BHM Posted January 28, 2023 Share Posted January 28, 2023 Getting free() invalid pointer issue when installing / using python3. Could be dpkg issue as well ! When I did sudo apt update && sudo apt upgrade, it happened and hence I tried to reinstall. This issue occurs when trying to manage it with ansible as well. I think something might be wrong with the latest python. Board: Helios64 (I know, I know CSC) Chipset: RK3399 Apt install logs: Reading package lists... Done Building dependency tree... Done Reading state information... Done 0 upgraded, 0 newly installed, 2 reinstalled, 0 to remove and 0 not upgraded. Need to get 0 B/472 kB of archives. After this operation, 0 B of additional disk space will be used. (Reading database ... 44574 files and directories currently installed.) Preparing to unpack .../python3-pkg-resources_59.6.0-1.2ubuntu0.22.04.1_all.deb ... double free or corruption (out) Aborted dpkg: warning: old python3-pkg-resources package pre-removal script subprocess returned error exit status 134 dpkg: trying script from the new package instead ... dpkg: ... it looks like that went OK Unpacking python3-pkg-resources (59.6.0-1.2ubuntu0.22.04.1) over (59.6.0-1.2ubuntu0.22.04.1) ... Preparing to unpack .../python3-setuptools_59.6.0-1.2ubuntu0.22.04.1_all.deb ... Unpacking python3-setuptools (59.6.0-1.2ubuntu0.22.04.1) over (59.6.0-1.2ubuntu0.22.04.1) ... Setting up python3-pkg-resources (59.6.0-1.2ubuntu0.22.04.1) ... Setting up python3-setuptools (59.6.0-1.2ubuntu0.22.04.1) ... free(): invalid pointer Aborted dpkg: error processing package python3-setuptools (--configure): installed python3-setuptools package post-installation script subprocess returned error exit status 134 Errors were encountered while processing: python3-setuptools E: Sub-process /usr/bin/dpkg returned an error code (1) Ansible logs: ansible_facts: {} failed_modules: ansible.legacy.setup: ansible_facts: discovered_interpreter_python: /usr/bin/python3 failed: true module_stderr: |- free(): invalid pointer Aborted module_stdout: '' msg: |- MODULE FAILURE See stdout/stderr for the exact error rc: 134 msg: |- The following modules failed to execute: ansible.legacy.setup 0 Quote Link to comment Share on other sites More sharing options...
BHM Posted January 29, 2023 Author Share Posted January 29, 2023 (edited) Cross linking to the github issue - https://github.com/armbian/build/issues/4761 Edited January 29, 2023 by BHM 0 Quote Link to comment Share on other sites More sharing options...
prahal Posted February 6, 2023 Share Posted February 6, 2023 I bet next step is to rebuild our kernel with KASAN turned on in the kernel config. 0 Quote Link to comment Share on other sites More sharing options...
prahal Posted February 6, 2023 Share Posted February 6, 2023 Do you also get kernel error messages in the kernel log (journalctl -b -k, or dmesg output)? 0 Quote Link to comment Share on other sites More sharing options...
prahal Posted February 15, 2023 Share Posted February 15, 2023 Made a test case that reproduces the issue: $ cat test-pkg_resources.py import pkg_resources print(pkg_resources.parse_version("2.3")) $ for i in $(seq 1 100);do python3 test-pkg_resources.py ;done 2.3 2.3 2.3 double free or corruption (out) Abandon (core dumped) 2.3 The kernel error I had where from failure to allocate (but as those errors stack trace shows it is a failure to allocate memory of a high order (big chunks) for the core dump generation). 0 Quote Link to comment Share on other sites More sharing options...
