Good afternoon,
I run Armbian bullseye on my orangepi zeroplus2-h3.
My wifi hotspot causes the OS to reboot sometimes, with the error "xradio WSM-ERR: bh error!>>> 0x0012 (16)"
I use the NetworkManager conf files below for my wifi hotspot.
    echo """
[connection]
id=mywifi
uuid=58356325-7da4-4d1d-ad6b-54f33bfee335
type=wifi
autoconnect=false
interface-name=wlan0
permissions=
[wifi]
band=bg
mac-address-blacklist=
mode=ap
ssid=IQLINK-1
[wifi-security]
key-mgmt=wpa-psk
psk=123456789
[ipv4]
address1=192.168.43.1/24
dns-priority=2
dns-search=
method=shared
route-metric=2
[ipv6]
addr-gen-mode=stable-privacy
dns-priority=2
dns-search=
method=auto
route-metric=2
""" > /etc/NetworkManager/system-connections/mywifi.nmconnection
echo """[main]
dns=default
rc-manager=file
plugins=ifupdown,keyfile
[ifupdown]
managed=true
[device]
match-device=driver:wlan0
wifi.scan-rand-mac-address=no
""" > /etc/NetworkManager/NetworkManager.conf
I get the syslog error below and the OS reboot :
Feb  2 13:17:37 myhostname kernel: [ 2583.698290] xradio WSM-ERR: bh error!>>> 0x0006 (12)
Feb  2 13:17:37 myhostname kernel: [ 2583.698301] ------------[ cut here ]------------
Feb  2 13:17:37 myhostname kernel: [ 2583.698307] WARNING: CPU: 1 PID: 996 at drivers/net/wireless/xradio/ap.c:645 xradio_bss_info_changed+0x72f/0xb04 [xradio_wlan]
Feb  2 13:17:37 myhostname kernel: [ 2583.698376] Modules linked in: binfmt_misc nft_chain_nat xt_MASQUERADE xt_state xt_conntrack ipt_REJECT nf_reject_ipv4 nft_counter xt_tcpudp nft_compat nf_tables nfnetlink nf_nat_h323 nf_conntrack_h323 nf_nat_pptp nf_conntrack_pptp nf_nat_tftp nf_conntrack_tftp nf_nat_sip nf_conntrack_sip nf_nat_irc nf_conntrack_irc nf_nat_ftp nf_conntrack_ftp iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 option usb_wwan qmi_wwan usbserial cdc_wdm lz4hc lz4 zram xradio_wlan mac80211 smsc cfg80211 nls_iso8859_1 sun4i_gpadc_iio industrialio smsc95xx cdc_acm usbnet sun8i_thermal rfkill libarc4 uio_pdrv_genirq uio cpufreq_dt usb_f_acm u_serial g_serial libcomposite ip_tables x_tables autofs4 pwrseq_simple sunxi phy_generic
Feb  2 13:17:37 myhostname kernel: [ 2583.698679] CPU: 1 PID: 996 Comm: wpa_supplicant Tainted: G        W         5.15.89-sunxi #trunk
Feb  2 13:17:37 myhostname kernel: [ 2583.698694] Hardware name: Allwinner sun8i Family
Feb  2 13:17:37 myhostname kernel: [ 2583.698708] [<c010cd21>] (unwind_backtrace) from [<c01095f5>] (show_stack+0x11/0x14)
Feb  2 13:17:37 myhostname kernel: [ 2583.698737] [<c01095f5>] (show_stack) from [<c09e10b5>] (dump_stack_lvl+0x2b/0x34)
Feb  2 13:17:37 myhostname kernel: [ 2583.698766] [<c09e10b5>] (dump_stack_lvl) from [<c011c439>] (__warn+0xad/0xc0)
Feb  2 13:17:37 myhostname kernel: [ 2583.698792] [<c011c439>] (__warn) from [<c09dada7>] (warn_slowpath_fmt+0x43/0x7c)
Feb  2 13:17:37 myhostname kernel: [ 2583.698813] [<c09dada7>] (warn_slowpath_fmt) from [<bf9d6f47>] (xradio_bss_info_changed+0x72f/0xb04 [xradio_wlan])
Feb  2 13:17:37 myhostname kernel: [ 2583.698873] [<bf9d6f47>] (xradio_bss_info_changed [xradio_wlan]) from [<bf940a79>] (ieee80211_bss_info_change_notify+0x79/0x174 [mac80211])
Feb  2 13:17:37 myhostname kernel: [ 2583.699288] [<bf940a79>] (ieee80211_bss_info_change_notify [mac80211]) from [<bf952fd3>] (ieee80211_do_open+0x19f/0x5e8 [mac80211])
