BuddhaChrist Posted January 11, 2023 Share Posted January 11, 2023 I got my H96 pro+ to boot into Armbian using the S912 .dtb file (meson-gxm-s912-libretech-pc.dtb) and u-boot-s905x-s912 I get the loading screen, then a black screen with a cursor, and then repeated [FAILED] messages: about a dozen "Failed to start access point and authentication server for WiFi and Ethernet", then "Failed to listen on OpenBSD Secure Shell server socket" Then [ 177.5586911] systemd-journald[1045]: Data hash table of /var/log/journal/e8131ef5db8049a6a008b6f40cd0e8eb/system.journal has fill level at 75.0 (3415 of 4551 items, 2621440 file size, 767 bytes per hash table item), suggest rotation. [ 177.5586911] systemd-journald[1045]: Data hash table of /var/log/journal/e8131ef5db8049a6a008b6f40cd0e8eb/system.journal Journal header limits reached or header out of date, rotating. Any thoughts? Link to comment Share on other sites More sharing options...
SteeMan Posted January 15, 2023 Share Posted January 15, 2023 Please provide some basic information. What build are you using? What u-boot.ext? Screen shots of what you are seeing during the boot process would help. From your post it seems the system is booting, so I'm not sure what problems you are reporting without more details. Link to comment Share on other sites More sharing options...
