jpm Posted February 9, 2023 Posted February 9, 2023 Has anyone managed to get video encoder working with the latest mainline kernel? I'm getting stuck trying to compile the cedar_ve kernel driver from https://github.com/uboborov/sunxi-cedar-mainline I have downloaded the kernel source using armbian-config and then built the sunxi-cedar-mainline kernel driver. However, I fail to load the driver due to version magic: Quote root@nanopineo:~# modprobe cedar_ve modprobe: ERROR: could not insert 'cedar_ve': Exec format error root@nanopineo:~# dmesg | tail -n 1 [ 653.998366] cedar_ve: version magic '5.15.80 SMP mod_unload ARMv7 thumb2 p2v8 ' should be '5.15.80-sunxi SMP mod_unload ARMv7 thumb2 p2v8 ' When trying to force the load: Quote root@nanopineo:~# modprobe -f cedar_ve modprobe: ERROR: could not insert 'cedar_ve': Exec format error But no dmesg message about magic check failure. 0 Quote
jpm Posted February 18, 2023 Author Posted February 18, 2023 Some updates: 1) Updated the dts file as required in https://github.com/uboborov/sunxi-cedar-mainline 2) Fixed cedar_ve compilation issues / kernel name 3) after loading the cedar_ve.ko, get only this is dmesg: Quote [ 71.096286] cedar_ve: loading out-of-tree module taints kernel. [ 71.097176] cedar_ve: module verification failed: signature and/or required key missing - tainting kernel [ 71.098546] sunxi cedar version 0.1 @ubobrov I would appreciate any insights. 0 Quote
jpm Posted February 19, 2023 Author Posted February 19, 2023 @ning Thanks for the link. But if I understand correctly - this is for decode. I need to encode h264. 0 Quote
schunckt Posted September 22, 2025 Posted September 22, 2025 Hi ! @jpm how exactly did you solve 2) Fixed cedar_ve compilation issues / kernel name ? I'm gettinf the same "modprobe: ERROR: could not insert 'cedar_ve': Exec format error" T. 0 Quote
sasa Posted September 29, 2025 Posted September 29, 2025 Hi, maybe someone will find this patch useful. It adds JPEG and H264 encoding to the main Cedrus driver. Both encoders use a stable stateful API, so they can be used with any multimedia software, such as gstreamer, ffmpeg, etc. gst-launch-1.0 videotestsrc pattern=smpte ! video/x-raw,width=1920,height=1080 ! v4l2h264enc ! h264parse ! matroskamux ! filesink location=test_h264.mkv gst-launch-1.0 videotestsrc ! v4l2jpegenc ! matroskamux ! filesink location=test_mjpeg.mkv I tested it on T113 (jpeg) and A40 (jpeg, h264) processors and I think it should work with H3 as well. It doesn't work with 64-bit processors like H616/T507 because their encoders have been updated, and as far as I know, they haven't been reverse-engineered yet. linux-6.12.28-cedrus-enc.patch 0 Quote
going Posted September 30, 2025 Posted September 30, 2025 14 часов назад, sasa сказал: Hi, maybe someone will find this patch useful. It adds JPEG and H264 encoding to the main Cedrus driver. Both encoders use a stable stateful API, so they can be used with any multimedia software, such as gstreamer, ffmpeg, etc. gst-launch-1.0 videotestsrc pattern=smpte ! video/x-raw,width=1920,height=1080 ! v4l2h264enc ! h264parse ! matroskamux ! filesink location=test_h264.mkv gst-launch-1.0 videotestsrc ! v4l2jpegenc ! matroskamux ! filesink location=test_mjpeg.mkv I tested it on T113 (jpeg) and A40 (jpeg, h264) processors and I think it should work with H3 as well. It doesn't work with 64-bit processors like H616/T507 because their encoders have been updated, and as far as I know, they haven't been reverse-engineered yet. linux-6.12.28-cedrus-enc.patch 66.8 \u041a\u0431 · 2 скачивания Please tell me the source of this patch. 0 Quote
sasa Posted September 30, 2025 Posted September 30, 2025 1 час назад, going сказал: Please tell me the source of this patch. This is internal development for our boards, unfortunately, there is no public repository for our kernel. The code is borrowed from reverse-engineered POCs h264 + * Based on https://github.com/jemk/cedrus + * Copyright (c) 2014-2015 Jens Kuske <jenskuske@gmail.com> jpeg + * Based on https://gitorious.org/recedro/jepoc + * Copyright (c) 2014 Manuel Braga <mul.braga@gmail.com> 0 Quote
piernov Posted November 11, 2025 Posted November 11, 2025 Thanks a lot for the patch. Got the H264 encoder to encode the test pattern on Allwinner V3s, with the additional following patches: https://lkml.org/lkml/2020/11/16/486 "ARM: dts: sun8i: v3s: Add node for system control", https://lkml.org/lkml/2020/11/16/485 "ARM: dts: sun8i: v3s: Add video engine node", and the patch in attachment to enable JPEG/H264 encoder capabilities on V3s. However the lack of RAM on V3s causes the kernel CMA to really struggle so I have only been able to run the encoder at low definitions for now. 0001-media-cedrus-v3s-H264-and-JPEG-and-capabilities.patch 0 Quote