Feb  2 13:17:37 myhostname kernel: [ 2583.699678] [<bf952fd3>] (ieee80211_do_open [mac80211]) from [<bf9535bf>] (ieee80211_if_change_type+0x147/0x254 [mac80211])
Feb  2 13:17:37 myhostname kernel: [ 2583.700058] [<bf9535bf>] (ieee80211_if_change_type [mac80211]) from [<bf959373>] (ieee80211_change_iface+0x23/0x19c [mac80211])
Feb  2 13:17:37 myhostname kernel: [ 2583.700441] [<bf959373>] (ieee80211_change_iface [mac80211]) from [<bf8c3ff7>] (cfg80211_change_iface+0x107/0x2e4 [cfg80211])
Feb  2 13:17:37 myhostname kernel: [ 2583.701188] [<bf8c3ff7>] (cfg80211_change_iface [cfg80211]) from [<bf8e28cd>] (nl80211_set_interface+0xc9/0x164 [cfg80211])
Feb  2 13:17:37 myhostname kernel: [ 2583.701568] [<bf8e28cd>] (nl80211_set_interface [cfg80211]) from [<c08d9555>] (genl_rcv_msg+0x125/0x27c)
Feb  2 13:17:37 myhostname kernel: [ 2583.701761] [<c08d9555>] (genl_rcv_msg) from [<c08d899d>] (netlink_rcv_skb+0x81/0xb4)
Feb  2 13:17:37 myhostname kernel: [ 2583.701781] [<c08d899d>] (netlink_rcv_skb) from [<c08d8f9d>] (genl_rcv+0x21/0x30)
Feb  2 13:17:37 myhostname kernel: [ 2583.701799] [<c08d8f9d>] (genl_rcv) from [<c08d8301>] (netlink_unicast+0x125/0x1a4)
Feb  2 13:17:37 myhostname kernel: [ 2583.701816] [<c08d8301>] (netlink_unicast) from [<c08d851b>] (netlink_sendmsg+0x19b/0x36c)
Feb  2 13:17:37 myhostname kernel: [ 2583.701834] [<c08d851b>] (netlink_sendmsg) from [<c08601ef>] (sock_sendmsg+0x23/0x2c)
Feb  2 13:17:37 myhostname kernel: [ 2583.701858] [<c08601ef>] (sock_sendmsg) from [<c0860495>] (____sys_sendmsg+0x181/0x194)
Feb  2 13:17:37 myhostname kernel: [ 2583.701877] [<c0860495>] (____sys_sendmsg) from [<c08615e5>] (___sys_sendmsg+0x49/0x64)
Feb  2 13:17:37 myhostname kernel: [ 2583.701898] [<c08615e5>] (___sys_sendmsg) from [<c08618a7>] (__sys_sendmsg+0x37/0x58)
Feb  2 13:17:37 myhostname kernel: [ 2583.701918] [<c08618a7>] (__sys_sendmsg) from [<c0100061>] (ret_fast_syscall+0x1/0x52)
Feb  2 13:17:37 myhostname kernel: [ 2583.701939] Exception stack(0xcfdedfa8 to 0xcfdedff0)
Feb  2 13:17:37 myhostname kernel: [ 2583.701954] dfa0:                   01d9d868 01da4288 00000006 beb3f7c8 00000000 00000000
Feb  2 13:17:37 myhostname kernel: [ 2583.701968] dfc0: 01d9d868 01da4288 b6f651f0 00000128 b6f46000 00000001 00000004 01db6c68
Feb  2 13:17:37 myhostname kernel: [ 2583.701977] dfe0: 00000128 beb3f778 b6b5765f b6ad07e6
Feb  2 13:17:37 myhostname kernel: [ 2583.702054] ---[ end trace e554f90c3b6dcdf3 ]---
Feb  2 13:17:37 myhostname kernel: [ 2583.702077] xradio WSM-ERR: bh error!>>> 0x0012 (16)
Feb  2 13:17:37 myhostname kernel: [ 2583.702087] xradio STA-ERR: wsm_set_tx_queue_params failed!
Feb  2 13:17:37 myhostname kernel: [ 2583.702093] xradio WSM-ERR: bh error!>>> 0x0012 (16)
Feb  2 13:17:37 myhostname kernel: [ 2583.702100] xradio STA-ERR: wsm_set_tx_queue_params failed!
Feb  2 13:17:37 myhostname kernel: [ 2583.702106] xradio WSM-ERR: bh error!>>> 0x0012 (16)
Feb  2 13:17:37 myhostname kernel: [ 2583.702112] xradio STA-ERR: wsm_set_tx_queue_params failed!
Feb  2 13:17:37 myhostname kernel: [ 2583.702117] xradio WSM-ERR: bh error!>>> 0x0012 (16)
Feb  2 13:17:37 myhostname kernel: [ 2583.702124] xradio STA-ERR: wsm_set_tx_queue_params failed!
Feb  2 13:17:39 myhostname systemd[1]: systemd-rfkill.service: Succeeded.
Thanks for your help.
Clouvis
