Hello,
I'm using a orangepi pc with armbian and I want to boot (automatically if possible) from the usb flash drive where I flashed batoceda. Is it possible? And if so, would you have step by step?
Thanks a lot.
Since as you say you are not using armbian but Bateceda, the Armbian forums are not the proper place for your question.  You should ask your question in the Bateceda forums.
So strange,
my firts words were "Hello, I'm using a orangepi pc with armbian..." I thought it was pretty obvious that i'm actually using Armbian.
I'm a beginner, that's true, english is not my mother language, also true, but i'm looking for help to understand and learn. I thought that with a name like this (forum.armbian.com) in a section for beginners i could find some.
The thing is that i'm trying to build a  bootable usb for my device (whatever the os i'm looking to boot on).
I would appreciate if someone had a solution for that.
Thanks a lot.
