Dave Posted February 9, 2023 Posted February 9, 2023 (edited) Hello to everyone Trying to use armbian on RockPi 4C plus. Got kernel OOPS. Kernel crushes in different moments: mostly during systemd units starting or just after boot finished. Backtraces are different (no common). Faulty images: 1) From the https://www.armbian.com/rockpi4/ For Model C+ here: https://redirect.armbian.com/rockpi-4cplus https://mirrors.dotsrc.org/armbian-dl/rockpi-4cplus/archive/ Armbian_22.11.1_Rockpi-4cplus_bullseye_current_5.15.80_minimal.img 2) Built by myself Armbian_22.11.2_Rockpi-4cplus_bullseye_current_5.15.84_minimal.img Armbian_23.02.0-trunk_Rockpi-4cplus_bullseye_edge_6.1.8_minimal.img Armbian_23.02.0-trunk_Rockpi-4cplus_bullseye_edge_6.1.9_minimal.img Armbian_23.02.0-trunk_Rockpi-4cplus_bullseye_edge_6.1.10_minimal.img My image build script for the edge (6.1.x): #!/bin/bash BOARD_NAME_PARAM="rockpi-4cplus" LINUX_DISTRO_PARAM="bullseye" LOG_FILE="_armbian_build_${BOARD_NAME_PARAM}.log" BRANCH_VALUE="edge" log() { local currtime=`date +"%Y/%m/%d %H:%M:%S"` echo "$currtime: $*" echo "$currtime: $*" >> $LOG_FILE } log "$0 begin" ARMBIAN_BUILD_OPTIONS="\ BOARD=$BOARD_NAME_PARAM \ BRANCH=$BRANCH_VALUE \ FULL_DESKTOP=no \ BUILD_DESKTOP=no \ BUILD_MINIMAL=yes \ INSTALL_HEADERS=no \ KERNEL_ONLY=no \ KERNEL_CONFIGURE=no \ RELEASE=$LINUX_DISTRO_PARAM \ COMPRESS_OUTPUTIMAGE=\"sha,img,xz\" \ " log "ARMBIAN_BUILD_OPTIONS=$ARMBIAN_BUILD_OPTIONS" log log "====================================" log "Armbian build - starting ..." log "====================================" sudo ./compile.sh $ARMBIAN_BUILD_OPTIONS armbian_compile_result=$? if [ $armbian_compile_result -eq 0 ]; then log "====================================" log "Armbian build finished: SUCCESS" log "====================================" else log "====================================" log "Armbian build failed: ERROR" log "====================================" fi log "$0 end" exit 0 All the faulty images have common thing in /boot/armbianEnv.txt fdtfile=rockchip/rk3399-rock-pi-4c-plus.dtb As I found out there are 2 dtbs referring to rockpi 4cplus: /boot/dtb-6.1.10-rockchip64/rockchip/rk3399-rock-4c-plus.dtb /boot/dtb-6.1.10-rockchip64/rockchip/rk3399-rock-pi-4c-plus.dtb Vanilla kernel https://github.com/torvalds/linux/tree/master/arch/arm64/boot/dts/rockchip has rk3399-rock-4c-plus dts https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/rockchip/rk3399-rock-pi-4c.dts and does not have rk3399-rock-pi-4c-plus I've changed /boot/armbianEnv.txt in the following way fdtfile=rockchip/rk3399-rock-4c-plus.dtb WIth rk3399-rock-4c-plus.dtb my RockPi 4C plus board boots fine and does not hang. I believe there is a mistake in dtb files. Why there are 2 dtbs /boot/dtb/rockchip/rk3399-rock-4c-plus.dtb /boot/dtb/rockchip/rk3399-rock-pi-4c-plus.dtb ? Edited February 10, 2023 by Dave 0 Quote
krankes_etwas Posted March 4, 2023 Posted March 4, 2023 (edited) another issue but I can confirm that all the rock 4c+ dtb's are probably faulty. With all of them with different OS & Kernel my GPU isn't detected but as soon I switch to 4C or 4B dtb my gpu is detected...... took a while to figure that out 😵 any ideas ? Edited March 4, 2023 by krankes_etwas 0 Quote
Michael Beck Posted May 14, 2023 Posted May 14, 2023 I can confirm that rk3399-rock-4c-plus.dtb is slightly better. No kernel ops on boot, and I was able to write the image to emmc and boot from it. With rk3399-rock-pi-4c-plus.dtb emmc writes generate errors and the resulting fs is broken. 0 Quote
