u-boot-default-aml.img of="${DEV_EMMC}" conv=fsync bs=1 count=442 dd if=/root/u-boot-default-aml.img of="${DEV_EMMC}" conv=fsync bs=512 skip=1 seek=1 sync echo "Done" echo "Start copy system for eMMC." mkdir -p /ddbr chmod 777 /ddbr PART_BOOT="${DEV_EMMC}p1" PART_ROOT="${DEV_EMMC}p2" DIR_INSTALL="/ddbr/install" if [ -d $DIR_INSTALL ] ; then rm -rf $DIR_INSTALL fi mkdir -p $DIR_INSTALL if grep -q $PART_BOOT /proc/mounts ; then echo "Unmounting BOOT partiton." umount -f $PART_BOOT fi echo -n "Formatting BOOT partition..." mkfs.vfat -n "BOOT_EMMC" $PART_BOOT echo "done." mount -o rw $PART_BOOT $DIR_INSTALL echo -n "Cppying BOOT..." cp -r /boot/* $DIR_INSTALL && sync echo "done." echo -n "Edit init config..." sed -e "s/ROOTFS/ROOT_EMMC/g" \ -i "$DIR_INSTALL/extlinux/extlinux.conf" echo "done." rm $DIR_INSTALL/s9* rm $DIR_INSTALL/aml* if [ -f /boot/u-boot.ext ] ; then mv -f $DIR_INSTALL/u-boot.ext $DIR_INSTALL/u-boot.emmc sed -e "s/u-boot.ext/u-boot.emmc/g" \ -i "$DIR_INSTALL/boot.ini" echo "done." sync fi umount $DIR_INSTALL if grep -q $PART_ROOT /proc/mounts ; then echo "Unmounting ROOT partiton." umount -f $PART_ROOT fi echo "Formatting ROOT partition..." mke2fs -F -q -t ext4 -L ROOT_EMMC -m 0 $PART_ROOT e2fsck -n $PART_ROOT echo "done." echo "Copying ROOTFS." mount -o rw $PART_ROOT $DIR_INSTALL cd / echo "Copy BIN" tar -cf - bin | (cd $DIR_INSTALL; tar -xpf -) #echo "Copy BOOT" #mkdir -p $DIR_INSTALL/boot #tar -cf - boot | (cd $DIR_INSTALL; tar -xpf -) echo "Create DEV" mkdir -p $DIR_INSTALL/dev #tar -cf - dev | (cd $DIR_INSTALL; tar -xpf -) echo "Copy ETC" tar -cf - etc | (cd $DIR_INSTALL; tar -xpf -) echo "Copy HOME" tar -cf - home | (cd $DIR_INSTALL; tar -xpf -) echo "Copy LIB" tar -cf - lib | (cd $DIR_INSTALL; tar -xpf -) echo "Create MEDIA" mkdir -p $DIR_INSTALL/media #tar -cf - media | (cd $DIR_INSTALL; tar -xpf -) echo "Create MNT" mkdir -p $DIR_INSTALL/mnt #tar -cf - mnt | (cd $DIR_INSTALL; tar -xpf -) echo "Copy OPT" tar -cf - opt | (cd $DIR_INSTALL; tar -xpf -) echo "Create PROC" mkdir -p $DIR_INSTALL/proc echo "Copy ROOT" tar -cf - root | (cd $DIR_INSTALL; tar -xpf -) echo "Create RUN" mkdir -p $DIR_INSTALL/run echo "Copy SBIN" tar -cf - sbin | (cd $DIR_INSTALL; tar -xpf -) echo "Copy SELINUX" tar -cf - selinux | (cd $DIR_INSTALL; tar -xpf -) echo "Copy SRV" tar -cf - srv | (cd $DIR_INSTALL; tar -xpf -) echo "Create SYS" mkdir -p $DIR_INSTALL/sys echo "Create TMP" mkdir -p $DIR_INSTALL/tmp echo "Copy USR" tar -cf - usr | (cd $DIR_INSTALL; tar -xpf -) echo "Copy VAR" tar -cf - var | (cd $DIR_INSTALL; tar -xpf -) sync echo "Copy fstab" rm $DIR_INSTALL/etc/fstab cp -a /root/fstab $DIR_INSTALL/etc/fstab rm $DIR_INSTALL/root/install*.sh rm $DIR_INSTALL/root/fstab cd / sync umount $DIR_INSTALL echo "*******************************************" echo "Complete copy OS to eMMC " echo "*******************************************" Thank you 😊 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted December 20, 2022 Share Posted December 20, 2022 2 hours ago, SteeMan said: download location Where did you download this build from? It doesn't look like a build that originated from armbian. 54 minutes ago, bryant said: I followed a tutorial from youtube What tutorial? 0 Quote Link to comment Share on other sites More sharing options...
