Good evening guy's and happy New year.......Need some help to install armbian 22.05 jammy in tvbox mxq-4k ....... I have installed successfully 21.08 buster with multitool.... When ill try to install jammy i have error...i suppose run only legacy version and not find  this version......little help to fix kernel
I'm assuming since you mention multitool that your box is rockchip based.  Moving to the rockchip TV box forum.
when you run the multitool, did it prompt you a message mentioning  that box your using is using NAND chip, if it does then you need to use legacy images which can be found here. You can only run later latest images via SD card or via USB with NAND bootloader upgrade.
and even if you try flashing non-legacy image on NAND system, it will just error out during early boot process mentioning it cant mount something.
to be honest if you have a NAND model, you might as well just use the SD card slot to run armbian.
