Hi After booting from the SD card, I try to write to the internal memory and the following error appears. Can anyone help?
armbian-install will not work on amlogic tv boxes.  Please follow the instructions here: https://forum.armbian.com/topic/17106-installation-instructions-for-tv-boxes-with-amlogic-cpus
Also, why did you abort the first run setup steps?  You may have left your box in an incomplete state that could cause issues in the future.
On further thought, I think your box has the s905 cpu.  And installation to emmc isn't possible on this cpu.  The next generation amlogic cpus (s905x) are supported for internal emmc install.
yes.... I can't write to emmc. Any tutorial to install homeassistant and boot directly from the card? or usb stick
If you have armbian running on the box from the sd card, you should be able to install home assistant following their instructions.  My son just did this on a box of mine, and he used the docker install of home assistant and it works fine.