bryant Posted December 21, 2022 Author Share Posted December 21, 2022 Previously, I knew Armbian from YouTube and downloaded it from the link given in the description. I hope the version I'm using now (Armbian_23.02.0-trunk_Aml-s9xx-box_kinetic_edge_6.0.12_xfce_desktop) can be installed on eMMC, because it's more stable and faster 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted December 21, 2022 Share Posted December 21, 2022 Since I don't know what previous version you had installed in emmc (i.e. where it came from, who built it, etc). That means from my perspective you are trying to run the emmc install script on top of an unknown environment. So i'm left to guessing what your issues might be. The cleanest solution would be to flash android back to the emmc so you have a known starting point and then reinstalling the current armbian build. This assumes you have/can find a copy of android firmware for your box, or that you made a backup before you installed to emmc. If that doesn't work, I suspect the problem is that you are trying to 'reinstall' into emmc. The script is only tested for installing into a fresh environment that has android on it, not an environment that already has linux. So you may need to look at the script and only do the portions that are involved in the copying over of the files from the sd card, but omit that part that is creating the partitions and other work on the disk. To verify this is what is happening, I would need you to capture the entire output of your running of the install-aml.sh script for me to review. 0 Quote Link to comment Share on other sites More sharing options...
bryant Posted December 21, 2022 Author Share Posted December 21, 2022 Okay, i'll try to run install-aml.sh Thank you 😊 0 Quote Link to comment Share on other sites More sharing options...
bryant Posted December 26, 2022 Author Share Posted December 26, 2022 On 12/21/2022 at 8:16 PM, SteeMan said: To verify this is what is happening, I would need you to capture the entire output of your running of the install-aml.sh script for me to review Sory for late posting . I'm a bit busy at work. You mean the log? 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted December 27, 2022 Share Posted December 27, 2022 The output from running install-aml.sh 0 Quote Link to comment Share on other sites More sharing options...
bacco70 Posted March 4, 2023 Share Posted March 4, 2023 Hello, i have similar problem, seem to be installed but dont boot, the log is here: root@S905x:~# ./install-aml.sh Start script create MBR and filesystem /dev/mmcblk1 Start backup u-boot default 4+0 records in 4+0 records out 4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.461703 s, 9.1 MB/s Start create MBR and partittion Start restore u-boot 442+0 records in 442+0 records out 442 bytes copied, 0.00630148 s, 70.1 kB/s 8191+0 records in 8191+0 records out 4193792 bytes (4.2 MB, 4.0 MiB) copied, 1.05499 s, 4.0 MB/s Done Start copy system for eMMC. Formatting BOOT partition...mkfs.fat 4.2 (2021-01-31) done. Copying BOOT...done. Edit init config...done. sed: can't read /ddbr/install/boot.ini: No such file or directory done. Formatting ROOT partition... /dev/mmcblk1p2 contains a ext4 file system labelled 'ROOT_EMMC' last mounted on /ddbr/install on Sat Mar 4 12:38:17 2023 e2fsck 1.46.5 (30-Dec-2021) ROOT_EMMC: clean, 11/385024 files, 46572/1539328 blocks done. Copying ROOTFS. Copy BIN Create DEV Copy ETC Copy HOME Copy LIB Copy LIB64 tar: lib64: Cannot stat: No such file or directory tar: Exiting with failure status due to previous errors Create MEDIA Create MNT Copy OPT Create PROC Copy ROOT Create RUN Copy SBIN Copy SELINUX Copy SRV Create SYS Create TMP Copy USR Copy VAR tar: var/lib/samba/private/msg.sock/4572: socket ignored tar: var/lib/samba/private/msg.sock/2230: socket ignored tar: var/lib/samba/private/msg.sock/2203: socket ignored tar: var/lib/samba/private/msg.sock/4560: socket ignored tar: var/lib/samba/private/msg.sock/2187: socket ignored tar: var/lib/samba/private/msg.sock/2082: socket ignored tar: var/lib/samba/private/msg.sock/2073: socket ignored tar: var/lib/samba/private/msg.sock/2186: socket ignored tar: var/lib/samba/private/msg.sock/2070: socket ignored tar: var/lib/samba/private/msg.sock/2078: socket ignored tar: var/lib/samba/private/msg.sock/4573: socket ignored tar: var/lib/samba/private/msg.sock/2053: socket ignored tar: var/lib/samba/private/msg.sock/2071: socket ignored tar: var/lib/samba/private/msg.sock/2079: socket ignored tar: var/lib/samba/private/msg.sock/1940: socket ignored tar: var/lib/samba/private/msg.sock/2072: socket ignored tar: var/lib/samba/private/msg.sock/2063: socket ignored tar: var/lib/samba/private/msg.sock/2081: socket ignored tar: var/lib/samba/private/msg.sock/2068: socket ignored tar: var/lib/samba/private/msg.sock/1991: socket ignored Copy fstab rm: cannot remove '/ddbr/install/usr/bin/ddbr': No such file or directory ******************************************* Complete copy OS to eMMC ******************************************* 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted March 5, 2023 Share Posted March 5, 2023 @bacco70 Please provide some basic information about your setup. What box do you have? What build do you have installed (file name and where downloaded from)? 13 hours ago, bacco70 said: Formatting ROOT partition... /dev/mmcblk1p2 contains a ext4 file system labelled 'ROOT_EMMC' last mounted on /ddbr/install on Sat Mar 4 12:38:17 2023 This would indicate that you are trying to install on to a none clean emmc. The script assumes you are installing on top of the native android firmware. This message indicates you have other stuff previously installed. Please explain what you have done before this attempt. 0 Quote Link to comment Share on other sites More sharing options...
bacco70 Posted March 5, 2023 Share Posted March 5, 2023 (edited) 8 hours ago, SteeMan said: This would indicate that you are trying to install on to a none clean emmc. The script assumes you are installing on top of the native android firmware. This message indicates you have other stuff previously installed. Please explain what you have done before this attempt. Yes, this is 2nd or 3rt try, but the 1st was no good also. i have try with various images, 23.02.2 bullseye and jammy, but the result was the same keep from https://imola.armbian.com/dl/aml-s9xx-box/archive/ now reflash android rom and do claen install, the box dont boot, uboot start but dont find the kernel? Edited March 5, 2023 by bacco70 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted March 5, 2023 Share Posted March 5, 2023 10 hours ago, SteeMan said: Please provide some basic information about your setup. What box do you have? 0 Quote Link to comment Share on other sites More sharing options...
bacco70 Posted March 5, 2023 Share Posted March 5, 2023 (edited) excelvan t95n s905x 1Gb ram 8Gb emmc during install to emmc, miss 1 file, boot.ini. you know if is possible to put this file in boot folder to configure u-boot? Edited March 5, 2023 by bacco70 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted March 9, 2023 Share Posted March 9, 2023 The aml-s9xx-box builds don't use a boot.ini file. 0 Quote Link to comment Share on other sites More sharing options...
ext23 Posted October 16, 2023 Share Posted October 16, 2023 First of all, thank you so much for your guide. I was able to turn a $20 Android TV box into a PiHole. However it's been giving me errors which I suspect are due to the SD card, and so I would like to install to emmc. Running sh install-aml.sh says UNABLE TO FIND ROOT OF THE RUNNING SYSTEM!!! I am currently booting it with meson-gxl-s905l2-ipbs9505.dtb. Is this impossible to write to emmc? 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted October 16, 2023 Share Posted October 16, 2023 @ext23 What box do you have? (The thread you have posted this question in is for a B680H). What build are you using? I've never seen that dtb file, where did you get it from? 0 Quote Link to comment Share on other sites More sharing options...
ext23 Posted October 16, 2023 Share Posted October 16, 2023 I bought a generic box on AliExpress that said it was the S905X but I am now led to believe that it's an S905L2. I got the dtb from here https://github.com/ophub/amlogic-s9xxx-armbian and am using Armbian_23.8.1_Aml-s9xx-box_bookworm_current_6.1.50_minimal. Sorry if this is too far off topic, I just wanted to confirm whether it's possible for me to install to emmc. 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted October 16, 2023 Share Posted October 16, 2023 The dtb you downloaded is not from armbian. That site is a fork of armbian and they use the armbian name without permission. They do not participate in armbian development, nor do they contribute to these forums. The armbian build you did download doesn't support the s905l2 specifically (there are no dtbs in the mainline linux kernel for that specific cpu). I don't have any boxes with this chip so it is unlikely that I or anyone here has much guidance for you. 0 Quote Link to comment Share on other sites More sharing options...
ext23 Posted October 17, 2023 Share Posted October 17, 2023 OK thank you! I am a beginner so I am learning as I'm going. I will be careful to only use reputable dtbs from now on. 0 Quote Link to comment Share on other sites More sharing options...
